So, I have been running freenas, freenas Coral, freenas 11 and then truenas 12 and then Truenas Scale, since 2017 on a HP Microserver Gen 8 up until now.
I could not have been happier, given the cost and features of this little server, but 7 years later and almost 10 years since the initial release of this little monster, its time to say goodbye.
I have another post where I am trying to figure out my server’s issue. Most probably PSU failling, so it’s time to start thinking for a replacement server.
My requirements are very minimal:
4 or 5 hdds (For holding movies/series/music/photos)
1 or 2 nvmes(Truenas boot and/or running 5-6 apps)
1 or 2 ssds(Truenas boot and/or running 5-6 apps)
apps:
A “quick” search and you end up with the AsRock Rack equivalent of NAS-favourite Supermicro A2SDi? You sure know the good parts and where to find them… (though the board is currently “not at stock” at Anafra). Go ahead with the plan.
With the number of ports[1] you can use in a CSE-721, no, unless you need the extra cores for your apps and/or want (or may want in the future) 10 GbE—then go for an A2SDi-H.
and even taking into account the complex interplay between PCIe and SATA lanes in the AsRock Rack board. ↩︎
Just to be sure, are you saying I should favour the supermicro over the AsRock?
They are both not in stock ofcourse and the price difference is just 100 euros.
I am thinking about it.
No, I see no obvious reason to favour a Supermicro board over an AsRockRack board with the same specs. If you want onboard 10GbE in mini-ITX, then Supermicro is the only option.
That solves any issue with the onboard Marvell NIC… Just carefully check the board manual about possible combinations of I/O lanes into PCIe and SATA: I remember that AsRock Rack got very “creative” to work around the limitations of the C3558.
The C3558D4I has 13 possible SATA ports and a x8 slot but can only expose either
PCIe x8 with a single SATA,
9 SATA without PCIe, or
PCIe x4 with 4-5 SATA.
You’d want the last option, and booting from USB to save the 5th port for an app pool on SATA SSD. A2SDi-4C-HLN4F can provide PCIe x4 with 4 SATA and M.2 x2 for app pool—still needs USB to boot, or move up to C3758 for 4 more SATA ports.
On a good note, it seems that the Marvell 88E1543(4L) is a PHY on SGMII interface (whatever that is) from the SoC rather than a genuine NIC.
And on a totally weird note, the AsRock Rack manual features…
