Terramaster F8 Plus, Enabling VT-d
I recently purchased a Terramaster F8 Plus, which is an all NVMe NAS.
I was able to install TrueNAS 25.04.0 by disabling the VT-d option in the bios.
Recently, I discovered a thread mentioning that adding pci=nommconf to the grub.cfg allows VT-d to be enabled. After some research, I created /boot/grub/custom.cfg using nano and added ‘set pci=nommconf’ (without quotes) to see if I could enable VT-d. My understanding is that parameters listed in custom.cfg are added to grub.cfg when it is rebuilt, but I’m not sure when a rebuild occurs.
It appears that adding ‘set pci=nommconf’ to custom.cfg did not work since TrueNAS crashes as soon as it attempts to list the disks when creating a pool.
Does TrueNAS automatically rebuild grub.cfg when it reboots, or is there something else that I should try?
Thanks!
I was able to make this work throught he magic of chatgpt. Below is the method I used to add pci=nommconf to grub using the midclt command in shell.
[HOWTO] Add Persistent Kernel Boot Parameters in TrueNAS SCALE (e.g., pci=nommconf)
If you’re trying to enable VT-d or need to pass custom kernel parameters like pci=nommconf (useful for fixing NVMe-related crashes when VT-d is enabled), do not edit GRUB manually — it can be overwritten during updates.
Instead, use the built-in midclt command, which safely stores the setting in the system configuration.
:white_check_mark: Steps (Tested on TrueNAS SCALE 25.04.0+)
  1. Open a shell (via Web UI or local terminal).
  2. Run this command to set the kernel option:
bash
Copy code
midclt call system.advanced.update '{"kernel_extra_options": "pci=nommconf"}'
  1. Confirm the change:
bash
Copy code
midclt call system.advanced.config | grep kernel_extra_options
You should see:
json
Copy code
  1. Reboot:
bash
Copy code
reboot
:counterclockwise_arrows_button: To Remove the Parameter Later:
bash
Copy code
midclt call system.advanced.update '{"kernel_extra_options": ""}'
:light_bulb: Notes:
  • This method is persistent across upgrades and safe to use.
  • You can include multiple parameters like so:
bash
Copy code
'{"kernel_extra_options": "pci=nommconf intel_iommu=on"}'
Hope this helps others with similar hardware issues or advanced configuration needs!
Hi, are these midclt call system.advanced.update commands kept after updates?
I found that adding a file in /etc/modprobe.d is not kept after minor updates and I’m looking to do it in the right way to not rewrite the file every time.
Thank you
I haven’t had any issues after running updates. Just upgrade to 25.04.2.4.
