Hi all,
I have a test deployment of TrueNAS Scale (Dragonfish-24.04.2.3) running on a computer with a few drives connected. I’m trying to wipe my pool/dataset and start fresh but when trying to remove it using Storage > Export/Disconnect, I get the error in the title and this log:
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool.py", line 87, in do_delete
with libzfs.ZFS() as zfs:
File "libzfs.pyx", line 529, in libzfs.ZFS.__exit__
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool.py", line 88, in do_delete
zfs.destroy(name, force=options['force'])
File "libzfs.pyx", line 1598, in libzfs.ZFS.destroy
libzfs.ZFSException: cannot unmount '/var/db/system/samba4': pool or dataset is busy
File "/usr/lib/python3.11/concurrent/futures/process.py", line 256, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 112, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 34, in _call
with Client(f'ws+unix://{MIDDLEWARE_RUN_DIR}/middlewared-internal.sock', py_exceptions=True) as c:
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 40, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 53, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 191, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool.py", line 93, in do_delete
raise CallError(str(e), errno_)
middlewared.service_exception.CallError: [EFAULT] cannot unmount '/var/db/system/samba4': pool or dataset is busy
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 469, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 511, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 47, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/export.py", line 145, in export
await self.middleware.call('zfs.pool.delete', pool['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1564, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1417, in _call
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 199, in delete
return await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1425, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1431, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1337, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
middlewared.service_exception.CallError: [EFAULT] cannot unmount '/var/db/system/samba4': pool or dataset is busy```
type or paste code here
I have the SMB service turned off and no docker containers or anything running. What is hanging this up?
