06:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS2308 PCI-Express Fusion-MPT SAS-2 (rev 05)
Subsystem: Broadcom / LSI 9207-8e SAS2.1 HBA
Flags: bus master, fast devsel, latency 0, IRQ 46, NUMA node 0, IOMMU group 20
I/O ports at 6000 [size=256]
Memory at dee40000 (64-bit, non-prefetchable) [size=64K]
Memory at dee00000 (64-bit, non-prefetchable) [size=256K]
Expansion ROM at ded00000 [disabled] [size=1M]
Capabilities: [50] Power Management version 3
Capabilities: [68] Express Endpoint, MSI 00
Capabilities: [d0] Vital Product Data
Capabilities: [a8] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [1e0] Secondary PCI Express
Capabilities: [1c0] Power Budgeting <?>
Capabilities: [190] Dynamic Power Allocation <?>
Capabilities: [148] Alternative Routing-ID Interpretation (ARI)
Kernel driver in use: mpt3sas
Kernel modules: mpt3sas
After I upgraded and it boots , it finds my storage Box ( Netapp) and find all disks , after Console is done i.e. itr bring you the options for shell.
it then forces a Enclosure boot and all disks are ripped out, and after that all kinds of error are reported in disks , after I rebooted again to other version 23.10.1.3 all error are removed.
I would but since this causes zfs break, on 3 of my pools I am very reluctant and trying this again, my thoughts are kernel related, quick google points in that direction.
That’s good, one less variable to worry about. Might be worth scrubbing the boot pool just to check that it wasn’t data corruption during/after the update rather than a real bug.
I Got an extra Netapp Enclosure box, and Hooked that one up to the secondary port of the controller.
So now I have two enclosures with a single connection down to each box.
So the problem was that I had the other enclore connected to both port A and B on the controller to one encloser , I tested this again, and that is what causes the crash , but only on Dragonfish.
Have had this setup running Truenas Scale and Core, But I guess I was doing the connection wrong way ?.
