Truenas Core Uncorrectable I/O failure on storage pool
Any time I try to import the Storage pool, the console says: “Pool ‘WD40’ has encountered an uncorrectable I/O failure and has been suspended”
I’ve already tried moving the drives (including boot drive) to a different system (different everything but drives) with the same results.
Install Info:
Truenas Core 13.3
ASRock Rack X570D4u-2L2T
Bare metal install (no virtualization)
Controller is sas9207-8i on recommended firmware version.
zpool import
   pool: WD40
     id:
  state: ONLINE
status: The pool was last accessed by another system.
 action: The pool can be imported using its name or numeric identifier and
        the '-f' flag.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-EY
        WD40                                            ONLINE
          mirror-0                                      ONLINE
            gptid/da68761c-4e44-11ef-954d-d45d64549e0e  ONLINE
            gptid/da5e23ba-4e44-11ef-954d-d45d64549e0e  ONLINE
          mirror-1                                      ONLINE
            gptid/da55cad3-4e44-11ef-954d-d45d64549e0e  ONLINE
            gptid/da723071-4e44-11ef-954d-d45d64549e0e  ONLINE
          mirror-2                                      ONLINE
            gptid/da7c67de-4e44-11ef-954d-d45d64549e0e  ONLINE
            gptid/da857aec-4e44-11ef-954d-d45d64549e0e  ONLINE
          mirror-3                                      ONLINE
            gptid/da3edc18-4e44-11ef-954d-d45d64549e0e  ONLINE
            gptid/da500160-4e44-11ef-954d-d45d64549e0e  ONLINE
Symptoms
Any time I try to import the pool, I get :
Boot hangs at built-in zpool import -a
CTRL-C a couple times during boot gets to the point where I can get to menu and shell, shut down, etc.
Any use of zpool status will lock the terminal, CTRL-C doesn’t do anything
SMART test results previous to failure state didn’t show anything alarming, neither do short tests after failure state, I haven’t run long tests.
I’ve moved the drives (including boot drive) to another entire computer with different controller, Power Supply, Motherboard, CPU, RAM, etc… Same error on boot at zpool import.
I’ve current got a fresh install on USB with default configuration ready.
I’m looking for advice on how to proceed to try to recover data from drives. With troubleshooting steps I’m pretty sure it is a hardware issue on one of the drives, but short of disconnecting one at a time, I’m not how to move forward while minimizing risks to the data.
smartctl -x -v 1,hex48 -v 7,hex48 -v 188,raw16 /dev/da0
smartctl 7.4 2023-08-01 r5530 [FreeBSD 13.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     ST20000NM004E-3HR103
Firmware Version: SN01
User Capacity:    20,000,588,955,648 bytes [20.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database 7.3/5528
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Jul  9 10:25:31 2025 PDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Write SCT (Get) Feature Control Command failed: scsi error aborted command
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1734) minutes.
Conveyance self-test routine
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   076   064   044    -    0x000002502bd0
  3 Spin_Up_Time            PO----   090   090   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    66
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   086   060   045    -    0x000016769d73
  9 Power_On_Hours          -O--CK   092   092   000    -    7840
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    66
 18 Unknown_Attribute       PO-R--   100   100   050    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   091   000    -    1 1 46
190 Airflow_Temperature_Cel -O---K   072   065   000    -    28 (Min/Max 25/28)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    23
193 Load_Cycle_Count        -O--CK   100   100   000    -    747
194 Temperature_Celsius     -O---K   028   040   000    -    28 (0 22 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
200 Multi_Zone_Error_Rate   PO---K   100   100   001    -    0
240 Head_Flying_Hours       ------   100   100   000    -    7687 (81 254 0)
241 Total_LBAs_Written      ------   100   253   000    -    223727639216
242 Total_LBAs_Read         ------   100   253   000    -    342340200957
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      8  Device Statistics Notification
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    768  Current Device Internal Status Data log
0x2f       GPL     R/O      1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS     160  Device vendor specific log
0xa2       GPL     VS   16320  Device vendor specific log
0xa4       GPL,SL  VS     160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xad       GPL     VS      16  Device vendor specific log
0xb1       GPL,SL  VS     160  Device vendor specific log
0xb4       GPL,SL  VS      16  Device vendor specific log
0xb6       GPL     VS    1920  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS       8  Device vendor specific log
0xc3       GPL,SL  VS      24  Device vendor specific log
0xc6       GPL     VS    5184  Device vendor specific log
0xc7       GPL,SL  VS       8  Device vendor specific log
0xc9       GPL,SL  VS       8  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xcd       GPL,SL  VS       1  Device vendor specific log
0xce       GPL     VS       1  Device vendor specific log
0xcf       GPL     VS     512  Device vendor specific log
0xd1       GPL     VS     656  Device vendor specific log
0xd2       GPL     VS   10256  Device vendor specific log
0xd4       GPL     VS    2048  Device vendor specific log
0xda       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%      7730         -
# 2  Short offline       Completed without error       00%      7679         -
# 3  Short offline       Completed without error       00%      7511         -
# 4  Short offline       Completed without error       00%      7343         -
# 5  Short offline       Completed without error       00%      7175         -
# 6  Extended offline    Completed without error       00%      7011         -
# 7  Short offline       Completed without error       00%      6839         -
# 8  Short offline       Completed without error       00%      6671         -
# 9  Short offline       Completed without error       00%      6503         -
#10  Short offline       Completed without error       00%      6335         -
#11  Extended offline    Completed without error       00%      6267         -
#12  Short offline       Completed without error       00%      6168         -
#13  Short offline       Completed without error       00%      6000         -
#14  Short offline       Completed without error       00%      5832         -
#15  Short offline       Completed without error       00%      5664         -
#16  Extended offline    Completed without error       00%      5548         -
#17  Short offline       Completed without error       00%      5496         -
#18  Short offline       Completed without error       00%      5328         -
#19  Short offline       Completed without error       00%      5160         -
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    28 Celsius
Power Cycle Min/Max Temperature:     25/28 Celsius
