Topology Degraded, Pool is not healthy but Disk Health is ok
One of my pools is showing the above. How can it be not healthy , then it is??
On another pool, Topology and ZFS health is ok, but Dik health shows 0 alerts and 19 failed smart tests.
Confused I will be
Robert_Heselwood:
That’s a red flag.
Other than that, I can’t say much.
Without knowing any details what-so-ever about your pool it’s going to be close to impossible to help you.
Posting smart reports from your disks and the output of sudo zpool status -v would be a great start.
As requested:
root@freenas[~]# sudo zpool status -v
pool: Backup_Data
state: DEGRADED
status: One or more devices could not be used because the label is missing or
invalid. Sufficient replicas exist for the pool to continue
functioning in a degraded state.
action: Replace the device using ‘zpool replace’.
see: Message ID: ZFS-8000-4J — OpenZFS documentation
scan: scrub repaired 0B in 00:44:23 with 0 errors on Sat Apr 12 17:34:38 2025
NAME STATE READ WRITE CKSUM
Backup_Data DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
16103469196657453443 UNAVAIL 0 0 0 was /dev/disk/by-partuuid/ce563f3f-528e-11e6-9216-0cc47a0c1eef
cf115aaa-528e-11e6-9216-0cc47a0c1eef ONLINE 0 0 0
errors: No known data errors
pool: CCTV
state: ONLINE
action: Enable all features using ‘zpool upgrade’. Once this is done,
scan: scrub repaired 0B in 00:02:21 with 0 errors on Sat Apr 12 17:52:30 2025
CCTV ONLINE 0 0 0
sdd2 ONLINE 0 0 0
On or for the Backup_Data pool, there are no SMART reports as such, only that it says:
sdc extended offline Success Lifetime 10461 No Errors
This is from running smartctl -x /dev/sdc
There are 7 errors in total from No 27 up to No 34, all are similar
Error 34 [9] occurred at disk power-on lifetime: 4938 hours (205 days + 18 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
04 -- 51 00 00 00 00 07 4d 69 30 00 00
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
ea 00 00 00 00 00 00 00 00 00 00 40 00 31d+08:04:23.872 FLUSH CACHE EXT
61 00 10 00 00 00 00 07 74 33 28 40 00 31d+08:04:23.872 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 07 74 33 08 40 00 31d+08:04:23.872 WRITE FPDMA QUEUED
61 00 10 00 00 00 00 00 c7 08 28 40 00 31d+08:04:23.872 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 00 c7 08 18 40 00 31d+08:04:23.872 WRITE FPDMA QUEUED
Running the same cmd for the CCTV pool, gives:
smartctl -x /dev/sdd
There is more information , but none for any errors as I can see.
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed: read failure 10% 15401 1953523096
# 2 Short offline Completed: read failure 60% 15390 1953523096
# 3 Short offline Completed: read failure 60% 15379 1953523096
# 4 Short offline Completed: read failure 60% 15365 1953523096
# 5 Short offline Completed: read failure 60% 15343 1953523096
# 6 Conveyance offline Completed without error 00% 15339 -
# 7 Extended offline Interrupted (host reset) 90% 15339 -
# 8 Short offline Completed: read failure 60% 15338 1953523096
# 9 Short offline Completed: read failure 60% 15319 1953523096
#10 Short offline Completed: read failure 60% 15295 1953523096
#11 Short offline Completed: read failure 60% 15271 1953523096
#12 Short offline Completed: read failure 60% 15247 1953523096
#13 Short offline Completed: read failure 60% 15223 1953523096
#14 Short offline Completed: read failure 60% 15199 1953523096
#15 Short offline Completed: read failure 60% 15175 1953523096
#16 Short offline Completed: read failure 60% 15151 1953523096
#17 Short offline Completed: read failure 60% 15127 1953523096
#18 Short offline Completed: read failure 60% 15103 1953523096
etorix
April 13, 2025, 4:10pm
4
Please provide the full output from smartctl as formatted text:
Use the </> button or paste between two lines of three backquotes
text
Is it the full output for both pools you want, or just one of them.
Still haven’t posted the full output… but from what you did post sdd is critically failing, since it’s failing short and extended tests. Conveyance passing isn’t enough change that.
sdc is likely also in bad shape, if it’s has 34 errors in the log.
Tough to say more without seeing the full output.
Mind you, sdc and sdd may be renamed during reboot. Always verify that you are working on the drive you think you’re working on, for example when preparing to replace one.
