Greetings all.
I completed my migration from Core to Scale. I did not find any issues with 24.04, so I jumped to 24.10. Immediately I noticed a problem with the storage widgets on the Dashboard (see below). I saw this post from November '24 with the same problem. That problem corrected itself with no apparent solution. I tried mucking with pool, but the widgets are still not working.
Is this a problem with Scale 24.10? Has anyone else encountered this problem?
Try to “rebuild” thoses wigets. Top right of Dashboard click Configure and edit the wigets in question.
Thanks for the suggestion, alleykat. It partially worked. I also tried to delete and add the broken widgets to no avail.
Any other suggestions?
Sometimes clearing the web browser cache fixes the issues. I use Firefox and Ctrl-F5 clears the cache.
Sorry, been away for a few days, I tries that, it didn’t work. Thank you @alleykat for the suggestions!
If anyone else has run into and solved this problem, please let me know.
