Sonarr plugin broke, can't reinstall, need to upgrade to scale?
so i been on core 13.3 for a long time. i only run sabnzb/sonarr/radarr/plex. nothing else and have data set. for storage. Suddenly my sonarr broke, i can ping it, but gui doesn’t load. I tried to pkg update, and kept getting error because repo doesn’t exist etc. i guess i have to upgrade to scale now to reinstall sonarr?
is the upgrade from 13.3 to scale simple and easy? do i have to do a lot of setup for the 4 plugins/jail i use? or will it migrate fine and work fine?
If there is a way to reinstall sonarr in my 13.3, i rather do that, please help.
this is the error i get when trying to reinsta//update sonarr
root@sonarr:~ # pkg update
Updating iocage-plugins repository catalogue…
pkg: http://pkg.freebsd.org/FreeBSD:12:amd64/latest/meta.txz: Not Found
repository iocage-plugins has no meta file, using default settings
pkg: http://pkg.freebsd.org/FreeBSD:12:amd64/latest/packagesite.pkg: Not Found
pkg: http://pkg.freebsd.org/FreeBSD:12:amd64/latest/packagesite.txz: Not Found
Unable to update repository iocage-plugins
Error updating repositories!
i also tried to update the jail to 13.3 before updating pkg and got this error
root@freenas[~]# iocage upgrade -r 13.3-RELEASE sonarr
Snapshotting sonarr…
Snapshot already exists
Updating plugin INDEX…
Updating plugin artifact…
Cloning git repository
Branch 13.3-RELEASE does not exist at GitHub - freenas/iocage-plugin-sonarr: Artifact file(s) for Sonarr iocage plugin!
Using “master” branch for plugin, this may not work with your RELEASE
New plugin RELEASE missing, fetching now…
13.2-RELEASE was not found!
root@freenas[~]#
I’m absolutely no expert for core jails, never used them… but don’t you have to do an iocage fetch for 13.4-release?
From the error it seems to me you’re still on iocage 12
correct, i did that and tried it before and got the following error:
root@freenas[~]#
You need to use 13.4
yup, tried that too. same error. seems like the plugin isn’t available outside of 12.**
yeah, if it was a plugin that explains a lot, those haven’t been maintained for years. you can try to roll out your own jail and manually install it inside it, but even the 13.4 release doesn’t have a long support window left. And Core 13.3 won’t get any updates anymore.