Full output for sdc disk
root@freenas[~]# smartctl -x /dev/sdc
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red (CMR)
Device Model: WDC WD10EFRX-68FYTN0
Serial Number: WD-WCC4J0CLAYDH
LU WWN Device Id: 5 0014ee 20d2446e3
Firmware Version: 82.00A82
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 5400 rpm
Device is: In smartctl database 7.3/5671
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Apr 13 17:12:14 2025 BST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (13680) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 156) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 123 121 021 - 4841
4 Start_Stop_Count -O--CK 100 100 000 - 135
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 001 001 000 - 76061
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 135
192 Power-Off_Retract_Count -O--CK 200 200 000 - 133
193 Load_Cycle_Count -O--CK 199 199 000 - 3741
194 Temperature_Celsius -O---K 110 094 000 - 33
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 34 (device log contains only the most recent 24 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 33 [8] occurred at disk power-on lifetime: 3082 hours (128 days + 10 hours)
04 -- 51 00 00 00 00 3d 3d 6d 30 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 3d+17:07:00.554 FLUSH CACHE EXT
61 00 08 00 00 00 00 22 b7 3c 50 40 00 3d+17:07:00.554 WRITE FPDMA QUEUED
61 00 10 00 00 00 00 0e 61 b0 20 40 00 3d+17:07:00.554 WRITE FPDMA QUEUED
61 00 10 00 00 00 00 0e 41 f5 f0 40 00 3d+17:07:00.554 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 5c 19 60 a0 40 00 3d+17:07:00.554 WRITE FPDMA QUEUED
Error 32 [7] occurred at disk power-on lifetime: 3082 hours (128 days + 10 hours)
04 -- 51 00 00 00 00 3d 3d 5d 20 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 3d+17:06:00.426 FLUSH CACHE EXT
61 00 10 00 00 00 00 2e 2a a2 50 40 00 3d+17:06:00.425 WRITE FPDMA QUEUED
61 00 20 00 00 00 00 2a ce 6b 68 40 00 3d+17:06:00.425 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 2a ce 6b 58 40 00 3d+17:06:00.425 WRITE FPDMA QUEUED
61 00 18 00 00 00 00 22 b7 33 08 40 00 3d+17:06:00.425 WRITE FPDMA QUEUED
Error 31 [6] occurred at disk power-on lifetime: 2070 hours (86 days + 6 hours)
04 -- 51 00 00 00 00 2a b8 c7 b8 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 11d+06:06:14.722 FLUSH CACHE EXT
61 00 10 00 00 00 00 34 29 b8 00 40 00 11d+06:06:14.721 WRITE FPDMA QUEUED
61 00 38 00 00 00 00 34 29 b7 c0 40 00 11d+06:06:14.721 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 34 29 b7 a8 40 00 11d+06:06:14.721 WRITE FPDMA QUEUED
61 00 10 00 00 00 00 2d d0 8c 40 40 00 11d+06:06:14.721 WRITE FPDMA QUEUED
Error 30 [5] occurred at disk power-on lifetime: 64907 hours (2704 days + 11 hours)
04 -- 51 00 00 00 00 2a 87 e7 40 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 28d+00:56:58.026 FLUSH CACHE EXT
61 00 08 00 00 00 00 28 ab 26 98 40 00 28d+00:56:58.026 WRITE FPDMA QUEUED
61 00 18 00 00 00 00 28 ab 26 78 40 00 28d+00:56:58.026 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 28 ab 26 60 40 00 28d+00:56:58.026 WRITE FPDMA QUEUED
61 00 10 00 00 00 00 28 5a 0c b0 40 00 28d+00:56:58.026 WRITE FPDMA QUEUED
Error 29 [4] occurred at disk power-on lifetime: 55110 hours (2296 days + 6 hours)
04 -- 51 00 00 00 00 6a 7c b1 38 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 33d+18:46:01.117 FLUSH CACHE EXT
61 00 08 00 00 00 00 6a b1 08 b0 40 00 33d+18:46:01.117 WRITE FPDMA QUEUED
61 00 18 00 00 00 00 6a b1 08 80 40 00 33d+18:46:01.116 WRITE FPDMA QUEUED
61 00 48 00 00 00 00 62 4f 68 e8 40 00 33d+18:46:01.116 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 62 4f 68 d8 40 00 33d+18:46:01.116 WRITE FPDMA QUEUED
Error 28 [3] occurred at disk power-on lifetime: 53254 hours (2218 days + 22 hours)
04 -- 51 00 00 00 00 62 8b 4a a0 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 6d+03:29:27.404 FLUSH CACHE EXT
