Updated to 24.10.0 from RC, and now docker is not running [SOLVED]
Hmmm. I’d hoped for a straight forward update this morning from RC2 to 24.10.0, but Docker didn’t start up on reboot.
I’d installed Dockge on the RC using the apps system, with host mounts for the app and stacks, as per Stux’s excellent video on migrating from Dragonfish jail to EE, and had several stacks up and running fine in 24.10.RC2
The update from the GUI seemed to go well - downloaded, installed & rebooted. But on reboot, the apps system wouldn’t come up, with a little “App service pending” icon. I waited about 5 minutes.
I’ve got the pool set, but when trying to reinstall Dockge, get the following error:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 488, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 535, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1361, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 268, in nf
    rv = func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 179, in do_create
    self.middleware.call_sync('docker.state.validate')
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1651, in call_sync
    return self.run_coroutine(methodobj(*prepared_call.args))
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1691, in run_coroutine
    return fut.result()
  File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result
    return self.__get_result()
  File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
    raise self._exception
  File "/usr/lib/python3/dist-packages/middlewared/plugins/docker/state_management.py", line 87, in validate
    raise CallError(error_str)
middlewared.service_exception.CallError: [EFAULT] Docker service is not running
Will try to unset the pool and reset it.
EDIT: Back up and running. Not sure if it was un-setting then resetting the pool which worked. Either way, I hope the above error messages are helpful to the TrueNAS team.
+1
I had to do the unset/set trick after initial install/boot too.
I ran into this when I updated from RC1 to RC2.
In my case a reboot of the system fixed the issue.
