Beloved TrueNAS Community,
during the last month and years you answered so much of my questions and did everything to improve my knowledge about storage systems, ZFS and TrueNAS. When I did my first TrueNAS build there were some solutions I was not fully satisfied with for my home-lab setup. Therefore, I started to design some custom pieces to mount my parts more nicely into my server. At this point I want to share the results with you, as I assume it will help some other users here in the forum.
So feel free to use my following adapters.
Supermicro ATX Powersupply Bracket
A bracket to mount an ATX power supply into the Supermicro PS/2 power supply slot of a Supermicro Superchassis CSE-743.
https://www.thingiverse.com/thing:6788493
CPU Fan Adapter Supermicro A2SDi
Two different models of a CPU fan adapter to be mounted on the CPU cooler of the Supermicro A2SDi series of motherboards. The fan adapter is only “clipped” onto the CPU cooler without any screws, glue, or zip-ties.
https://www.thingiverse.com/thing:6788511
HBA Fan Adapter LSI 9211-4i (IBM ServeRAID H1110)
This model can be mounted on an IBM ServeRAID H1110 (81Y4494) controller of the type 9211-4i (SAS 2004) and can hold a 40mm fan of the type “Noctua NF-A4x20 PWM”. There are absolutely no screws required.
https://www.thingiverse.com/thing:6788526
HBA Fan Adapter LSI 9305-16i
This model can be mounted on an LSI HBA controller of the type 9305-16i and can hold a 60mm fan of the type “Noctua NF-A6 PWM”. There are no screws required.
https://www.thingiverse.com/thing:6788527
Thanks again for all your support,
Thomas
