Upgrading old FreeNAS system? (v9.10)
Hi everyone
At home I’ve got a NAS-system that I’ve built myself in 2017. It’s really stable and is working great now since 7 years back, never had any problems.
It’s running FreeNAS-9.10.2-U2 (e1497f2) so I feel that I really should check out if/how I can upgrade it to a good, modern version.
In the FreeNAS web interface there is a page/tab “Update”, but unfortunately it doesn’t work since FreeNAS 9.10 is really old at this time.
I get the message: “Update server could not be reached HTTP. Error 308: Permanent Redirect”
Any advice on how I can upgrade?
Some additional information: My usage of this NAS-system is pretty basic. I only use it to serve storage through NFS, plus a jail running rtorrent+rutorrent.
The main storage is just two HDDs in RAID1, one volume and a few datasets. It’s below 80% full with 1.5TB free space.
I have offline HDDs with all data backuped.
Please upload images directly to the forum instead of using external image hosts.
Yes, you can use a manual update package, which you can get from https://download.freenas.org/
Another question: Does newer TrueNAS-versions have higher demand on the boot drive?
I’m using two usb-drives. It was a popular practice back in ~2017 with FreeNAS 9.10
I saw this discussion that mentions that it is no longer recommended Reddit - Dive into anything
What is the most modern version of TrueNAS can I update to while having these dual usb-sticks as boot drive?
My system is currently running FreNAS version 9.10.2-U2 (e1497f2)
Suppose I want to upgrade to the latest 11.1-version, am I thinking right that I should apply these 5 manual updates?
First upgrade to latest 9.10.2-U6: https://archive.freenas.org/9.10/STABLE/9.10.2-U6/FreeNAS-9.10.2-U6-manual-update.tar
Step up to 11.0: https://download.freenas.org/11/11.0-RELEASE/FreeNAS-11.0-RELEASE-manual-update.tar
Upgrade to latest 11.0-U4 https://download.freenas.org/11/11.0-U4/FreeNAS-11.0-U4-manual-update.tar
Step up to 11.1: https://download.freenas.org/11/11.1-RELEASE/FreeNAS-11.1-RELEASE-manual-update.tar
Upgrade to latest 11.1-U7 https://download.freenas.org/11/11.1-U7/FreeNAS-11.1-U7-manual-update.tar
Also, do jails stop working / get erased? For example when I upgrade to a new major version (9.10 to 11.0, 11.0 to 11.1)
I have made some careful attempts at trying to upgrade from 9.10.2-U2 to 9.10.2-U6, but updating does not succeed, it has no effect.
First I tried using “Manual Update” in the web interface and giving this tarball: https://archive.freenas.org/9.10/STABLE/9.10.2-U6/FreeNAS-9.10.2-U6-manual-update.tar
That results in this error message:
Error: Failed to apply update Command '['/usr/local/bin/freenas-update', '-C', u'/var/tmp/firmware', 'update']' returned non-zero exit status 1
Second attempt I tried was updating from terminal with these commands:
cd /var/tmp
wget https://archive.freenas.org/9.10/STABLE/9.10.2-U6/FreeNAS-9.10.2-U6-manual-update.tar
freenas-update FreeNAS-9.10.2-U6-manual-update.tar
The freenas-update command produces no output to terminal at all.
The next thing I will try is upgrading using a bootable usb-stick. As I understand the documentation it should be no problem to leapfrog directly to v11.1-U7 or v11.2-U8.
Make sure to download your config, which you should be able to upload to 11.
Once you get to 11, I found this migration path diagram
Not more so than 9.3 and 9.10. It was indeed a popular option, though by 2017 it had fallen quite a bit out of favor already. USB flash drives, typically, are just too unreliable and/or age too terribly performance-wise.
Not inherently a limitation, but the most obvious issue you’re likely to run into is that updates take forever (over an hour in some cases).
Thanks for the diagram, very helpful! :smiley:
Ok, I have now updated by using bootable usb-stick.
I first updated to 11.1-U7 which went great, no issues or any warnings at all.
Next I updated to FreeNAS-11.2-U8, the update process went pretty well but I did get one weirdness:
During the reboot / “conversion configuration database” the process hanged at this step for a long time:
middlewared: setting up plugins (alert) [15/17]
Eventually it continued after some timeout limit was reached (240 seconds I think) and displayed a really serious-looking warning
middlewared did not start correctly
I get no warnings or anything in the web interface, everything looks good there. Should I examine the system closer and if there’s any issues?
My priority now is to setup a new rtorrent+rutorrent iocage jail…
I wonder how much work it will be, package repositories does not seem to be available, so I will have to install everything by building from source…? :sweat_smile:
An issue I’m facing is that in FreeNAS 11.2-U8 I cannot create jails, because the web interface gives me no option for (FreeBSD) “Release”. (I am of course using the new interface, not the legacy one)
What makes it stranger is that I could create a jail in 11.1-U7 in the brief time I ran that version, before upgrading to 11.2-U8.
Anyway, can I manually fix this from the command line? I’m imagining something like downloading FreeBSD and placing it in the right directory.
