Subject: Need Help with Slow Cloud Sync Task Speeds on a Custom TrueNAS Build
Hello everyone,
I’ve recently put together a custom TrueNAS setup and I’m encountering an issue that I’m hoping someone can help me solve. Here’s a brief overview of my system:
Motherboard: MSI
CPU: AMD Ryzen 5 3600, 6 cores, 12 threads
RAM: 64GB
Storage: 73TB total capacity
Internet Speed: 440 Mbps download, 330 Mbps upload
Network Adapters: Connected via two 100BaseTX adapters Intro
A few weeks ago i had a problem with the download of the cloud sync task. it was really slow like 2-3 Mbips at the end i finally find a solution installing a new Internet Card and it went to 75 Mbi/s that is close to 587 MB/s
I download close to 80TB of info on my Nas station. The Problem:
After finish all that process my next task is to update all that information to dropbox. For that reason i create another cloudsync task to update copy the info on a push task. When task started I saw that the speed nos is 5 Mbi/s what means is really slow and it take a lot of time in do that task. Question
I find the solucion for dowload to a decent speed. Now, How can I fix the update speed, knowing that my internet speed is 500 MBs of update?
Thanks everyone that help me to fix that problem
Please tell us more about the model of the adapter you have installed. And, are you sure it’s not a pool-performance issue? Is anything going on while the cloud sync is running?
Hello thanks for your anwser a few weeks ago i update the internet adaptor. For the download that was really good, but now for upload i hace between 4 to 6 Mib/s.
my internet adaptor is
Dual-Port PCIe Gigabit Network Card 1000M PCI Express Ethernet Adapter with Intel 82576 Two Ports LAN NIC Card for Support PXE for Windows/Windows Server/Linux/Freebsd/DOS with Low Profile
