I would like to have more insight on understanding the snapshots on TrueNAS.
I configured them on my datasets and I use them for backup:
- in replication task on a backup server
- manually twice a year on cold backup
- roll back when I did some mistakes!
And there are some subtleties that elude me⦠because well, I donāt necessarily need them. ![]()
But I would like to understand it a bit hence my message.
Context:
Iām doing a manual backup from a snapshot of a dataset from a server (A) to another server (B, on the LAN).
So I use zfs send/recv through nc from a terminal on each of the servers.
From the source server (A) I have existing snapshots:
root@ServerA[~]# zfs list -r -t snapshot -o name,creation Tank/Document
Tank/Document@auto-20240622.0030-12m Sat Jun 22 0:30 2024
Tank/Document@auto-20240622.0130-12m Sat Jun 22 1:30 2024
Tank/Document@auto-20240623.0030-12m Sun Jun 23 0:30 2024
Tank/Document@auto-20240623.0130-12m Sun Jun 23 1:30 2024
Tank/Document@auto-20240624.0030-12m Mon Jun 24 0:30 2024
Tank/Document@auto-20240624.0130-12m Mon Jun 24 1:30 2024
Note: yeah, donāt ask me about the snapshots at 00:30 and 01:30 on the same day, I just noticed, I have to look into that! ![]()
So I use the following on server A:
root@ServerA[~]# zfs send Tank/Document@auto-20240622.0130-12m | nc -l 3333
And the following on the target server (server B):
root@ServerB[~]# nc 192.168.1.20 3333 | zfs recv Backup/Document
And that works perfectlyā¦
Question:
It took me several days to finished my backup and I thought, in the meantime I have new snapshots from the Document dataset, letās send them overā¦
So I thought Iād sent the latest snapshot:
root@ServerA[~]# zfs send Tank/Document@auto-20240624.0130-12m | nc -l 3333
And I expected then the server B to show two snapshots for this dataset but instead I got an error:
cannot receive new filesystem stream: destination 'Backup/Document' exists
must specify -F to overwrite it
So I could use -F indeed but then, as I understand it, it will completely overwrite the existing snapshot (which is fine) but I was wondering, can I send this snapshot incrementally?
I thought Iād use -I in zfs send to send the missing snapshots in between but it didnāt work as expected, I got:
Server A:
root@ServerA[~]# zfs send -I Tank/Document@auto-20240622.0130-12m Tank/Document@auto-20240624.0130-12m | nc -l 3333
Server B:
cannot receive incremental stream: destination Backup/Document has been modified
since most recent snapshot
On server B, the data in the Document dataset has not been changed (beside of the zfs recv), so Iām surprised.
Am I missing something?
Maybe a parameter? Or my understanding of how to use the snapshots, or the zfs send/recv?
Or maybe the way I do it is not compatible with sending incremental snapshots (but then, why?)?
Thanks for your insights.
