SOLVED: Use SSL wildcard on jails
Hi all,
i have a really “noob” question (don’t be too harsh on me :slight_smile: ).
Long story short: I don’t wanna “expose” my homenas, i have a dynamic ip, but i have free access to a domain and to his relative SSL Wildcard… so i pointed an A record to my local nas ip → installed the wildcard → and all work fine (until, obv, im in my local net).
Im mapping my jail’s IP too, with theyr own A record… but how i can use the same wildcard installed in “Certificates”?
What sort of application and specifically which web server is running inside that jail?
Heimdall and nextcloud, both using Caddy
Copy the cerficate and key files somewhere inside the jail, I suggest /usr/local/etc/ssl or /usr/local/etc/certs or some such.
Then configure Caddy for custom SSL as outlined in this document:
work like a charm, thanks for the tip!
