[Solved] Qbittorrent default password not working
This is to show you how to fix default credentials not working in qbittorrent in truenas core not sure whether it will work in scale
first open a shell to the qbittorrent jail you created
then stop the qbittorent service using the following command
service qbittorrent stop
vi the config file
vi /var/db/qbittorrent/conf/qBittorrent/config/qBittorrent.conf
Add the following line at the end of the file
[Preferences]
WebUI\Password_PBKDF2="@ByteArray(ARQ77eY1NUZaQsuDHbIMCA==:0WMRkYTUWVT9wVvdDtHAjU9b3b7uB8NR1Gur2hmQCvCDpm39Q+PsJRJPaCU51dEiz+dTzh8qbPsL8WkFljQYFQ==)"
Finally start the service again
Once you login make sure to change the password from the webUI
When i did this i uninstalled and reinstalled the plugin
Thanks for finding this. Slight correction, your final step should say “start” not "stop.
Thank you for a simple solution that worked right out of the box. I had 10 hours into installing qbit and 2-3 of them were getting past a nonexistent login. Plenty of stuff for Docker but nada for a vanilla install and default credentials.
Thanks and happy new year.
Can someone help me? I can’t save the options, nothing, I can’t change my password or any other options.
Doesnt qbittorrent show login credentials in its log on the first boot. There is no default login/passwd anymore ?
