Truenas SCALE Seagate Exos X16 Load Cycling, Heads Parking. Change of Idle_b and Idle_c values
Like many users of Seagate Exos drives, I have found that they park their heads very aggressively, approximately every 2 minutes. Due to this behavior, the Load Cycle Count increases rapidly.
For example, one of my drives:
193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 5659
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 337
I have already found many topics about this issue, but all of them rely on using camcontrol (which is not available on SCALE) or SeaChest/OpenSeaChest.
The official SeaChest tool from Seagate is not compatible with SCALE.
OpenSeaChest needs to be compiled for BSD, but SCALE does not include the tools required to compile it.
Has anyone found a tool that can use EPC to change the Idle_b and Idle_c values for Exos drives?
SeaChest works for me on SCALE – https://www.seagate.com/content/dam/seagate/migrated-assets/old-support-files/seachest/SeaChestUtilities.zip
In the archive, look for /SeaChestUtilities/Linux/Non-RAID/x_86_64
Obligatory word of warning - mucking with low-level drive settings like this can cause issues. If you do it on a live pool, I’d back up your data first.
Agree, I have used SeaChest with good results for this same issue on scale plus drive cache.
Thanks, guys! I spent almost half the day solving this.
Here’s a quick tutorial for Linux newbies (like me :slight_smile: ):
  1. Download the Utilities:
    Download the SeaChest utilities from jro post
  2. Extract the Binaries:
    Extract all binaries from:
    /SeaChestUtilities/Linux/Non-RAID/x_86_64/
  3. Copy them to your network share.
  4. Log in to Your TrueNAS Instance:
  • Navigate to System > Shell in the TrueNAS web interface.
  1. Switch to the Root User:
    Run the following command to switch to the root user:
    sudo -i
  2. Open Midnight Commander:
    mc
    Navigate to your network share where you copied the binaries. Copy them to /root/ and then close Midnight Commander.
  3. Navigate to the Folder with Binaries:
    Navigate to the folder where you copied the binaries, e.g., /root/exos_tools/.
  4. Change premissions and make binaries executable:
    chmod 777 ./*
  5. Scan for Device Handles:
    Run this command to obtain device handles (e.g., /dev/sg2):
    ./SeaChest_Basics --scan
  6. Check Idle State Timers:
    Use this command to check the idle state timers:
    ./SeaChest_PowerControl -d /dev/sg2 --showEPCSettings
For example mine:
/dev/sg2 - OOS14000G - 00023Y4K - OOS1 - ATA
===EPC Settings===
* = timer is enabled
C column = Changeable
S column = Savable
All times are in 100 milliseconds
Name Current Timer Default Timer Saved Timer Recovery Time C S
Idle A *1 *1 *1 1 Y Y
Idle B *1200 *1200 *1200 4 Y Y
Idle C 0 6000 6000 30 Y Y
Standby Z 0 9000 9000 210 Y Y
Explanation of Idle States:
Power Condition Name Description Manufacturer Default Timer Values
Idle_a Reduced electronics 100ms
Idle_b Heads unloaded. Disks spinning at full RPM 2 min
Idle_c Heads unloaded. Disks spinning at reduced RPM 4 min
Standby_z Heads unloaded. Motor stopped (disks not spinning) 15 min
  1. Set a Reasonable Idle_B Timer:
    For example, set Idle_b to 6 minutes:
    ./SeaChest_PowerControl -d /dev/sg2 --idle_b 360000
  2. Verify Changes:
    Use this command to verify the changes were applied:
  3. Repeat the above steps for all drives you want to modify.
  4. Clean Up:
    After making the changes, open Midnight Commander and delete the folder containing the binaries to clean up the system.
I couldn’t include the original link or credit the authors due to publication restrictions :frowning: sorry . However, I hope this guide helps others facing the same issue!
TrueNAS-12.0-U8.1
Seagate Exos X16
Default power settings from the manufacturer:
===EPC Settings===
        S column = Savable
Idle C      0             6000          6000         20            Y Y
Standby Z   0             9000          9000         110           Y Y
I get the following error when I try to change it.
sudo openSeaChest_PowerControl -d /dev/da2 --idle_b 360000
 openSeaChest_PowerControl - openSeaChest drive utilities
 Copyright (c) 2014-2022 Seagate Technology LLC and/or its Affiliates, All Rights Reserved
 openSeaChest_PowerControl Version: 2.0.0-1_21_23 X86_64
 Build Date: Apr 13 2022
 Today: Tue Nov  4 17:49:35 2025
/dev/da2 - ST16000NM001G-2KK103 - ZL23Z55C - ATA
Configuring EPC Settings is not supported on this device.
Any ideas what’s wrong? I downloaded the most recent version of Seagate’s utilities from Github (Release v25.05.3 · Seagate/openSeaChest · GitHub).
