Hi there, here are some screen shots showing the configuration on NFS servers and Share permissions.
The truenas is a virtual machine.
The truenas was unresponsive 24 hours ago. The VM was rebooted.
The backup solution is called Cohesity. It connects to share paths using NFS version 4.1.
I cannot mount to any NFS shares at this stage. The request times out.
So if you are able to assist with any things I need to check.
More info…
Error: Traceback (most recent call last): File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 198, in call_method result = await self.middleware.call_with_audit(message[‘method’], serviceobj, methodobj, params, self) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1466, in call_with_audit result = await self._call(method, serviceobj, methodobj, params, app=app, ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1417, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 187, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 47, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/plugins/smb.py”, line 1865, in getacl acl = await self.middleware.call(‘smb.sharesec.getacl’, data[‘share_name’]) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1564, in call return await self._call( ^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1417, in call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 187, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/smb/sharesec.py", line 156, in getacl sharesec = await self.sharesec(action=‘–view’, share=share_name) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/smb/sharesec.py", line 130, in _sharesec raise CallError(f’sharesec {action} failed with error: {sharesec.stderr.decode()}') middlewared.service_exception.CallError: [EFAULT] sharesec --view failed with error: Invalid sharename: DATA