Lifetime    Min/Max Temperature:     21/55 Celsius
Under/Over Temperature Limit Count:   0/0
SMART Status:                        0xc24f (PASSED)
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         4 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    128 (34)
Index    Estimated Time   Temperature Celsius
  35    2025-07-04 05:09    32  *************
  36    2025-07-04 06:08    33  **************
 ...    ..(  5 skipped).    ..  **************
  42    2025-07-04 12:02    33  **************
  43    2025-07-04 13:01    32  *************
 ...    ..(  2 skipped).    ..  *************
  46    2025-07-04 15:58    32  *************
  47    2025-07-04 16:57    31  ************
  48    2025-07-04 17:56    29  **********
  49    2025-07-04 18:55    28  *********
  50    2025-07-04 19:54    27  ********
  51    2025-07-04 20:53    27  ********
  52    2025-07-04 21:52    27  ********
  53    2025-07-04 22:51    28  *********
  54    2025-07-04 23:50    28  *********
  55    2025-07-05 00:49    29  **********
  56    2025-07-05 01:48    29  **********
  57    2025-07-05 02:47    29  **********
  58    2025-07-05 03:46    30  ***********
  59    2025-07-05 04:45    30  ***********
  60    2025-07-05 05:44    29  **********
  61    2025-07-05 06:43    28  *********
  62    2025-07-05 07:42    29  **********
 ...    ..(  3 skipped).    ..  **********
  66    2025-07-05 11:38    29  **********
  67    2025-07-05 12:37    30  ***********
 ...    ..(  4 skipped).    ..  ***********
  72    2025-07-05 17:32    30  ***********
  73    2025-07-05 18:31    29  **********
 ...    ..(  8 skipped).    ..  **********
  82    2025-07-06 03:22    29  **********
  83    2025-07-06 04:21    30  ***********
  84    2025-07-06 05:20    30  ***********
  85    2025-07-06 06:19    30  ***********
  86    2025-07-06 07:18    29  **********
  87    2025-07-06 08:17    28  *********
  88    2025-07-06 09:16    29  **********
  89    2025-07-06 10:15    32  *************
  90    2025-07-06 11:14    32  *************
  91    2025-07-06 12:13    33  **************
 ...    ..(  7 skipped).    ..  **************
  99    2025-07-06 20:05    33  **************
 100    2025-07-06 21:04    30  ***********
 101    2025-07-06 22:03    29  **********
 102    2025-07-06 23:02    29  **********
 103    2025-07-07 00:01    30  ***********
 104    2025-07-07 01:00     ?  -
 105    2025-07-07 01:59    30  ***********
 106    2025-07-07 02:58    29  **********
 107    2025-07-07 03:57    30  ***********
 ...    ..( 17 skipped).    ..  ***********
 125    2025-07-07 21:39    30  ***********
 126    2025-07-07 22:38    29  **********
 127    2025-07-07 23:37    29  **********
   0    2025-07-08 00:36     ?  -
   1    2025-07-08 01:35    28  *********
   2    2025-07-08 02:34     ?  -
   3    2025-07-08 03:33    24  *****
   4    2025-07-08 04:32     ?  -
   5    2025-07-08 05:31    23  ****
   6    2025-07-08 06:30     ?  -
   7    2025-07-08 07:29    22  ***
   8    2025-07-08 08:28    26  *******
   9    2025-07-08 09:27    26  *******
  10    2025-07-08 10:26     ?  -
  11    2025-07-08 11:25    27  ********
  12    2025-07-08 12:24     ?  -
  13    2025-07-08 13:23    23  ****
  14    2025-07-08 14:22     ?  -
  15    2025-07-08 15:21    25  ******
  16    2025-07-08 16:20     ?  -
  17    2025-07-08 17:19    31  ************
  18    2025-07-08 18:18     ?  -
  19    2025-07-08 19:17    34  ***************
  20    2025-07-08 20:16     ?  -
  21    2025-07-08 21:15    25  ******
  22    2025-07-08 22:14     ?  -
  23    2025-07-08 23:13    25  ******
  24    2025-07-09 00:12    28  *********
  25    2025-07-09 01:11     ?  -
  26    2025-07-09 02:10    28  *********
  27    2025-07-09 03:09     ?  -
  28    2025-07-09 04:08    28  *********
  29    2025-07-09 05:07    29  **********
  30    2025-07-09 06:06    28  *********
  31    2025-07-09 07:05     ?  -
  32    2025-07-09 08:04    22  ***
  33    2025-07-09 09:03     ?  -
  34    2025-07-09 10:02    25  ******
SCT Error Recovery Control:
           Read:    100 (10.0 seconds)
          Write:    100 (10.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              66  ---  Lifetime Power-On Resets
0x01  0x010  4            7840  ---  Power-on Hours
0x01  0x018  6    223725686520  ---  Logical Sectors Written
0x01  0x020  6       923591166  ---  Number of Write Commands
0x01  0x028  6    342309406747  ---  Logical Sectors Read
0x01  0x030  6      1339895357  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4            7718  ---  Spindle Motor Power-on Hours
0x03  0x010  4            7683  ---  Head Flying Hours
0x03  0x018  4             748  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              23  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              45  ---  Resets Between Cmd Acceptance and Completion
0x04  0x018  4               0  -D-  Physical Element Status Changed
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              28  ---  Current Temperature
0x05  0x010  1              29  ---  Average Short Term Temperature
0x05  0x018  1              28  ---  Average Long Term Temperature
0x05  0x020  1              35  ---  Highest Temperature
0x05  0x028  1              22  ---  Lowest Temperature
0x05  0x030  1              32  ---  Highest Average Short Term Temperature
0x05  0x038  1              24  ---  Lowest Average Short Term Temperature
0x05  0x040  1              29  ---  Highest Average Long Term Temperature
0x05  0x048  1              26  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             138  ---  Number of Hardware Resets
0x06  0x010  4              81  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x010  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
smartctl -x -v 1,hex48 -v 7,hex48 -v 188,raw16 /dev/da1
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1688) minutes.
  1 Raw_Read_Error_Rate     POSR--   079   064   044    -    0x000004a8b650
  4 Start_Stop_Count        -O--CK   100   100   020    -    67
  7 Seek_Error_Rate         POSR--   086   060   045    -    0x000015f898bd
 12 Power_Cycle_Count       -O--CK   100   100   020    -    67
188 Command_Timeout         -O--CK   100   091   000    -    1 1 34
192 Power-Off_Retract_Count -O--CK   100   100   000    -    22
193 Load_Cycle_Count        -O--CK   100   100   000    -    768
194 Temperature_Celsius     -O---K   028   040   000    -    28 (0 21 0 0 0)
240 Head_Flying_Hours       ------   100   100   000    -    7682 (165 67 0)
241 Total_LBAs_Written      ------   100   253   000    -    223707917000
242 Total_LBAs_Read         ------   100   253   000    -    344071662995
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 6  Extended offline    Completed without error       00%      7010         -
#16  Extended offline    Completed without error       00%      5547         -
Power Cycle Min/Max Temperature:     24/28 Celsius
Vendor specific:
Temperature History Size (Index):    128 (35)
  36    2025-07-04 05:09    32  *************
  37    2025-07-04 06:08    32  *************
  38    2025-07-04 07:07    33  **************
 ...    ..(  4 skipped).    ..  **************
  43    2025-07-04 12:02    33  **************
  44    2025-07-04 13:01    32  *************