61 00 08 00 00 00 00 41 75 26 68 40 00 6d+03:29:27.403 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 29 4b 2a 28 40 00 6d+03:29:27.403 WRITE FPDMA QUEUED
61 00 20 00 00 00 00 29 4b 29 f8 40 00 6d+03:29:27.403 WRITE FPDMA QUEUED
61 00 18 00 00 00 00 16 7d 75 50 40 00 6d+03:29:27.403 WRITE FPDMA QUEUED
Error 27 [2] occurred at disk power-on lifetime: 51567 hours (2148 days + 15 hours)
04 -- 51 00 00 00 00 41 1e 25 68 00 00
ea 00 00 00 00 00 00 00 00 00 00 40 00 13d+19:07:59.419 FLUSH CACHE EXT
61 00 10 00 00 00 00 72 af 7e 90 40 00 13d+19:07:59.419 WRITE FPDMA QUEUED
61 00 28 00 00 00 00 5d 3b 97 80 40 00 13d+19:07:59.419 WRITE FPDMA QUEUED
61 00 08 00 00 00 00 5d 3b 97 68 40 00 13d+19:07:59.419 WRITE FPDMA QUEUED
61 00 10 00 00 00 00 5d 09 70 20 40 00 13d+19:07:59.419 WRITE FPDMA QUEUED
# 1 Extended offline Completed without error 00% 10519 -
# 2 Extended offline Completed without error 00% 10461 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 33 Celsius
Power Cycle Min/Max Temperature: 25/36 Celsius
Lifetime Min/Max Temperature: 0/49 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (112)
Index Estimated Time Temperature Celsius
113 2025-04-13 09:15 33 **************
... ..( 81 skipped). .. **************
195 2025-04-13 10:37 33 **************
196 2025-04-13 10:38 34 ***************
... ..( 9 skipped). .. ***************
206 2025-04-13 10:48 34 ***************
207 2025-04-13 10:49 33 **************
... ..( 18 skipped). .. **************
226 2025-04-13 11:08 33 **************
227 2025-04-13 11:09 34 ***************
... ..( 15 skipped). .. ***************
243 2025-04-13 11:25 34 ***************
244 2025-04-13 11:26 35 ****************
... ..(107 skipped). .. ****************
352 2025-04-13 13:14 35 ****************
353 2025-04-13 13:15 36 *****************
... ..( 8 skipped). .. *****************
362 2025-04-13 13:24 36 *****************
363 2025-04-13 13:25 35 ****************
... ..( 6 skipped). .. ****************
370 2025-04-13 13:32 35 ****************
371 2025-04-13 13:33 34 ***************
... ..( 11 skipped). .. ***************
383 2025-04-13 13:45 34 ***************
384 2025-04-13 13:46 33 **************
... ..(205 skipped). .. **************
112 2025-04-13 17:12 33 **************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 135 --- Lifetime Power-On Resets
0x01 0x010 4 76061 --- Power-on Hours
0x01 0x018 6 99127197430 --- Logical Sectors Written
0x01 0x020 6 2248460397 --- Number of Write Commands
0x01 0x028 6 86007334658 --- Logical Sectors Read
0x01 0x030 6 375071772 --- Number of Read Commands
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 75682 --- Spindle Motor Power-on Hours
0x03 0x010 4 75363 --- Head Flying Hours
0x03 0x018 4 3875 --- Head Load Events
0x03 0x020 4 200 N-- Number of Reallocated Logical Sectors
0x03 0x028 4 1 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 1 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 33 --- Current Temperature
0x05 0x010 1 33 --- Average Short Term Temperature
0x05 0x018 1 34 --- Average Long Term Temperature
0x05 0x020 1 49 --- Highest Temperature
0x05 0x028 1 22 --- Lowest Temperature
0x05 0x030 1 45 --- Highest Average Short Term Temperature
0x05 0x038 1 25 --- Lowest Average Short Term Temperature
0x05 0x040 1 38 --- Highest Average Long Term Temperature
0x05 0x048 1 26 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 2440 --- Number of Hardware Resets
0x06 0x010 4 392 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 3 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 7 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 167329 Vendor specific
Full output for sdd disk
root@freenas[~]# smartctl -x /dev/sdd
Model Family: Western Digital Purple (Pro)
Device Model: WDC WD10PURZ-85U8XY0
Serial Number: WD-WCC4JFDM719T
LU WWN Device Id: 5 0014ee 215b9b049
Firmware Version: 01.01A01
Local Time is: Sun Apr 13 17:30:32 2025 BST
was never started.
