When it comes to replication, is replication via sneakernet from one NAS to the backup NAS possible?
Ie
export snapshots from primary NAS to a DAS
Transport DAS to remote NAS
Import snapshots at remote NAS from DAS
Especially if the primary and remote NAS are trying but failing to replicate their initial dataset snapshots due to the size of said snapshots, network interruptions, etc.
I’ve done that using an external USB drive in the past
Basically the process was:
Connect drive
Create pool on drive.
Setup local replication job from Pool 1 → USB Pool.
Run replication
Export pool
Sneaker-net to new system
Import Pool
Setup local replication job from USB pool back to Remote Local Pool
Run job
Downside of that vs a DAS is that its a single drive, so no redundancy for the sneakernet portion if something goes wrong in transit. But ZFS will let you know if anything checksum-wise looks off.
To keep things simplified, and more likely to “just work”, use the same options for steps #3 and #8, whether you use the GUI or manual command-line.
The output of ZFS Send is a data stream, which can be saved as a file. This file can be copied via many different methods to the remote site. Including via a ZFS pool on a USB disk. Slightly different from @kris’ solution.
I have personally used a full ZFS Send output file to restore a pool remotely. (The ZFS Send file was copied via SCP.)
One weird / neat thing about incremental ZFS sends to remote locations, via manual methods, is that you can collect a few on the transfer media. Meaning you might do incremental ZFS Sends once a week, but only update the remote pool once a month.
You can collect 4 incremental ZFS send files on the USB drive. Then, as long as you ZFS Receive the files in the right order, (oldest first), you should be good.
That is useful if you have a remote place like a cabin, or relative that you don’t visit as regular as your ZFS snapshot schedule is performed.
Wait. @Constantin, just to make sure about something:
In your opening post, were you implying that when you “travel back to the physical location” of the “remote NAS”, you are going to remove the drives from the DAS and insert them into the remote NAS server to permanently reside here? (In other words, only two pools are involved.)
Or did you mean there are three “pools” involved? Main NAS pool + DAS pool + Remote NAS pool?
Only two pools - one primary, one remote. The initial replication keeps getting interrupted by network disconnects and ZFS send does not handle that well - restarting from scratch every time.
Since my entire primary pool will fit on one 12TB drive, I’ll simply follow @kris instructions to get the initial replication done. Subsequent incrementals are tiny by comparison and should execute without issues.