  45    2025-07-04 14:00    32  *************
  46    2025-07-04 14:59    31  ************
  47    2025-07-04 15:58    31  ************
  48    2025-07-04 16:57    29  **********
  49    2025-07-04 17:56    29  **********
  50    2025-07-04 18:55    27  ********
  51    2025-07-04 19:54    26  *******
  52    2025-07-04 20:53    26  *******
  53    2025-07-04 21:52    27  ********
  54    2025-07-04 22:51    27  ********
  55    2025-07-04 23:50    28  *********
  56    2025-07-05 00:49    28  *********
  57    2025-07-05 01:48    29  **********
  60    2025-07-05 04:45    29  **********
  61    2025-07-05 05:44    28  *********
  65    2025-07-05 09:40    28  *********
  66    2025-07-05 10:39    29  **********
  67    2025-07-05 11:38    29  **********
  68    2025-07-05 12:37    29  **********
  69    2025-07-05 13:36    30  ***********
  70    2025-07-05 14:35    30  ***********
  71    2025-07-05 15:34    29  **********
  76    2025-07-05 20:29    29  **********
  77    2025-07-05 21:28    28  *********
  78    2025-07-05 22:27    28  *********
  79    2025-07-05 23:26    28  *********
  80    2025-07-06 00:25    29  **********
  84    2025-07-06 04:21    29  **********
  85    2025-07-06 05:20    30  ***********
  86    2025-07-06 06:19    29  **********
  87    2025-07-06 07:18    29  **********
  88    2025-07-06 08:17    28  *********
  89    2025-07-06 09:16    28  *********
  90    2025-07-06 10:15    32  *************
  91    2025-07-06 11:14    31  ************
  92    2025-07-06 12:13    33  **************
 ...    ..(  2 skipped).    ..  **************
  95    2025-07-06 15:10    33  **************
  96    2025-07-06 16:09    32  *************
 ...    ..(  3 skipped).    ..  *************
 100    2025-07-06 20:05    32  *************
 101    2025-07-06 21:04    30  ***********
 102    2025-07-06 22:03    29  **********
 103    2025-07-06 23:02    29  **********
 104    2025-07-07 00:01    29  **********
 105    2025-07-07 01:00     ?  -
 106    2025-07-07 01:59    29  **********
 ...    ..( 21 skipped).    ..  **********
   0    2025-07-07 23:37    29  **********
   1    2025-07-08 00:36     ?  -
   2    2025-07-08 01:35    28  *********
   3    2025-07-08 02:34     ?  -
   4    2025-07-08 03:33    24  *****
   5    2025-07-08 04:32     ?  -
   6    2025-07-08 05:31    22  ***
   7    2025-07-08 06:30     ?  -
   8    2025-07-08 07:29    21  **
   9    2025-07-08 08:28    26  *******
  10    2025-07-08 09:27    26  *******
  11    2025-07-08 10:26     ?  -
  12    2025-07-08 11:25    27  ********
  13    2025-07-08 12:24     ?  -
  14    2025-07-08 13:23    23  ****
  15    2025-07-08 14:22     ?  -
  16    2025-07-08 15:21    25  ******
  17    2025-07-08 16:20     ?  -
  18    2025-07-08 17:19    30  ***********
  19    2025-07-08 18:18     ?  -
  20    2025-07-08 19:17    34  ***************
  21    2025-07-08 20:16     ?  -
  22    2025-07-08 21:15    24  *****
  23    2025-07-08 22:14     ?  -
  24    2025-07-08 23:13    25  ******
  25    2025-07-09 00:12    28  *********
  26    2025-07-09 01:11     ?  -
  27    2025-07-09 02:10    28  *********
  28    2025-07-09 03:09     ?  -
  29    2025-07-09 04:08    28  *********
  30    2025-07-09 05:07    29  **********
  31    2025-07-09 06:06    28  *********
  32    2025-07-09 07:05     ?  -
  33    2025-07-09 08:04    21  **
  34    2025-07-09 09:03     ?  -
  35    2025-07-09 10:02    24  *****
0x01  0x008  4              67  ---  Lifetime Power-On Resets
0x01  0x018  6    223705944736  ---  Logical Sectors Written
0x01  0x020  6       922738398  ---  Number of Write Commands
0x01  0x028  6    344066480562  ---  Logical Sectors Read
0x01  0x030  6      1346997275  ---  Number of Read Commands
0x03  0x010  4            7678  ---  Head Flying Hours
0x03  0x018  4             769  ---  Head Load Events
0x03  0x040  4              22  ---  Number of High Priority Unload Events
0x04  0x010  4              34  ---  Resets Between Cmd Acceptance and Completion
0x05  0x020  1              34  ---  Highest Temperature
0x05  0x040  1              28  ---  Highest Average Long Term Temperature
0x05  0x048  1              25  ---  Lowest Average Long Term Temperature
0x06  0x008  4             195  ---  Number of Hardware Resets
                                ||__ D supports DSN
No Defects Logged
smartctl -x -v 1,hex48 -v 7,hex48 -v 188,raw16 /dev/da2
Local Time is:    Wed Jul  9 10:25:32 2025 PDT
                                        been run.
data collection:                (  575) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        (1817) minutes.
  1 Raw_Read_Error_Rate     POSR--   081   064   044    -    0x000007619c78
  7 Seek_Error_Rate         POSR--   086   061   045    -    0x00001771b139
  9 Power_On_Hours          -O--CK   092   092   000    -    7844
188 Command_Timeout         -O--CK   100   096   000    -    1 1 29
190 Airflow_Temperature_Cel -O---K   072   055   000    -    28 (Min/Max 25/28)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    24
193 Load_Cycle_Count        -O--CK   100   100   000    -    722
194 Temperature_Celsius     -O---K   028   045   000    -    28 (0 21 0 0 0)
240 Head_Flying_Hours       ------   100   100   000    -    7704 (86 2 0)
241 Total_LBAs_Written      ------   100   253   000    -    223981869765
242 Total_LBAs_Read         ------   100   253   000    -    342950280682
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%      7736         -
# 2  Short offline       Completed without error       00%      7684         -
# 3  Short offline       Completed without error       00%      7516         -
# 4  Short offline       Completed without error       00%      7348         -
# 5  Short offline       Completed without error       00%      7180         -
# 6  Extended offline    Completed without error       00%      7017         -
# 7  Short offline       Completed without error       00%      6844         -
# 8  Short offline       Completed without error       00%      6676         -
# 9  Short offline       Completed without error       00%      6508         -
#10  Short offline       Completed without error       00%      6340         -
#11  Extended offline    Completed without error       00%      6273         -
#12  Short offline       Completed without error       00%      6173         -
#13  Short offline       Completed without error       00%      6005         -
#14  Short offline       Completed without error       00%      5837         -
#15  Short offline       Completed without error       00%      5669         -
#16  Extended offline    Completed without error       00%      5554         -
#17  Short offline       Completed without error       00%      5501         -
#18  Short offline       Completed without error       00%      5333         -
#19  Short offline       Completed without error       00%      5165         -
Vendor specific:
Temperature History Size (Index):    128 (40)
  41    2025-07-04 05:09    33  **************
  42    2025-07-04 06:08    33  **************
  43    2025-07-04 07:07    33  **************
  44    2025-07-04 08:06    34  ***************
 ...    ..(  3 skipped).    ..  ***************
  48    2025-07-04 12:02    34  ***************
  49    2025-07-04 13:01    33  **************
