TrueNas Scale Selecting Primary Network Interface
I have multiple network interfaces on my TrueNas Scale which is primarily used for ISCSI. I have 2 X 10GB/s connections but also a 40GB/s however for some reason all traffic is always routed to the 10GB/s network interfaces despite my ESXI specifically using the IP address of the 40GB/s network card.
Is there a way I can set the 40GB/s QSFP network as the primary and the others as failover only?
You will need to set the metric for the fastest connection to a 25, then set the other connections in the order that you want access.
