Tips
If you run TrueNAS Scale with a SES-compatible SAS enclosure, you can easily locate a disk from the CLI with the encled utility.
For example if you want to locate the disk sde just type
encled sde locate
It works very well on my Supermicro JBOD + LSI 9300-8i HBA.