  50    2025-07-04 14:00    32  *************
  53    2025-07-04 16:57    32  *************
  54    2025-07-04 17:56    31  ************
  55    2025-07-04 18:55    28  *********
  56    2025-07-04 19:54    27  ********
  57    2025-07-04 20:53    27  ********
  58    2025-07-04 21:52    27  ********
  59    2025-07-04 22:51    28  *********
  60    2025-07-04 23:50    29  **********
  61    2025-07-05 00:49    29  **********
  62    2025-07-05 01:48    29  **********
  63    2025-07-05 02:47    30  ***********
  64    2025-07-05 03:46    30  ***********
  65    2025-07-05 04:45    30  ***********
  66    2025-07-05 05:44    29  **********
  71    2025-07-05 10:39    29  **********
  72    2025-07-05 11:38    30  ***********
  73    2025-07-05 12:37    30  ***********
  74    2025-07-05 13:36    31  ************
  75    2025-07-05 14:35    30  ***********
  79    2025-07-05 18:31    30  ***********
  80    2025-07-05 19:30    29  **********
  86    2025-07-06 01:24    29  **********
  87    2025-07-06 02:23    30  ***********
  91    2025-07-06 06:19    30  ***********
  92    2025-07-06 07:18    29  **********
  93    2025-07-06 08:17    29  **********
  94    2025-07-06 09:16    29  **********
  95    2025-07-06 10:15    32  *************
  96    2025-07-06 11:14    32  *************
  97    2025-07-06 12:13    33  **************
 105    2025-07-06 20:05    33  **************
 106    2025-07-06 21:04    32  *************
 107    2025-07-06 22:03    29  **********
 108    2025-07-06 23:02    29  **********
 109    2025-07-07 00:01    30  ***********
 110    2025-07-07 01:00     ?  -
 111    2025-07-07 01:59    30  ***********
 ...    ..( 21 skipped).    ..  ***********
   5    2025-07-07 23:37    30  ***********
   6    2025-07-08 00:36     ?  -
   7    2025-07-08 01:35    28  *********
   8    2025-07-08 02:34     ?  -
   9    2025-07-08 03:33    24  *****
  10    2025-07-08 04:32     ?  -
  11    2025-07-08 05:31    22  ***
  12    2025-07-08 06:30     ?  -
  13    2025-07-08 07:29    21  **
  14    2025-07-08 08:28    26  *******
  15    2025-07-08 09:27    26  *******
  16    2025-07-08 10:26     ?  -
  17    2025-07-08 11:25    27  ********
  18    2025-07-08 12:24     ?  -
  19    2025-07-08 13:23    23  ****
  20    2025-07-08 14:22     ?  -
  21    2025-07-08 15:21    25  ******
  22    2025-07-08 16:20     ?  -
  23    2025-07-08 17:19    30  ***********
  24    2025-07-08 18:18     ?  -
  25    2025-07-08 19:17    34  ***************
  26    2025-07-08 20:16     ?  -
  27    2025-07-08 21:15    24  *****
  28    2025-07-08 22:14     ?  -
  29    2025-07-08 23:13    25  ******
  30    2025-07-09 00:12    28  *********
  31    2025-07-09 01:11     ?  -
  32    2025-07-09 02:10    28  *********
  33    2025-07-09 03:09     ?  -
  34    2025-07-09 04:08    28  *********
  35    2025-07-09 05:07    29  **********
  36    2025-07-09 06:06    29  **********
  37    2025-07-09 07:05     ?  -
  38    2025-07-09 08:04    22  ***
  39    2025-07-09 09:03     ?  -
  40    2025-07-09 10:02    25  ******
0x01  0x010  4            7844  ---  Power-on Hours
0x01  0x018  6    223979844589  ---  Logical Sectors Written
0x01  0x020  6       928795558  ---  Number of Write Commands
0x01  0x028  6    342914557735  ---  Logical Sectors Read
0x01  0x030  6      1323152679  ---  Number of Read Commands
0x03  0x008  4            7722  ---  Spindle Motor Power-on Hours
0x03  0x010  4            7699  ---  Head Flying Hours
0x03  0x018  4             723  ---  Head Load Events
0x03  0x040  4              24  ---  Number of High Priority Unload Events
0x04  0x010  4              27  ---  Resets Between Cmd Acceptance and Completion
0x05  0x020  1              45  ---  Highest Temperature
0x05  0x030  1              34  ---  Highest Average Short Term Temperature
0x05  0x038  1              25  ---  Lowest Average Short Term Temperature
0x06  0x008  4             192  ---  Number of Hardware Resets
0x06  0x010  4              83  ---  Number of ASR Events
                                ||__ D supports DSN
No Defects Logged
SMART DA3
Local Time is:    Wed Jul  9 10:25:33 2025 PDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1808) minutes.
  1 Raw_Read_Error_Rate     POSR--   080   064   044    -    0x000005f00faa
  7 Seek_Error_Rate         POSR--   086   060   045    -    0x00001721f88c
188 Command_Timeout         -O--CK   100   089   000    -    0 0 41
190 Airflow_Temperature_Cel -O---K   072   066   000    -    28 (Min/Max 25/28)
193 Load_Cycle_Count        -O--CK   100   100   000    -    718
240 Head_Flying_Hours       ------   100   100   000    -    7697 (52 19 0)
241 Total_LBAs_Written      ------   100   253   000    -    223954162552
242 Total_LBAs_Read         ------   100   253   000    -    336588416644
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%      7732         -
# 6  Extended offline    Completed without error       00%      7012         -
#11  Extended offline    Completed without error       00%      6269         -
#16  Extended offline    Completed without error       00%      5549         -
Current Temperature:                    27 Celsius
Vendor specific:
 ...    ..(  6 skipped).    ..  *************
  43    2025-07-04 12:02    32  *************
  44    2025-07-04 13:01    31  ************
  48    2025-07-04 16:57    30  ***********
  49    2025-07-04 17:56    30  ***********
  53    2025-07-04 21:52    26  *******
  57    2025-07-05 01:48    28  *********
  58    2025-07-05 02:47    29  **********
  59    2025-07-05 03:46    29  **********
  66    2025-07-05 10:39    28  *********
  74    2025-07-05 18:31    29  **********
  75    2025-07-05 19:30    28  *********
  80    2025-07-06 00:25    28  *********
  81    2025-07-06 01:24    29  **********
  87    2025-07-06 07:18    28  *********
  90    2025-07-06 10:15    31  ************
  92    2025-07-06 12:13    32  *************
 101    2025-07-06 21:04    31  ************
 102    2025-07-06 22:03    28  *********
 103    2025-07-06 23:02    28  *********
  16    2025-07-08 15:21    24  *****
  18    2025-07-08 17:19    29  **********
  20    2025-07-08 19:17    32  *************
  22    2025-07-08 21:15    23  ****
  24    2025-07-08 23:13    24  *****
  25    2025-07-09 00:12    27  ********
  33    2025-07-09 08:04    22  ***
0x01  0x018  6    223952162024  ---  Logical Sectors Written
0x01  0x020  6       928604901  ---  Number of Write Commands
0x01  0x028  6    336553031204  ---  Logical Sectors Read
0x01  0x030  6      1317328588  ---  Number of Read Commands
0x03  0x010  4            7693  ---  Head Flying Hours
0x03  0x018  4             719  ---  Head Load Events
0x04  0x010  4              41  ---  Resets Between Cmd Acceptance and Completion
0x05  0x008  1              27  ---  Current Temperature
0x05  0x018  1              27  ---  Average Long Term Temperature
0x05  0x028  1              21  ---  Lowest Temperature
0x06  0x008  4             200  ---  Number of Hardware Resets
0x06  0x010  4              80  ---  Number of ASR Events
                                ||__ D supports DSN
No Defects Logged
SMART da4
                                        been run.
data collection:                (  559) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        (1686) minutes.
