Hi there, just spent this morning upgrading to TrueNAS SCALE 24.10.0.
I understood that as part of the migration away from Kubernetes to Docker, the current applications would be converted for you into Docker applications.
Well, not a single one of my apps came across! I have lost those apps and I have nothing running??
Sop Plex, Sabnzbd, Sonarr, Radarr, cloudflare, overseer are all gone, amongst many others.
I will have to start all over again from scratch, but hugely dissapointing.
Firstly the app configs are preserved so you can roll back to dragonfish.
Secondly I suggest looking at the apps logs & checking if there is an obvious logged reason they did not migrate. The release notes & docs call out some key things to check before upgrade such as encrypted pools not being supported for apps migration & apps needing to be up to date.
Happy to see a bug ticket come in with a debug attached via private upload so we can take a look at what is causing the issue.
Additionally you can retry the migration from the command line:
Thanks so much for the swift reply, very much appreciated. I will investigate and see if there is obvious reasons why. I read the update notes before taking the plunge, and made sure there was no encrypted partitions/datasets etc and all apps were up to date.
I will try the manual command and let you know how that works out.
