I’m trying to run the Replication Wizard and it just continues to timeout on me. The stack trace is below. The two units are side by side on the same subnet and I can readily connect between them. Any thoughts?
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 211, in call_method
result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1529, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1460, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 179, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 49, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/keychain_/ssh_connections.py", line 99, in setup_ssh_connection
resp = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1629, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1471, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/keychain.py", line 630, in remote_ssh_semiautomatic_setup
with client as c:
File "/usr/lib/python3/dist-packages/middlewared/plugins/keychain.py", line 658, in remote_ssh_semiautomatic_setup
user = c.call("user.query", [["username", "=", data["username"]], ['local', '=', True]], {"get": True})
File "/usr/lib/python3/dist-packages/truenas_api_client/__init__.py", line 484, in call
return self.wait(c, callback=callback, job=job, timeout=timeout)
File "/usr/lib/python3/dist-packages/truenas_api_client/__init__.py", line 495, in wait
raise CallTimeout()
truenas_api_client.CallTimeout: Call timeout
Verify the SSH service settings to ensure you have Root with Password , Log in as Admin with Password , and Allow Password Authentication selected to enable these capabilities.
But the actual UI has only one such option:
*edit:
So looking at this through the eyes of tcpdump, the host that I am trying to set this up on isn’t sending anything out over the wire. So whatever the “timeout” is, it’s not in the actual network. This is a shiny brand spankin new install. So I don’t know what to make of it.