  1 Raw_Read_Error_Rate     POSR--   084   064   044    -    0x00000e5ee279
  7 Seek_Error_Rate         POSR--   086   061   045    -    0x000016214c80
188 Command_Timeout         -O--CK   100   092   000    -    1 1 44
190 Airflow_Temperature_Cel -O---K   071   050   000    -    29 (Min/Max 25/29)
193 Load_Cycle_Count        -O--CK   100   100   000    -    763
194 Temperature_Celsius     -O---K   029   050   000    -    29 (0 22 0 0 0)
240 Head_Flying_Hours       ------   100   100   000    -    7685 (249 247 0)
241 Total_LBAs_Written      ------   100   253   000    -    223774976675
242 Total_LBAs_Read         ------   100   253   000    -    350693942205
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%      7734         -
# 2  Short offline       Completed without error       00%      7683         -
# 3  Short offline       Completed without error       00%      7515         -
# 4  Short offline       Completed without error       00%      7347         -
# 5  Short offline       Completed without error       00%      7179         -
# 6  Extended offline    Completed without error       00%      7015         -
# 8  Short offline       Completed without error       00%      6675         -
# 9  Short offline       Completed without error       00%      6507         -
#10  Short offline       Completed without error       00%      6339         -
#11  Extended offline    Completed without error       00%      6271         -
#16  Extended offline    Completed without error       00%      5552         -
#19  Short offline       Completed without error       00%      5164         -
Current Temperature:                    29 Celsius
Power Cycle Min/Max Temperature:     25/29 Celsius
Lifetime    Min/Max Temperature:     22/55 Celsius
Vendor specific:
Temperature History Size (Index):    128 (39)
  40    2025-07-04 05:09    34  ***************
  41    2025-07-04 06:08    34  ***************
  42    2025-07-04 07:07    34  ***************
  43    2025-07-04 08:06    35  ****************
 ...    ..(  3 skipped).    ..  ****************
  47    2025-07-04 12:02    35  ****************
  48    2025-07-04 13:01    34  ***************
  49    2025-07-04 14:00    34  ***************
  50    2025-07-04 14:59    33  **************
  51    2025-07-04 15:58    34  ***************
  52    2025-07-04 16:57    31  ************
  53    2025-07-04 17:56    30  ***********
  54    2025-07-04 18:55    29  **********
  55    2025-07-04 19:54    28  *********
  56    2025-07-04 20:53    28  *********
  57    2025-07-04 21:52    29  **********
  58    2025-07-04 22:51    29  **********
  59    2025-07-04 23:50    30  ***********
  60    2025-07-05 00:49    30  ***********
  61    2025-07-05 01:48    30  ***********
  62    2025-07-05 02:47    31  ************
  63    2025-07-05 03:46    31  ************
  64    2025-07-05 04:45    31  ************
  65    2025-07-05 05:44    30  ***********
  66    2025-07-05 06:43    30  ***********
  67    2025-07-05 07:42    30  ***********
  68    2025-07-05 08:41    31  ************
  69    2025-07-05 09:40    30  ***********
  70    2025-07-05 10:39    31  ************
  71    2025-07-05 11:38    31  ************
  72    2025-07-05 12:37    31  ************
  73    2025-07-05 13:36    32  *************
  74    2025-07-05 14:35    31  ************
  79    2025-07-05 19:30    31  ************
  80    2025-07-05 20:29    30  ***********
  84    2025-07-06 00:25    30  ***********
  85    2025-07-06 01:24    31  ************
  91    2025-07-06 07:18    31  ************
  92    2025-07-06 08:17    30  ***********
  93    2025-07-06 09:16    30  ***********
  94    2025-07-06 10:15    34  ***************
  95    2025-07-06 11:14    34  ***************
  96    2025-07-06 12:13    35  ****************
 ...    ..(  5 skipped).    ..  ****************
 102    2025-07-06 18:07    35  ****************
 103    2025-07-06 19:06    34  ***************
 104    2025-07-06 20:05    35  ****************
 105    2025-07-06 21:04    32  *************
 106    2025-07-06 22:03    31  ************
 107    2025-07-06 23:02    31  ************
 108    2025-07-07 00:01    31  ************
 109    2025-07-07 01:00     ?  -
 110    2025-07-07 01:59    31  ************
 ...    ..( 21 skipped).    ..  ************
   4    2025-07-07 23:37    31  ************
   5    2025-07-08 00:36     ?  -
   6    2025-07-08 01:35    30  ***********
   7    2025-07-08 02:34     ?  -
   8    2025-07-08 03:33    24  *****
   9    2025-07-08 04:32     ?  -
  10    2025-07-08 05:31    23  ****
  11    2025-07-08 06:30     ?  -
  12    2025-07-08 07:29    22  ***
  13    2025-07-08 08:28    27  ********
  14    2025-07-08 09:27    27  ********
  15    2025-07-08 10:26     ?  -
  16    2025-07-08 11:25    28  *********
  17    2025-07-08 12:24     ?  -
  18    2025-07-08 13:23    23  ****
  19    2025-07-08 14:22     ?  -
  20    2025-07-08 15:21    25  ******
  21    2025-07-08 16:20     ?  -
  22    2025-07-08 17:19    31  ************
  23    2025-07-08 18:18     ?  -
  24    2025-07-08 19:17    34  ***************
  25    2025-07-08 20:16     ?  -
  26    2025-07-08 21:15    25  ******
  27    2025-07-08 22:14     ?  -
  28    2025-07-08 23:13    25  ******
  29    2025-07-09 00:12    29  **********
  30    2025-07-09 01:11     ?  -
  31    2025-07-09 02:10    29  **********
  32    2025-07-09 03:09     ?  -
  33    2025-07-09 04:08    29  **********
  34    2025-07-09 05:07    30  ***********
  35    2025-07-09 06:06    29  **********
  36    2025-07-09 07:05     ?  -
  37    2025-07-09 08:04    22  ***
  38    2025-07-09 09:03     ?  -
  39    2025-07-09 10:02    25  ******
0x01  0x018  6    223772836627  ---  Logical Sectors Written
0x01  0x020  6       923951763  ---  Number of Write Commands
0x01  0x028  6    350687173359  ---  Logical Sectors Read
0x01  0x030  6      1354070935  ---  Number of Read Commands
0x03  0x010  4            7681  ---  Head Flying Hours
0x03  0x018  4             763  ---  Head Load Events
0x04  0x010  4              44  ---  Resets Between Cmd Acceptance and Completion
0x05  0x008  1              29  ---  Current Temperature
0x05  0x010  1              30  ---  Average Short Term Temperature
0x05  0x018  1              29  ---  Average Long Term Temperature
0x05  0x020  1              50  ---  Highest Temperature
0x05  0x028  1              23  ---  Lowest Temperature
0x05  0x030  1              33  ---  Highest Average Short Term Temperature
0x05  0x038  1              26  ---  Lowest Average Short Term Temperature
0x05  0x048  1              27  ---  Lowest Average Long Term Temperature
0x06  0x008  4             209  ---  Number of Hardware Resets
0x06  0x010  4              84  ---  Number of ASR Events
0xff  0x010  7               1  ---  Vendor Specific
                                ||__ D supports DSN
No Defects Logged
SMART da5
Local Time is:    Wed Jul  9 10:25:34 2025 PDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1704) minutes.
  1 Raw_Read_Error_Rate     POSR--   072   064   044    -    0x000000fecfa8
  7 Seek_Error_Rate         POSR--   086   061   045    -    0x0000163d4dc0
188 Command_Timeout         -O--CK   100   092   000    -    0 0 36
193 Load_Cycle_Count        -O--CK   100   100   000    -    767
240 Head_Flying_Hours       ------   100   100   000    -    7688 (127 193 0)
241 Total_LBAs_Written      ------   100   253   000    -    223745524307
242 Total_LBAs_Read         ------   100   253   000    -    350003473299
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Vendor specific:
  42    2025-07-04 06:08    34  ***************
  52    2025-07-04 15:58    33  **************
  53    2025-07-04 16:57    30  ***********
  54    2025-07-04 17:56    30  ***********
  55    2025-07-04 18:55    29  **********
  56    2025-07-04 19:54    28  *********
  57    2025-07-04 20:53    28  *********
  58    2025-07-04 21:52    28  *********
  59    2025-07-04 22:51    29  **********
  61    2025-07-05 00:49    30  ***********
  62    2025-07-05 01:48    30  ***********
  64    2025-07-05 03:46    31  ************
  65    2025-07-05 04:45    31  ************
  66    2025-07-05 05:44    30  ***********
  67    2025-07-05 06:43    29  **********
  68    2025-07-05 07:42    30  ***********
  73    2025-07-05 12:37    31  ************
  78    2025-07-05 17:32    31  ************
 ...    ..(  8 skipped).    ..  ***********
  88    2025-07-06 03:22    30  ***********
  89    2025-07-06 04:21    31  ************
  90    2025-07-06 05:20    31  ************
  91    2025-07-06 06:19    31  ************
  92    2025-07-06 07:18    30  ***********
  93    2025-07-06 08:17    30  ***********
  94    2025-07-06 09:16    30  ***********
  95    2025-07-06 10:15    33  **************
  96    2025-07-06 11:14    33  **************
  97    2025-07-06 12:13    34  ***************
 ...    ..(  7 skipped).    ..  ***************
 105    2025-07-06 20:05    34  ***************
 106    2025-07-06 21:04    31  ************
 107    2025-07-06 22:03    30  ***********
 108    2025-07-06 23:02    30  ***********
 109    2025-07-07 00:01    31  ************
 111    2025-07-07 01:59    31  ************
 112    2025-07-07 02:58    30  ***********
 113    2025-07-07 03:57    31  ************
 118    2025-07-07 08:52    31  ************
 119    2025-07-07 09:51    30  ***********
 120    2025-07-07 10:50    31  ************
 ...    ..(  9 skipped).    ..  ************
   2    2025-07-07 20:40    31  ************
   3    2025-07-07 21:39    30  ***********
   4    2025-07-07 22:38    30  ***********
   7    2025-07-08 01:35    29  **********
  11    2025-07-08 05:31    23  ****
  13    2025-07-08 07:29    22  ***
  14    2025-07-08 08:28    27  ********
  15    2025-07-08 09:27    27  ********
  17    2025-07-08 11:25    28  *********
  23    2025-07-08 17:19    31  ************
  27    2025-07-08 21:15    25  ******
  30    2025-07-09 00:12    29  **********
  32    2025-07-09 02:10    29  **********
  34    2025-07-09 04:08    29  **********
  35    2025-07-09 05:07    30  ***********
0x01  0x018  6    223743500275  ---  Logical Sectors Written
0x01  0x020  6       923064851  ---  Number of Write Commands
0x01  0x028  6    349998104153  ---  Logical Sectors Read
0x01  0x030  6      1350768784  ---  Number of Read Commands
0x03  0x010  4            7684  ---  Head Flying Hours
0x03  0x018  4             768  ---  Head Load Events
0x04  0x010  4              36  ---  Resets Between Cmd Acceptance and Completion
0x06  0x008  4             201  ---  Number of Hardware Resets
                                ||__ D supports DSN
No Defects Logged
SMART da6
Local Time is:    Wed Jul  9 10:25:35 2025 PDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1699) minutes.
