Hey there!
I’d like to collect information in this thread to make TrueNAS CORE work on these devices.
I have pledged for a DXP6800 PRO and will add information accordingly in the next days after scraping the stock debian for more info.
If you have a spare UGREEN NASYNC Device and would like to contribute, please do so and I’ll update this Post.
Output of lspci:
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4601] (rev 04)
00:02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-UP3 GT2 [UHD Graphics] [8086:4628] (rev 0c)
00:07.0 PCI bridge [0604]: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 [8086:466e] (rev 04)
00:07.2 PCI bridge [0604]: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #2 [8086:462f] (rev 04)
00:0d.0 USB controller [0c03]: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller [8086:461e] (rev 04)
00:0d.2 USB controller [0c03]: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 [8086:463e] (rev 04)
00:0d.3 USB controller [0c03]: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #1 [8086:466d] (rev 04)
00:14.0 USB controller [0c03]: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller [8086:51ed] (rev 01)
00:14.2 RAM memory [0500]: Intel Corporation Alder Lake PCH Shared SRAM [8086:51ef] (rev 01)
00:15.0 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 [8086:51e8] (rev 01)
00:15.1 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 [8086:51e9] (rev 01)
00:16.0 Communication controller [0780]: Intel Corporation Alder Lake PCH HECI Controller [8086:51e0] (rev 01)
00:17.0 SATA controller [0106]: Intel Corporation Alder Lake-P SATA AHCI Controller [8086:51d3] (rev 01)
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:51ba] (rev 01)
00:1c.4 PCI bridge [0604]: Intel Corporation Device [8086:51bc] (rev 01)
00:1c.6 PCI bridge [0604]: Intel Corporation Device [8086:51be] (rev 01)
00:1d.0 PCI bridge [0604]: Intel Corporation Alder Lake PCI Express Root Port [8086:51b0] (rev 01)
00:1f.0 ISA bridge [0601]: Intel Corporation Alder Lake PCH eSPI Controller [8086:5182] (rev 01)
00:1f.3 Audio device [0403]: Intel Corporation Alder Lake PCH-P High Definition Audio Controller [8086:51c8] (rev 01)
00:1f.4 SMBus [0c05]: Intel Corporation Alder Lake PCH-P SMBus Host Controller [8086:51a3] (rev 01)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Alder Lake-P PCH SPI Controller [8086:51a4] (rev 01)
55:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation PS5013 E13 NVMe Controller [1987:5013] (rev 01)
56:00.0 Ethernet controller [0200]: Aquantia Corp. Device [1d6a:04c0] (rev 03)
57:00.0 Ethernet controller [0200]: Aquantia Corp. Device [1d6a:04c0] (rev 03)
58:00.0 SATA controller [0106]: ASMedia Technology Inc. Device [1b21:1164] (rev 02)
dan
June 7, 2024, 10:35pm
I’ve also pledged for a 6800, and while I think I’ll mainly be running SCALE on it, I’m planning to try a few different OSs including CORE. Though I’m not sure CORE supports the onboard NIC.
No, the NIC is not supported out of the box for now on FreeBSD.
Will mainly collect information for CORE to make it functional.
Also the status LEDs for the bays and NICs seem to be controller independantly, as they are stuck in the cicle animation like at a reboot of UGOS.
Here’s the lspci from UGreen NASync 6800 PRO:
00:00.0 Host bridge: Intel Corporation Device 4601 (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-UP3 GT2 [Iris Xe Graphics] (rev 0c)
00:07.0 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 04)
00:07.2 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #2 (rev 04)
00:0d.0 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller (rev 04)
00:0d.2 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 (rev 04)
00:0d.3 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #1 (rev 04)
00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
00:15.1 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 (rev 01)
00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
00:17.0 SATA controller: Intel Corporation Alder Lake-P SATA AHCI Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation Device 51ba (rev 01)
00:1c.4 PCI bridge: Intel Corporation Device 51bc (rev 01)
00:1c.6 PCI bridge: Intel Corporation Device 51be (rev 01)
00:1d.0 PCI bridge: Intel Corporation Alder Lake PCI Express Root Port (rev 01)
00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
00:1f.3 Audio device: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
55:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5013 E13 NVMe Controller (rev 01)
56:00.0 Ethernet controller: Aquantia Corp. Device 04c0 (rev 03)
57:00.0 Ethernet controller: Aquantia Corp. Device 04c0 (rev 03)
58:00.0 SATA controller: ASMedia Technology Inc. Device 1164 (rev 02)
Also the LED control has already been figured out:
ugreen_truenas_led.md
## UGREEN DXP4800 Plus TrueNAS Status LED Guide
The following is a quick guide on getting basic status LED functionality working with TrueNAS running on the UGREEN DXP4800 Plus. Theoretically, it should work on all models... but I only have a DXP4800 Plus. :)
This guide is for cron job that runs a script to update the LEDs every couple minutes, but I'm sure the following can be modified for blinky LEDs as well.
## Steps:
This file has been truncated. show original
