Hello all,
I’m running Electric Eel 24.10.1 on an iX Systems TrueNAS MiniXL+. Upgraded from Core. The intent is to use both the optimized TrueCloud Backup and also use Cloud Sync for some small-group file sharing via StorJ.
I set up a Cloud Sync job with StorJ as a backend, and it works. However, it sets the file modification times to the datetime stamp of the backup job run, not the files’ last modification dates.
In a curbside conversation with a StorJ engineer, I was told that it should probably preserve these timestamps.
The GUI settings for the job don’t make any mention of timestamps, metadata (one post online implied I might need to set a metadata flag with rclone). I can’t see a way in the GUI to directly pass rclone flags.
Any ideas?
Thank you,
David