Self-test execution status: ( 113) The previous self-test completed having
the read element of the test failed.
data collection: (13980) seconds.
command.
power-saving mode.
recommended polling time: ( 159) minutes.
3 Spin_Up_Time POS--K 136 136 021 - 4183
9 Power_On_Hours -O--CK 079 079 000 - 15407
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 12
192 Power-Off_Retract_Count -O--CK 200 200 000 - 8
193 Load_Cycle_Count -O--CK 200 200 000 - 4
194 Temperature_Celsius -O---K 110 099 000 - 33
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 1
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Power Cycle Min/Max Temperature: 26/36 Celsius
Lifetime Min/Max Temperature: 0/44 Celsius
Vendor specific:
Temperature History Size (Index): 478 (201)
202 2025-04-13 09:33 33 **************
... ..(220 skipped). .. **************
423 2025-04-13 13:14 33 **************
424 2025-04-13 13:15 34 ***************
431 2025-04-13 13:22 34 ***************
432 2025-04-13 13:23 35 ****************
... ..( 15 skipped). .. ****************
448 2025-04-13 13:39 35 ****************
449 2025-04-13 13:40 36 *****************
... ..(113 skipped). .. *****************
85 2025-04-13 15:34 36 *****************
86 2025-04-13 15:35 35 ****************
... ..( 9 skipped). .. ****************
96 2025-04-13 15:45 35 ****************
97 2025-04-13 15:46 34 ***************
113 2025-04-13 16:02 34 ***************
114 2025-04-13 16:03 33 **************
... ..( 86 skipped). .. **************
201 2025-04-13 17:30 33 **************
0x01 0x008 4 12 --- Lifetime Power-On Resets
0x01 0x010 4 15407 --- Power-on Hours
0x01 0x018 6 8982004116 --- Logical Sectors Written
0x01 0x020 6 92236387 --- Number of Write Commands
0x01 0x028 6 2118635915 --- Logical Sectors Read
0x01 0x030 6 7094228 --- Number of Read Commands
0x03 0x008 4 15364 --- Spindle Motor Power-on Hours
0x03 0x010 4 15364 --- Head Flying Hours
0x03 0x018 4 13 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 6898 --- Read Recovery Attempts
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x05 0x020 1 44 --- Highest Temperature
0x05 0x028 1 25 --- Lowest Temperature
0x05 0x030 1 42 --- Highest Average Short Term Temperature
0x05 0x038 1 28 --- Lowest Average Short Term Temperature
0x05 0x040 1 39 --- Highest Average Long Term Temperature
0x05 0x048 1 29 --- Lowest Average Long Term Temperature
0x06 0x008 4 480 --- Number of Hardware Resets
0x06 0x010 4 74 --- Number of ASR Events
||__ D supports DSN
Pending Defects log (GP Log 0x0c) not supported
0x8000 4 168430 Vendor specific
Robert_Heselwood:
sdc
The 34 errors aren’t great, but when put into the context of accruing those over 8.5 years, it dampens it somewhat. I suggest you run an extended smart test on it and see how it handles that. Only two tests appear to have been run total, and that was many, many years ago.
Robert_Heselwood:
sdd
When did you get this drive? If it hadn’t been a 1TB device I would say you may still have the ability to claim your warranty. But given the size I suspect this isn’t a new drive, even if it’s only been on for 1.7 years.
Time to replace it either way.
I bought x2 1Tb WD Red disks , which are sdc, in 2015. I then bought x1 1Tb WD Purple disk in 2023. and is just under 2 years old. As it has a 3 year warranty, I should get it replaced or money back
I bought them from Amazon UK
Robert_Heselwood:
2Tb WD Purple
Your SMART report says it’s 1 TB.
Either way, get it replaced on warranty.
It is a !TB Purple, my error.
I have a brand new 2TB purple surveillance disk which I now want to create a new pool with. So I selected Stripe, but a VDEV was automatically added, then a message saying:
A stripe data VDEV is highly discouraged and will result in data loss if it fails
So what layout do I select for 1 disk
A single stripe is always a risk, as long as you understand this, and that if the disk fails you lose all the data on it, you can click past that warning. ZFS will be unable to resolve any possible read errors and files impacted by those will be lost.
Your pool will consist of a single VDEV made up of single striped disk.
If you only have a one disk, that is your only option.
