For some reason when I run the TrueNAS (CORE) installer, either TrueNAS-13.0-U6.4.iso
or TrueNAS-13.3-U1.iso
on my box (C2550D4I) I can’t boot from it. I’m installing to an SSD plugged into a SATA port on the Marvell ‘controller’. While this isn’t recommended (BIOS says boot will be slower), all 6 other SATA ports on the main board are dedicated to my storage pool. The thing is, this works fine when I install vanilla FreeBSD (FreeBSD-14.2-RELEASE-amd64-disc1.iso
). I don’t know why, but it does… When I install TrueNAS, I can’t see the option to boot from this drive in the bios. I don’t change bios settings between OS versions.
I’m installing as UEFI boot. I think I tried ‘BIOS boot’, but I had the same issue. Not 100% sure.
Is there some way I can ‘dual boot’ TrueNAS on top of the FreeBSD?
Sorry if this is a stupid question.
My ‘plan B’ is to look at how FreeBSD does the disk partition and see if I can recreate that after installing TrueNAS. My plan C is to stick with FreeBSD ;-p
Many thanks for any tips.