  1 Raw_Read_Error_Rate     POSR--   078   064   044    -    0x0000040864e8
  7 Seek_Error_Rate         POSR--   086   061   045    -    0x00001643a6ce
190 Airflow_Temperature_Cel -O---K   072   053   000    -    28 (Min/Max 25/28)
193 Load_Cycle_Count        -O--CK   100   100   000    -    751
194 Temperature_Celsius     -O---K   028   047   000    -    28 (0 21 0 0 0)
240 Head_Flying_Hours       ------   100   100   000    -    7688 (99 6 0)
241 Total_LBAs_Written      ------   100   253   000    -    223984170671
242 Total_LBAs_Read         ------   100   253   000    -    349514169910
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Vendor specific:
  41    2025-07-04 05:09    32  *************
  48    2025-07-04 12:02    33  **************
  49    2025-07-04 13:01    32  *************
  52    2025-07-04 15:58    32  *************
  54    2025-07-04 17:56    29  **********
  60    2025-07-04 23:50    28  *********
  87    2025-07-06 02:23    29  **********
 ...    ..( 19 skipped).    ..  ***********
   4    2025-07-07 22:38    29  **********
  38    2025-07-09 08:04    21  **
0x01  0x018  6    223982212567  ---  Logical Sectors Written
0x01  0x020  6       929173850  ---  Number of Write Commands
0x01  0x028  6    349507370629  ---  Logical Sectors Read
0x01  0x030  6      1349627849  ---  Number of Read Commands
0x03  0x018  4             752  ---  Head Load Events
0x04  0x010  4              33  ---  Resets Between Cmd Acceptance and Completion
0x05  0x020  1              48  ---  Highest Temperature
0x06  0x008  4             199  ---  Number of Hardware Resets
                                ||__ D supports DSN
No Defects Logged
SMART da7
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1685) minutes.
  1 Raw_Read_Error_Rate     POSR--   070   064   044    -    0x000000a4163f
  3 Spin_Up_Time            PO----   091   091   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    53
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    1
  7 Seek_Error_Rate         POSR--   084   060   045    -    0x00000ea85d6b
  9 Power_On_Hours          -O--CK   092   092   000    -    7507
 12 Power_Cycle_Count       -O--CK   100   100   020    -    53
188 Command_Timeout         -O--CK   100   091   000    -    0 0 39
190 Airflow_Temperature_Cel -O---K   071   051   000    -    29 (Min/Max 25/29)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    18
193 Load_Cycle_Count        -O--CK   100   100   000    -    662
194 Temperature_Celsius     -O---K   029   049   000    -    29 (0 22 0 0 0)
240 Head_Flying_Hours       ------   100   100   000    -    7377 (51 224 0)
241 Total_LBAs_Written      ------   100   253   000    -    28673801006
242 Total_LBAs_Read         ------   100   253   000    -    153629134112
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%      7397         -
# 2  Short offline       Completed without error       00%      7346         -
# 3  Short offline       Completed without error       00%      7178         -
# 4  Short offline       Completed without error       00%      7010         -
# 5  Short offline       Completed without error       00%      6842         -
# 6  Extended offline    Completed without error       00%      6678         -
# 7  Short offline       Completed without error       00%      6507         -
# 8  Short offline       Completed without error       00%      6339         -
# 9  Short offline       Completed without error       00%      6171         -
#10  Short offline       Completed without error       00%      6003         -
#11  Extended offline    Completed without error       00%      5934         -
#12  Short offline       Completed without error       00%      5836         -
#13  Short offline       Completed without error       00%      5668         -
#14  Short offline       Completed without error       00%      5500         -
#15  Short offline       Completed without error       00%      5332         -
#16  Extended offline    Completed without error       00%      5215         -
#17  Short offline       Completed without error       00%      5164         -
#18  Short offline       Completed without error       00%      4996         -
#19  Short offline       Completed without error       00%      4828         -
Lifetime    Min/Max Temperature:     22/52 Celsius
Vendor specific:
Temperature History Size (Index):    128 (57)
  58    2025-07-04 05:09    35  ****************
  59    2025-07-04 06:08    35  ****************
  60    2025-07-04 07:07    36  *****************
 ...    ..(  4 skipped).    ..  *****************
  65    2025-07-04 12:02    36  *****************
  66    2025-07-04 13:01    35  ****************
  67    2025-07-04 14:00    35  ****************
  68    2025-07-04 14:59    34  ***************
  69    2025-07-04 15:58    35  ****************
  70    2025-07-04 16:57    32  *************
  71    2025-07-04 17:56    31  ************
  72    2025-07-04 18:55    30  ***********
  73    2025-07-04 19:54    29  **********
  74    2025-07-04 20:53    29  **********
  75    2025-07-04 21:52    29  **********
  76    2025-07-04 22:51    30  ***********
  77    2025-07-04 23:50    31  ************
  78    2025-07-05 00:49    31  ************
  79    2025-07-05 01:48    31  ************
  80    2025-07-05 02:47    32  *************
  81    2025-07-05 03:46    32  *************
  82    2025-07-05 04:45    32  *************
  83    2025-07-05 05:44    31  ************
  87    2025-07-05 09:40    31  ************
  88    2025-07-05 10:39    32  *************
  89    2025-07-05 11:38    32  *************
  90    2025-07-05 12:37    32  *************
  91    2025-07-05 13:36    33  **************
  92    2025-07-05 14:35    32  *************
  97    2025-07-05 19:30    32  *************
  98    2025-07-05 20:29    31  ************
 102    2025-07-06 00:25    31  ************
 103    2025-07-06 01:24    32  *************
 109    2025-07-06 07:18    32  *************
 110    2025-07-06 08:17    31  ************
 111    2025-07-06 09:16    31  ************
 112    2025-07-06 10:15    35  ****************
 113    2025-07-06 11:14    35  ****************
 114    2025-07-06 12:13    36  *****************
 ...    ..(  7 skipped).    ..  *****************
 122    2025-07-06 20:05    36  *****************
 123    2025-07-06 21:04    35  ****************
 124    2025-07-06 22:03    32  *************
 125    2025-07-06 23:02    32  *************
 126    2025-07-07 00:01    32  *************
 127    2025-07-07 01:00     ?  -
   0    2025-07-07 01:59    32  *************
   1    2025-07-07 02:58    33  **************
   2    2025-07-07 03:57    32  *************
 ...    ..( 19 skipped).    ..  *************
  22    2025-07-07 23:37    32  *************
  23    2025-07-08 00:36     ?  -
  24    2025-07-08 01:35    30  ***********
  25    2025-07-08 02:34     ?  -
