Hi, today after not bothering for months, i wanted to upgrade apps, but im getting error
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 509, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 556, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1367, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/upgrade.py", line 75, in upgrade
new_values = self.middleware.call_sync(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1654, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1694, in run_coroutine
return fut.result()
File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result
return self.__get_result()
File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
raise self._exception
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/schema_normalization.py", line 34, in normalize_and_validate_values
dict_obj = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1629, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1460, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/schema_validation.py", line 37, in validate_values
verrors.check()
File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 72, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] values.network.web_port: A dict was expected
A dict was expected error. I updated catalog but still getting this error.
I saw something about june 1st deadline, but im on Electric eel TrueNAS-SCALE-24.10.2 already and migrated my apps from truecharts few months ago.
What do i need to do to fix this?
