I am using Truenas Core in my small company since 2 years. We are also using a second server - just because of SQL ampplications.
Is there any way to install SQL Express on TrueNAS machine?
#SQLexpress #sqlTruenas
At the time i was using Core, i did some research to achieve the same goal (running SQL express on a jail) but at the end i didn’t find anything that could work.
The fact is that FreeBSD isn’t supported, instead linux is… so if there is a way to run Linux jail’s into Core will be for sure tricky but maybe viable.
If can be usefull anyway… i’m running SQL Express into a docker container in Scale. So you can explore those options
Thank you so much, Using VM and second operating system will be solution.
Thank you again.
