Syncthing permission denied
Hello everybody
I’m setting up Truenas in a small office to backup documents from users’ stations, I installed the Syncthing app to synchronize documents from Windows stations with shared folders on the Truenas server.
I configured sharing in ACL Editor like this:
Where the user: ti, in the group: ti, may Read | Write | Execute, the folder /mnt/Arquivos_Princesa/BKP/ti
ACL Editor
Path: /mnt/Arquivos_Princesa/BKP/ti
Owner: ti Owner Group: ti
Access Control List
User Obj – ti Read | Write | Execute
User – apps Read | Write | Execute
User – ti Read | Write | Execute
Group Obj – ti Read | Write | Execute
Group – ti Read | Write | Execute
Mask Read | Write | Execute
Other None
User Obj – default – ti Read | Write | Execute
User – default – ti Read | Write | Execute
Group Obj – default – ti Read | Write | Execute
Group – default – ti Read | Write | Execute
Mask – default Read | Write | Execute
groups
Other – default None
And I configured App Syncthing like this:
Application Name
syncti
Syncthing Configuration
Additional Environment Variables
No items have been added yet.
User and Group Configuration
User ID: 3002
Group ID: 3000
Advanced Pod Configuration
Advanced DNS Configuration
DNS Options
Network Configuration
Web Port: 20910
TCP Port: 20978
UDP Port: 20979
( ) Host Network
Storage Configuration
Type: Host Path (Path that already exists on the system)
Host Path Config
(X) Enable ACL
ACL Configuration
Host Path: /mnt/Arquivos_Princesa/BKP/ti
Entradas ACL Add
ID Type: Entry is for a USER
Access: FULL_CONTROL Access
ACL Options
(X) Force Flag
Additional Storage: No items have been added yet.
Resources Configuration
Limits
CPU: 4000m
Memory: 8Gi
But when accessing “http://192.168.18.2:20910” and adding folder, I only get the response:
“Failed to create folder root directory mkdir /mnt/Arquivos_Princesa: permission denied”
and
“Error on folder “Documentos” (hg3z7-acsui): folder path missing”
Can anyone give me a tip on where I’m going wrong?
Or if something is missing from configuring?
I have the same issue. Were you able to resolve it?
I have the same issue too.
I createde a pool, for SyncThing, installed it and pointed it to /mnt/Pool1/SyncThing
I updated the default folder location for SyncThing also to /mnt/Pool1/SyncThing
I have shared a test folder and it picks it up, tries to put it in /mnt/Pool1/SyncThing/TEST and then i get
Failed to create folder root directory: mkdir /mnt/Pool1: permission denied
I think i may have solved this, I need to test on a fresh install, but what i think is this:
I created a storage pool “Pool1”
In there i created a Dataset “SyncThing” (/mnt/SyncThing, this worked a set as a normal file share)
I had syncthing set to use /mnt/SyncThing
This did not work
I blundered around in circles for ages and for some reason I decided to create a sub folder and changed syncthing to use /mnt/SyncThing/Sync and it appears to work.
Basically it appears using the root dataset folder is not how to do it :smile:
