I must have made a stupid decision when I connected my external SSD to my Truenas Scale via USB adapter and connected it to my pool. This morning I noticed that the system rebooted overnight and my pool is no longer loaded.
When I enter “zpool import” in the console, I get the following output
root@truenas[~]# zpool import
pool: vmpool
state: UNAVAIL
status: One or more devices contains corrupted data.
action: The pool cannot be imported due to damaged devices or data.
vmpool UNAVAIL insufficient replicas
nvme0n1p4 ONLINE
694dfb9c-f13f-4bed-b69b-76e810e2b9c3 UNAVAIL
Is there still a possibility to save the pool or do I have to delete the pool and all data is gone?
What you did here was not sensible - whilst we need to focus here on how to get your pool back, next time ask for some advice before you decide to use an unusual pool layout.
To get this pool back online we need to establish what has happened to the USB drive. Can you please run the following:
Try to identify the USB device, and if you can then run:
sudo sgdisk -p /dev/xxx
where xxx is the device name for the USB device.
Then post the output for each of these here (and try to preserve the formatting using the editors “preformatted text” button).
If we can get the data back, you need to decide how to switch to a more sensible pool design, and if not you will need to recreate it and that would be best done on a more sensible pool design.
So lesson learned. Thank you for clear message. basicly i know that it was not the best idea but what should i say?
I run the command with the the USB Drive in same Port as i installed it.
root@truenas[~]# lsblk -bo NAME,PTTYPE,TYPE,START,SIZE,PARTTYPENAME
NAME PTTYPE TYPE START SIZE PARTTYPENAME
nvme0n1 gpt disk 240057409536
├─nvme0n1p1 gpt part 4096 1048576 BIOS boot
├─nvme0n1p2 gpt part 6144 536870912 EFI System
├─nvme0n1p3 gpt part 1054720 17179869184 Solaris /usr & Apple ZFS
└─nvme0n1p4 gpt part 34609152 222336909312 Linux filesystem
In the first try i did not find the USB drive and i dont change the slot. After that i switch the USB Port and run the Commands again with the following output:
sda gpt disk 1000204886016
└─sda1 gpt part 2048 1000203091968
root@truenas[~]# sudo sgdisk -p /dev/sda
Disk /dev/sda: 1953525168 sectors, 931.5 GiB
Model:
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): 97F00230-E9CE-4FE7-AC4A-51A4EF9E2A8F
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 1953525134
Partitions will be aligned on 2048-sector boundaries
Total free space is 3437 sectors (1.7 MiB)
Number Start (sector) End (sector) Size Code Name
1 2048 1953523711 931.5 GiB BF01 data
root@truenas[~]# sudo sgdisk -p /dev/sda1
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Exact type match not found for type code 7200; assigning type code for
'Linux filesystem'
Exact type match not found for type code 6C00; assigning type code for
'Linux filesystem'
Warning! Secondary partition table overlaps the last partition by
1936159669 blocks!
You will need to delete this partition or resize it in another utility.
Disk /dev/sda1: 1953521664 sectors, 931.5 GiB
Disk identifier (GUID): 69949DB5-70EB-4BA6-B594-A4A538911719
First usable sector is 34, last usable sector is 1953521630
Partitions will be aligned on 32-sector boundaries
Total free space is 1920221950 sectors (915.6 GiB)
1 1920221984 3736432267 866.0 GiB 8300 Linux filesystem
2 1936028192 3889681299 931.6 GiB 8300 Linux filesystem
So got the pool back online and copy all my needed Stuff from it and setup the pool again without the USB Drive.
What was my Solution for this Problem?!
I set the zfs_max_missing_tvds to 1 and import the Pool in read only with zpool import -o readonly=on vmpool . After that the main nvme was back online and i can reconnect them. After a second the USB Drive came back online too.
