I’ve been using FreeNAS/TrueNAS successfully for several years on a Dell PowerEdge R720 with an unraid controller recommended by this community.
I recently swapped out all of the 14x 7.2k rpm data drives with brand new 14x SSD data drives. The basic steps I followed were:
Moved all of my data off
Destroyed the pool
Power down
Swapped the media
Power on
Create new pool on the SSDs
Created new test Zvol
Begin testing
Everything seems to be working fine from the surface. However, the console ocassionally scrolls messages about three of the 14 SSD drives. Do I really have 3 problematic drives that need to be replaced already or is something else going on? I have no idea how critical or benign these messages are. I can replace the three drives if necessary but I didn’t want to go through those motions and waste time if that was the wrong path.
Run a smart long test on all the drives and after they finish (usually 10 minuites or so for SSDs) post the SMART data.
You can start a SMART long test using smartctl -t long /dev/daXX where XX is the number of the drive; smartctl -a /dev/daXX to see the smart data of the drive XX.
root@truenas1:~ # smartctl -t long /dev/da10
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke,
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 60 minutes for test to complete.
Test will complete after Fri Aug 23 09:54:24 2024 CDT
Use smartctl -X to abort test.
root@truenas1:~ # smartctl -a /dev/da10
Device Model: SSDSC2KG480GZR
Serial Number: PHYJ2436025P480AGN
LU WWN Device Id: 5 5cd2e4 1561b6719
Add. Product Id: DELL(tm)
Firmware Version: 7CV1DL74
User Capacity: 480,103,981,056 bytes [480 GB]
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Aug 23 11:40:45 2024 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
been run.
data collection: ( 72) seconds.
capabilities: (0x79) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
Self-test supported.
power-saving mode.
Short self-test routine
recommended polling time: ( 60) minutes.
Conveyance self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
1 Raw_Read_Error_Rate 0x000e 130 130 039 Old_age Always - 1875474734
5 Reallocated_Sector_Ct 0x0033 076 076 001 Pre-fail Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 41
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
13 Read_Soft_Error_Rate 0x001e 110 100 000 Old_age Always - 1875474734
170 Unknown_Attribute 0x0033 100 100 010 Pre-fail Always - 0
171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
173 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 1
174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2
175 Program_Fail_Count_Chip 0x0012 100 100 010 Old_age Always - 0
179 Used_Rsvd_Blk_Cnt_Tot 0x0033 100 100 010 Pre-fail Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 3628
181 Program_Fail_Cnt_Total 0x003a 100 100 000 Old_age Always - 0
182 Erase_Fail_Count_Total 0x003a 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 26
195 Hardware_ECC_Recovered 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
201 Unknown_SSD_Attribute 0x0033 100 100 010 Pre-fail Always - 25780685028
202 Unknown_SSD_Attribute 0x0027 100 100 000 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 282
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
235 Unknown_Attribute 0x000b 100 100 000 Pre-fail Always - 282
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 478
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 28617
245 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 100
SMART Error Log not supported
# 1 Extended offline Completed without error 00% 38 -
# 2 Extended offline Completed without error 00% 37 -
Read SMART Selective Self-test Log failed: scsi error aborted command
root@truenas1:~ # smartctl -t long /dev/da11
Testing has begun.
Test will complete after Fri Aug 23 12:42:07 2024 CDT
root@truenas1:~ # smartctl -a /dev/da11
Serial Number: PHYJ2424005R480AGN
LU WWN Device Id: 5 5cd2e4 156198b42
Local Time is: Fri Aug 23 12:43:42 2024 CDT
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000e 130 130 039 Old_age Always - 937772179
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 42
13 Read_Soft_Error_Rate 0x001e 105 095 000 Old_age Always - 5232739475
180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 3624
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 27
201 Unknown_SSD_Attribute 0x0033 100 100 010 Pre-fail Always - 17183934841
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 278
235 Unknown_Attribute 0x000b 100 100 000 Pre-fail Always - 278
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 471
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 14309
# 1 Extended offline Completed without error 00% 41 -
root@truenas1:~ # smartctl -t long /dev/da14
Testing has begun.
Test will complete after Fri Aug 23 13:44:22 2024 CDT
root@truenas1:~ # smartctl -a /dev/da14
Serial Number: PHYJ2424008L480AGN
LU WWN Device Id: 5 5cd2e4 156198ba3
Local Time is: Fri Aug 23 13:57:26 2024 CDT
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000e 130 130 039 Old_age Always - 937771937
5 Reallocated_Sector_Ct 0x0033 077 077 001 Pre-fail Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 43
13 Read_Soft_Error_Rate 0x001e 108 108 000 Old_age Always - 937771937
180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 3679
201 Unknown_SSD_Attribute 0x0033 100 100 010 Pre-fail Always - 17184655774
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 288
235 Unknown_Attribute 0x000b 100 100 000 Pre-fail Always - 288
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 485
# 1 Extended offline Completed without error 00% 42 -
thanks for the response and promise I will replace it eventually, though it has already passed multiple tests without any issues. I was hoping for more specific advice regarding the console message.
also, I was under the impression that my post was relevant to this thread since the situation is very similar. if it’s more appropriate, I can certainly create a new thread (however forum rules say not to cross-post the same thing in multiple topics), but I was just looking for helpful input related to my current issue
