Update from Dragonfish-24.04.2 (not from 24.04.2.5) to 24.10.2?
Hi, i have question, can i update directly from Dragonfish-24.04.2 (not from 24.04.2.5) to 24.10.2?
I must update to 24.04.2.5 before update to 24.10.2? or i can update from 24.04.2 to 24.10.2 normally?
Secend question, i have docker containers added manually, is move automaticly from k3s to docker?
You should update from one major release to the next so your fist update should be 24.10.X and then 25.04. I don’t know if you must be on the last point release of 24.04, but i don’t think you have to.
Your custom apps should migrate to the docker backend.
Thx for your anser, but i ask can i update from 24.X to 24.X but from 24.04.2.0 to 24.10.2 or i must first update to 24.04.2.5 before update to 24.10.X? I want to update from 24.04.2.0 (24.04.2) to 24.10.2
you can jump from 24.04.X to 24.10.X, it should not matter.
Cool, thx for help :slight_smile:
