I’m trying to set up tftpd-hpa with a mapfile, which I need because I’m trying to use it to PXE boot Windows systems, which of course uses the "" as the path separator.
Per the docs for the app, I try to set the MAPFILE environment variable, but when I do that I get the following error:
base_v2_1_2.error.RenderError: Environment variable [MAPFILE] is already defined from the application developer.
Does anyone have a workaround?