  26    2025-07-08 03:33    24  *****
  27    2025-07-08 04:32     ?  -
  28    2025-07-08 05:31    23  ****
  29    2025-07-08 06:30     ?  -
  30    2025-07-08 07:29    22  ***
  31    2025-07-08 08:28    28  *********
  32    2025-07-08 09:27    28  *********
  33    2025-07-08 10:26     ?  -
  34    2025-07-08 11:25    29  **********
  35    2025-07-08 12:24     ?  -
  36    2025-07-08 13:23    23  ****
  37    2025-07-08 14:22     ?  -
  38    2025-07-08 15:21    25  ******
  39    2025-07-08 16:20     ?  -
  40    2025-07-08 17:19    30  ***********
  41    2025-07-08 18:18     ?  -
  42    2025-07-08 19:17    33  **************
  43    2025-07-08 20:16     ?  -
  44    2025-07-08 21:15    24  *****
  45    2025-07-08 22:14     ?  -
  46    2025-07-08 23:13    25  ******
  47    2025-07-09 00:12    29  **********
  48    2025-07-09 01:11     ?  -
  49    2025-07-09 02:10    29  **********
  50    2025-07-09 03:09     ?  -
  51    2025-07-09 04:08    29  **********
  52    2025-07-09 05:07    30  ***********
  53    2025-07-09 06:06    30  ***********
  54    2025-07-09 07:05     ?  -
  55    2025-07-09 08:04    22  ***
  56    2025-07-09 09:03     ?  -
  57    2025-07-09 10:02    25  ******
0x01  0x008  4              53  ---  Lifetime Power-On Resets
0x01  0x010  4            7507  ---  Power-on Hours
0x01  0x018  6     28671732590  ---  Logical Sectors Written
0x01  0x020  6       166144772  ---  Number of Write Commands
0x01  0x028  6    153624215267  ---  Logical Sectors Read
0x01  0x030  6       593408425  ---  Number of Read Commands
0x03  0x008  4            7387  ---  Spindle Motor Power-on Hours
0x03  0x010  4            7374  ---  Head Flying Hours
0x03  0x018  4             663  ---  Head Load Events
0x03  0x020  4               1  ---  Number of Reallocated Logical Sectors
0x03  0x040  4              18  ---  Number of High Priority Unload Events
0x04  0x010  4              39  ---  Resets Between Cmd Acceptance and Completion
0x05  0x010  1              31  ---  Average Short Term Temperature
0x05  0x018  1              30  ---  Average Long Term Temperature
0x05  0x028  1              25  ---  Lowest Temperature
0x05  0x030  1              35  ---  Highest Average Short Term Temperature
0x05  0x038  1              27  ---  Lowest Average Short Term Temperature
0x05  0x040  1              30  ---  Highest Average Long Term Temperature
0x06  0x008  4             181  ---  Number of Hardware Resets
0x06  0x010  4              75  ---  Number of ASR Events
                                ||__ D supports DSN
No Defects Logged
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
mpsutil show all
Adapter:
mps0 Adapter:
       Board Name: SAS9207-8i
   Board Assembly: H3-25412-00K
        Chip Name: LSISAS2308
    Chip Revision: ALL
    BIOS Revision: 7.39.02.00
Firmware Revision: 20.00.07.00
  Integrated RAID: no
         SATA NCQ: ENABLED
 PCIe Width/Speed: x4 (8.0 GB/sec)
        IOC Speed: Full
      Temperature: 72 C
PhyNum  CtlrHandle  DevHandle  Disabled  Speed   Min    Max    Device
0       0001        0009       N         6.0     1.5    6.0    SAS Initiator
1       0002        000a       N         6.0     1.5    6.0    SAS Initiator
2       0003        000b       N         6.0     1.5    6.0    SAS Initiator
3       0004        000c       N         6.0     1.5    6.0    SAS Initiator
4       0005        000d       N         6.0     1.5    6.0    SAS Initiator
5       0006        000e       N         6.0     1.5    6.0    SAS Initiator
6       0007        000f       N         6.0     1.5    6.0    SAS Initiator
7       0008        0010       N         6.0     1.5    6.0    SAS Initiator
Devices:
B____T    SAS Address      Handle  Parent    Device        Speed Enc  Slot  Wdt
00   07   4433221100000000 0009    0001      SATA Target   6.0   0001 03    1
00   04   4433221101000000 000a    0002      SATA Target   6.0   0001 02    1
00   05   4433221102000000 000b    0003      SATA Target   6.0   0001 01    1
00   06   4433221103000000 000c    0004      SATA Target   6.0   0001 00    1
00   00   4433221104000000 000d    0005      SATA Target   6.0   0001 07    1
00   01   4433221105000000 000e    0006      SATA Target   6.0   0001 06    1
00   02   4433221106000000 000f    0007      SATA Target   6.0   0001 05    1
00   03   4433221107000000 0010    0008      SATA Target   6.0   0001 04    1
Enclosures:
Slots      Logical ID     SEPHandle  EncHandle    Type
  08    500605b00e9efe90               0001     Direct Attached SGPIO
Expanders:
NumPhys   SAS Address     DevHandle   Parent  EncHandle  SAS Level
sas2flash --list
LSI Corporation SAS2 Flash Utility
Version 16.00.00.00 (2013.03.01)
Copyright (c) 2008-2013 LSI Corporation. All rights reserved
        Adapter Selected is a LSI SAS: SAS2308_2(D1)
        Controller Number              : 0
        Controller                     : SAS2308_2(D1)
        PCI Address                    : 00:2d:00:00
        SAS Address                    : 500605b-0-0e9e-fe90
        NVDATA Version (Default)       : 14.01.00.06
        NVDATA Version (Persistent)    : 14.01.00.06
        Firmware Product ID            : 0x2214 (IT)
        Firmware Version               : 20.00.07.00
        NVDATA Vendor                  : LSI
        NVDATA Product ID              : SAS9207-8i
        BIOS Version                   : 07.39.02.00
        UEFI BSD Version               : 07.27.01.00
        FCODE Version                  : N/A
        Board Name                     : SAS9207-8i
        Board Assembly                 : H3-25412-00K
        Board Tracer Number            : SP90315953
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
I’m afraid this is word salad.
Once you get to the shell, what’s the output of zpool import?
zpool import
pool: WD40
id:
state: ONLINE
the ‘-f’ flag.
see: Message ID: ZFS-8000-EY — OpenZFS documentation
    WD40                                            ONLINE
      mirror-0                                      ONLINE
      mirror-1                                      ONLINE
      mirror-2                                      ONLINE
      mirror-3                                      ONLINE
Please use formatted text </> rather than “Hide Details”.
The next command to try would be zpool import -f -R /mnt WD40
I’ll change them all from hide details to formatted output.
Console immediatly responds to zpool import -f -R /mnt WD40 with:
Solaris: WARNING: Pool 'WD40' has encountered an uncorrectable I/O failure and has been suspended
ssh session running command appears to be hung, top shows no activity.
:fearful:
We’ll need help from @HoneyBadger here… Starting with inspecting the log for this I/O error.
Wow, now that I look at it, not only was it word salad… but what I was trying to say was wrong, too. Should have been stripe of mirrored vdevs. Thanks, and corrected.
