Hi, I’m trying to understand how the encryption keys are saved on TrueNAS.
If I use encryption keys to encrypt e.g.
pool-1, those keys are then stored in the System Dataset, by default, on the boot-pool, right? -
If I were to move the System Dataset to encrypted
pool-1, what would happen on boot? Complete brick? Or would it ask me to manually input the key? -
What do I gain by encrypting the System Dataset? I understood that on Scale, System Logs are on the boot-pool, and that cannot be changed (at the time of posting), but what else is on the System Dataset?
Boot-pool encryption? Is this possible at all? I’m running TrueNAS as a VM on XCP-ng.
I figure it would be easiest to keep the System Dataset on an SSD (boot-pool), and just encrypt it completely, also blocking off access to any other encryption key. And yes, I am aware this would then require me inputting that key on every boot.
From there, if 4. is somehow possible, the ideal solution for the security oriented homelabber could be having a USB drive attached with the “main” key → System boots, using the “main” key decrypts the boot-pool, which then has decryption keys for all other drives.
I can then unplug the USB before leaving home, knowing that if I need to destroy it, my data would be safe with a simple power cycle.
Any other interesting ideas?
