UI/Storage and UI/Storage/Disks hangs during format
I have two machines, one with a Draid array and one with a pool with 12 vdevs of 3 way mirrors. I tried moving a couple drives around and tried to start a format of the replacement drive before starting any replace operations. I have noticed any time I call a format command such as sg_format --format --size=512 -v /dev/sdg from the shell, the ui/storage or ui/storage/disks pages refuse to load for a period of time. This happens longer on the mirrored array than the draid array but occors on both.
On the mirrored pool, I believe I started a format on the wrong drive causing the pool to be slightly more degraded. One vdev has a removed drive and another vdev has a faulted drive because I accidentally formatted a drive that was online and part of a pool. Unfortunately I cannot identify which is the correct drive that needs formatted until the format operation finishes or the system becomes responsive again. My data isn’t really at risk due to still having 2 mirrors in each problematic vdev, but it would be nice to get that second format started.
Does anyone have a good shell command to help me identify which drive is not a member of the pool? It seems like unresponsive pages like this during a format operation would be some sort of bug.
I did end up just pulling the disks which stopped the format. It then allowed me to offline /dev/sdg and discover I actually wanted to format /dev/sda. Both drives are now formatting and I should be able to resilver the array tomorrow.
Truenas needs to support formatting from the GUI better for instances where drives need sector size changes or other proper formats rather than just being wiped or quick formatted. I chose to format in this instance because that is the only way I have figured out so far to take a drive that was removed from a draid3 array and use it to replace a drive in a mirrored vdev. Otherwise I get errors. It would be helpful to fix these errors that make the GUI unusable during a format operation.