Have you run any SMART Long test since the failure occured? You can probably force a mount as read only to gain access to your data.
But first, run a long test on all your drives, ensure they appear to br healthy.
I haven’t yet. They take a long time to run on these drives, I wanted to make sure that running the long test wouldn’t interfere with any other troubleshooting before I started the test.
Edit: But, because I guess you can cancel them with smartctl -X, I just started them
Slightly toastier than I’d normally like to see - how is the cooling in the case?
After a reboot, see if it will mount RO with zpool import -f -R /mnt WD40 -o readonly=on - you can also run a second SSH session and dump the output of sysctl kstat.zfs.misc.dbgmsg to see if the tail end identifies a specific vdev or member that’s throwing a fault.
during shutdown, “some processes wouldn’t die”, so after buffers synced I reset.
The zpool mounted fine read only. dbgmsg says 0 metadata errors and 2 data errors.
zpool status -v WD40
  pool: WD40
 state: ONLINE
	corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
	entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 9M in 11:50:04 with 0 errors on Fri Jul  4 07:38:00 2025
	WD40                                            ONLINE       0     0     0
	  mirror-0                                      ONLINE       0     0     0
	    gptid/da68761c-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	    gptid/da5e23ba-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	  mirror-1                                      ONLINE       0     0     0
	    gptid/da55cad3-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	    gptid/da723071-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	  mirror-2                                      ONLINE       0     0     0
	    gptid/da7c67de-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	    gptid/da857aec-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	  mirror-3                                      ONLINE       0     0     0
	    gptid/da3edc18-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
	    gptid/da500160-4e44-11ef-954d-d45d64549e0e  ONLINE       0     0     0
        WD40/.system/rrd-ae1f6b9a44d94d15a639a40c1e91b328:/localhost/load/load.rrd
        WD40/rData:<0x38381>
So I have read only access - hurray, and thank you!
Do you have any suggestions for troubleshooting the actual I/O error? I’m guessing reboot again, try normal mount, check that debug to see if it has anything relevant.
0 metadata errors in the log is good, although I see WD40/rData:<0x38381> which would seem to indicate metadata or other corruption since it’s not calling out a file like the .system dataset file above (which could be largely ignored)
Yep, that’s where I’d go - you might be able to revert back a transaction or two with the capital -F parameter, but I’d start with trying the same regular import as before and looking at the dbgmsg output to see if it shows what’s what.
No help that I can identify from sysctl kstat.zfs.misc.dbgmsg.
1752095115   spa.c:6771:spa_tryimport(): spa_tryimport: importing WD40
1752095115   spa_misc.c:419:spa_load_note(): spa_load($import, config trusted): LOADING
1752095115   vdev.c:162:vdev_dbgmsg(): disk vdev '/dev/gptid/da68761c-4e44-11ef-954d-d45d64549e0e': best uberblock found for spa $import. txg 5172414
1752095115   spa_misc.c:419:spa_load_note(): spa_load($import, config untrusted): using uberblock with txg=5172414
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading checkpoint txg
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading indirect vdev metadata
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Checking feature flags
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading special MOS directories
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading properties
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading AUX vdevs
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading vdev metadata
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading dedup tables
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading BRT
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Verifying Log Devices
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Verifying pool data
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Calculating deflated space
1752095115   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Starting import
1752095115   spa.c:8925:spa_async_request(): spa=$import async request task=2048
1752095115   spa_misc.c:419:spa_load_note(): spa_load($import, config trusted): LOADED
1752095115   spa_misc.c:419:spa_load_note(): spa_load($import, config trusted): UNLOADING
1752095115   spa.c:6623:spa_import(): spa_import: importing WD40
1752095115   spa_misc.c:419:spa_load_note(): spa_load(WD40, config trusted): LOADING
1752095115   vdev.c:162:vdev_dbgmsg(): disk vdev '/dev/gptid/da68761c-4e44-11ef-954d-d45d64549e0e': best uberblock found for spa WD40. txg 5172414
1752095115   spa_misc.c:419:spa_load_note(): spa_load(WD40, config untrusted): using uberblock with txg=5172414
1752095123   spa_misc.c:419:spa_load_note(): spa_load(WD40, config trusted): Read 17 log space maps (17 total blocks - blksz = 131072 bytes) in 28 ms
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading dedup tables
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Loading BRT
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Verifying Log Devices
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Verifying pool data
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Calculating deflated space
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Starting import
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Claiming ZIL blocks
1752095123   mmp.c:240:mmp_thread_start(): MMP thread started pool 'WD40' gethrtime 196756656978
1752095123   spa_misc.c:2311:spa_import_progress_set_notes_impl(): 'WD40' Syncing ZIL claims
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 2, ms_id 573, smp_length 86904, unflushed_allocs 69632, unflushed_frees 733184, freed 0, defer 0 + 0, unloaded time 196756 ms, loading_time 10 ms, ms_max_size 9355919360, max size error 9355563008, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 1, ms_id 59, smp_length 27888, unflushed_allocs 237568, unflushed_frees 208896, freed 0, defer 0 + 0, unloaded time 196756 ms, loading_time 17 ms, ms_max_size 11656130560, max size error 11656085504, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 3, ms_id 64, smp_length 3608, unflushed_allocs 81920, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 196756 ms, loading_time 19 ms, ms_max_size 14224048128, max size error 14224048128, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 0, ms_id 59, smp_length 44560, unflushed_allocs 405504, unflushed_frees 335872, freed 0, defer 0 + 0, unloaded time 196756 ms, loading_time 21 ms, ms_max_size 12024918016, max size error 12024791040, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 3, ms_id 598, smp_length 146216, unflushed_allocs 344064, unflushed_frees 344064, freed 0, defer 0 + 0, unloaded time 196777 ms, loading_time 13 ms, ms_max_size 9100754944, max size error 9100689408, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 2, ms_id 595, smp_length 188304, unflushed_allocs 352256, unflushed_frees 225280, freed 0, defer 0 + 0, unloaded time 196776 ms, loading_time 33 ms, ms_max_size 9230364672, max size error 9230319616, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 2, ms_id 601, smp_length 53680, unflushed_allocs 405504, unflushed_frees 74661888, freed 0, defer 0 + 0, unloaded time 196811 ms, loading_time 23 ms, ms_max_size 9154138112, max size error 9146798080, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 1, ms_id 554, smp_length 443936, unflushed_allocs 196608, unflushed_frees 299008, freed 0, defer 0 + 0, unloaded time 196835 ms, loading_time 49 ms, ms_max_size 8705822720, max size error 8705724416, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 0, ms_id 554, smp_length 479144, unflushed_allocs 446464, unflushed_frees 327680, freed 0, defer 0 + 0, unloaded time 196885 ms, loading_time 25 ms, ms_max_size 8597098496, max size error 8597012480, old_weight 840000000000001, new_weight 840000000000001
1752095123   metaslab.c:2469:metaslab_load_impl(): metaslab_load: txg 5172415, spa WD40, vdev_id 1, ms_id 582, smp_length 272416, unflushed_allocs 200704, unflushed_frees 524288, freed 0, defer 0 + 0, unloaded time 196910 ms, loading_time 13 ms, ms_max_size 8629760000, max size error 8629473280, old_weight 840000000000001, new_weight 840000000000001
It’s entering here
And then when it tries to proceed to txg++ it’s having issues:
I see a good chunk of unflushed_frees in one line (74661888)
Riddle me this … you didn’t happen to be using deduplication at all, did you?
No deduplication. The default compression yes, but not deduplication.
That’s good then. Did it immediately throw the uncorrectable I/O failure at you when trying to import, or is it still plucking away?
