Smart test aborted and Truenas shows as unhealthy pool
Hello for context I have never had a drive fail and am not sure what I am looking at/for with SMART tests.
I was woken up early in the morning to some emails from my Truenas Scale saying that one of my 2 year old drives had a bunch of errors below are the alerts I got:
  • Device: /dev/sdg [SAT], not capable of SMART self-check.
  • Device: /dev/sdg [SAT], failed to read SMART Attribute Data.
  • Device: /dev/sdg [SAT], Read SMART Self-Test Log Failed.
  • Device: /dev/sdg [SAT], Read SMART Error Log Failed.
I have since run a extended offline test on the drive and it says completed without error. My Truenas UI still has the alerts active and the device said the status of the disk (sdg) was failed until I offlined then reonlined the disk.
I am not sure if this is something I should be worried about I have bought a spare disk and am prepared to do a swap but I know the disk will still be under warranty (unsure if this would be warranty worthy)
I did a # smartctl -a /dev/sdg and this was my output I am not sure what I am looking at and would appreciate some if any guidance. My questions is should I replace this drive?
root@truenas[~]# smartctl -a /dev/sdg
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.29-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST8000VN004-2M2101
Serial Number:    #######
LU WWN Device Id: 5 000c50 0e0db3216
Firmware Version: SC60
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Sep 23 13:22:00 2024 AEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  559) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 705) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   072   064   044    Pre-fail  Always       -       14952472
  3 Spin_Up_Time            0x0003   085   081   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       74
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       677572863
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       17764
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       74
18 Head_Health             0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   019   000    Old_age   Always       -       81
190 Airflow_Temperature_Cel 0x0022   066   050   040    Old_age   Always       -       34 (Min/Max 31/37)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       42
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       2439
194 Temperature_Celsius     0x0022   034   050   000    Old_age   Always       -       34 (0 19 0 0 0)
195 Hardware_ECC_Recovered  0x001a   072   064   000    Old_age   Always       -       14952472
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       17566h+33m+26.660s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       39750117148
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       278053802580
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     17744         -
# 2  Extended offline    Interrupted (host reset)      00%     17731         -
# 3  Short offline       Completed without error       00%     17682         -
# 4  Short offline       Completed without error       00%     17490         -
# 5  Extended offline    Completed without error       00%     17406         -
# 6  Short offline       Completed without error       00%     17322         -
# 7  Short offline       Completed without error       00%     17082         -
# 8  Extended offline    Completed without error       00%     16998         -
# 9  Short offline       Completed without error       00%     16938         -
#10  Short offline       Completed without error       00%     16746         -
#11  Extended offline    Completed without error       00%     16662         -
#12  Short offline       Completed without error       00%     16578         -
#13  Short offline       Completed without error       00%     16338         -
#14  Extended offline    Completed without error       00%     16254         -
#15  Short offline       Completed without error       00%     16194         -
#16  Short offline       Completed without error       00%     16003         -
#17  Extended offline    Completed without error       00%     15918         -
#18  Short offline       Completed without error       00%     15835         -
#19  Short offline       Completed without error       00%     15622         -
#20  Extended offline    Completed without error       00%     15539         -
#21  Short offline       Completed without error       00%     15479         -
The above only provides legacy SMART information - try 'smartctl -x' for more
Which version of TrueNAS? That would be helpful.
Have you powered off the machine, waited about 5 to 10 seconds, then powered back on to see if the problem still exists?
The only thing I see of any concern about the drive are the Hardware ECC corrections, it is rather high. The seek error rate could be an issue but I didn’t to the math to subtract “FFFF” from the value to see what the true errors are.
Best of luck, headed into work.
Silverstone 6 port Sata 3 PCIe Card SST-ECS06
Which is a PCIe3x2 with ASM1166
PCIe Gen3 x2 with ASMedia ASM1166 SATA host controller (AHCI)
Compliant with AHCI Specification Rev. 1.4
Support six SATA Gen3 (6Gbps) ports
Support SATA port multiplier command based switching
Support device sleep power management
Low profile design
Its not a proper HBA device and may be at leats part of the cause here
I feel like an idiot, rebooting should have been my go to first step, it cleared those alerts. I still don’t know what to look out for/when I should be looking to replace a drive. Should it be wait until the drive actually dies?
Also my truenas version is Dragonfish-24.04.1.1 and the other factor is I upgraded from a data card to a hba Supermicro 9300-8I
Yea I did swap it out to a Supermicro 9300-8I about 3 months ago and tossed the sata board I just forgot to update my build signature.
Well that is easy, sort of. I will summarize it however if in doubt, ask the forum.
These are the key indicators:
  1. Long/Extended/Short self-tests not completing, no errors.
  2. ID 5, 197, 198, 199, 200 higher than zero is notable, if the value is double digits, it is a problem and if it is incrementing that is a HUGE warning to backup your data (depends on your redundancy) and replace the drive, with the possible exception of ID 200 which may go up and might be fine. It is a hit and miss it seems.
  3. ID 194 Temperature too high. I high value here doesn’t mean disaster, but it could mean you have voided your warranty and that you may feel some premature failures.
I recommend you test your drives this way:
Short test = Daily
Long Test = Weekly
I have an updated Hard Drive Troubleshooting Guide I’m in the middle of updating to include NVMe drives. Once complete I will post it as a resource. An old one is there now which may help you.
