TrueNAS SCALE - Installation - Console Network Setup
after my TrueNAS SCALE installation and the first startup, I’m at the console and want to set the network configuration, because DHCP will not be used.
However, I think I am too stupid for the network configuration via console :worried:
I tried to use the options “1) Configure network interfaces” and “2) Configure network settings”, but where can I set the IP address of the TrueNAS network interface?
In “1) Configure network interfaces” I can add a description, enable/disable DHCP and add aliases, but where to set the IP address?
Is there something missing in TrueNAS SCALE 24.04.1.1?
Thanks a lot in advance,
Thomas
The alias is the IP address.
…in CIDR notation, e.g., 192.168.100.100/24.