I solved the issue with that I had no option for “Release” in jail creation. I had to run the iocage fetch-command manually like this:
iocage fetch --root-dir /pub/FreeBSD-Archive/old-releases/amd64/ --server ftp-archive.freebsd.org
My machine is currently running FreeNAS 11.2. I would like to continue updating to 11.3 but I have an old jail from v9.10 that I really would like to keep and continue using. But v11.3 drops support for the old pre-iocage jails (atleast in the WebUI…)
I have done some examining, and the jail command-line utilities are available in later versions of Free/Truenas. Even TrueNAS 13.0 includes these commands (maybe not really surprising since I guess they’re part of the base operating system)
So I am thinking of updating to 11.3 and managing this old jail from the command line. (I only need to stop/start it)
If I run into problem I can go back to booting 11.2
Any thoughts on how viable it is to keep around an old jail in 11.3 that’s only “supposed” to support iocage jails?
Since FreeBSD 11 is EOL since 2020 you cannot create new jails with FreeBSD 11. You need to run a supported release on your host first. That would be TrueNAS 13.3 with FreeBSD 13.3.
Then you can create a new iocage jail and manually migrate your application. The time window for a seamless migration from warden to iocage is long gone …
I discovered that there is a tool included in FreeNAS for migrating warden jails to iocage, migrate_warden.py .
I want to test this in a FreeNAS virtual machine before doing it on my real system, that means I also need to create a warden jail.
Creating a warden jail is not exactly an easy task in 2024, but eventually I found out and solved how to do that:
  1. Go to Jails > Templates > Click the button ‘Add Jail Template’
    Name: < whatever >
    OS: FreeBSD
    Architecture: x64
    URL: https://download.freenas.org/jails/9.10/x64/freenas-pluginjail-10.3-RELEASE.tgz
    Mtree: https://download.freenas.org/jails/9.10/x64/freenas-pluginjail-10.3-RELEASE.mtree
  2. Now a jail can easily be created. Click ‘Add Jail’ and also click ‘Advanced Mode’ in order to select the jail template created in step #1.
forum topic about migrate_warden.py:
I have used the migrate_warden.py script and migrated my old jail created in FreeNAS 9.10 (FreeBSD 10.3-RELEASE).
The new iocage jail fails to start. There seems to be an issue with configuring network / DHCP at startup. If I disable so that the jail will not have a network connection then the jail can start.
Failed startup:
iocage start rtorrent_jail
* Starting rtorrent_jail
  + Started OK
  + Configuring VNET OK
ifconfig: illegal option -- f
usage: ifconfig [-L] [-C] [-g groupname] interface address_family [address [dest_address]]
                [parameters]
       ifconfig interface create
       ifconfig -a [-L] [-C] [-g groupname] [-d] [-m] [-u] [-v] [address_family]
       ifconfig -l [-d] [-u] [address_family]
       ifconfig [-L] [-C] [-g groupname] [-d] [-m] [-u] [-v]
  File "/usr/local/bin/iocage", line 10, in <module>
    sys.exit(cli())
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__
    return self.main(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main
    rv = self.invoke(ctx)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke
    return callback(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/iocage_cli/start.py", line 54, in cli
    ioc.IOCage(jail=jail, rc=rc).start()
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1641, in start
    callback=self.callback
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 67, in __init__
    self.__start_jail__()
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 467, in __start_jail__
    "message": "  + Acquiring DHCP address: FAILED,"
UnboundLocalError: local variable 'addr' referenced before assignment
Example of successful startup:
iocage start testjail
* Starting testjail
  + Started OK
  + DHCP Address: 192.168.1.115/24
  + Starting services OK
I have found some mentions of this problem (or something very similar) on the internet:
https://www.reddit.com/r/freenas/comments/asn0mc/112_killed_jails_the_fix_doesnt_work/
https://www.reddit.com/r/freenas/comments/as0vei/comment/egrcjek/
Just toggling the jail’s network settings are not helping in my case. I haven’t tried setting a static IP adress, so I will try that.
Alright, if I set a static IP for the jail it starts up successfully.
The particular version of iocage included in 11.2 seems to have a known error when it comes to jails older than FreeBSD 11.0. I found this:
I also checked FreeNAS 11.3, the version of iocage included there is more modern and should handle DHCP for old jails correctly.
Correction: Earlier in this thread I wrote that newer versions of Free/TrueNAS (11.3 and newer) included command-line utilities for warden jails, but I was mistaken.
I have updated to FreeNAS 11.3-U5 now by using bootable usb-stick. The update went fine without any issues.
DHCP works fine now for the old FreeBSD 10.3 jail.
A weird thing in FreeNAS 11.3-U5 is that I cannot create jails by using the WebUI, same problem as in 11.2 that I get no option for Release.
In 11.2 it was easily solved by using iocage fetch to fetch a release, but in 11.3 that does not solve the problem in the WebUI.
However, I can use iocage create from the command line to create jails just fine, and they are listed in the WebUI.
I have now created a 11.3 jail with lighttpd+php 7.4+rtorrent 0.9.8+rutorrent 5.0 !! :partying_face: :partying_face:
