I have 4 x 4TB disks in mirror mode. Initially I had 3x4TB and it was enough, so when I added the extra 4 TB drive I just left it as is.
Now I got my hands on 2 x 8TB drives and I would like to do a STRIPE+MIRROR.
So I would have 16TB available as 8+4+4 (3 disks) and then this would be mirrored to 8+4+4 (another 3 disks).
Is that possible? When I clicked on Extend the pool simply grabbed the extra disk and now I have a 6-way 4TB mirror… I can’t seem to change the layout from MIRROR in the extend dialog…
You started with three 4TB drives and set them up as a 3-way mirror? For net capacity of 4TB? Or did you set them up as a stripe with capacity of 12TB and no redundancy?
When you added the fourth 4TB drive did you make it a 4-way mirror (capacity 4TB) or a 4-way stripe (16TB capacity and no redundancy)?
What you propose is sensible, a zpool made up of 2-way mirrors, the first being a pair of 8TB drives and then two more each consisting of a 2-way mirror of 4TB drives.
Please post output from /sbin/zpool status as preformatted text.
Apologies for the confusion. It was a mirror with 3 disks all having the same data. Then I added a 4th and it be came part of the mirror, so I have 4 copies of the data.
I did not mind because I had less than 4TB saved, but now I need more spaces. I got 2 extra drives that are 8TB (so double the size). But I did the same thing as when I got my 4th 4TB drive: extend the pool and apparently now the 2 extra 8TB drives are also part of the mirror and I have 6 copies of the data…
I want to have 2 copies of the data and 16TB available:
I would remove all but 2 of the drives form the existing zpool.
Then you have a choice. You can either add additional mirror pairs to that zpool. Or you can start building a new zpool and copy the data over.
The advantage to adding mirrors to the existing zpool is that you do not have to copy any data. The disadvantage is that new writes prefer the mirror pairs with the most free space. Since you will have unbalanced mirror (one 8TB and two 4TB) you will always have some of that.
The advantage of creating a new zpool is that from day one you will be balancing writes across all mirror pairs. the disadvantage is the need to copy data and a brief window of vulnerability when you move the existing 4TB drives into the new zpool.
Let me know which way you want to go and I’ll get you instructions.
P.S. I would go with adding onto the existing mirror zpool.
Ok so I should remove the disks from the mirror until I am left with a 2x4TB mirror. Then I create a new mirror with 2x4TB and that will pair them to give me 8TB. Then I make another pair of 2x8TB?
Ok so I have followed the instructions and I now have 3 VDEVs, each is a mirror (2x4TB, 2x4TB and 2x8TB) and this worked nicely. The available space is now 16TB.
