Use FreeIPA/RedHat IdM for Auth in TrueNAS with Kerberos & LDAP for NFSv4
I am working on a proof of concept for integrating TrueNAS with FreeIPA user and host management. The goal is to get Kerberos Auth working with NFSv4. For that, LDAP is needed to get the FreeIPA users and Kerberos for ticket authentication. After extensively researching this, I was unable to find any forum post or blog entry here or anywhere on the internet on how to fully configure this and get it working. So, first of all, is this currently even possible with TrueNAS SCALE 24.10?
Since I am not allowed to post links or images, please excuse the obfuscated urls.
General Info about my setup (all hostnames have been changed):
Kerberos Realm: MYREALM (dot) EXAMPLE (dot) COM
TrueNAS SCALE Server: truenas (dot) srv (dot) example (dot) com
FreeIPA Server: ipa (dot) srv (dot) example (dot) com
My configuration steps:
Create a new Host on the FreeIPA Server and create the corresponding keytab file for TrueNAS:
sudo ipa host-add truenas.srv.example.com
sudo ipa-getkeytab -p host/truenas.srv.example.com -k truenas.keytab
Then I uploaded that keytab file after configuring the other required Kerberos Settings:
imgur (dot) com/u1qmAFa
Some information I found online said to add a couple of lines to the “Libdefaults Auxiliary Parameters” which is how I ended up with the following config:
default_realm = MYREALM.EXAMPLE.COM
rdns = no
dns_lookup_kdc = true
dns_lookup_realm = false
Now to the issue I am facing: the LDAP config. On the FreeIPA Server I ran the command ldapmodify -x -D 'cn=Directory Manager' -W to create the system LDAP user according to the official documentation (www (dot) freeipa (dot) org/page/HowTo/LDAP). This command is for entering the LDAP cli and will ask for the (LDAP) admin password set during FreeIPA installation. After entering it and pressing enter, write the lines below. Make sure to use a new password for that user. Then press enter twice until the “adding new entry” line is printed. After that, exit that cli by pressing Ctrl+D. The full terminal log should look like this:
~$ sudo ldapmodify -x -D 'cn=Directory Manager' -W
Enter LDAP Password:
dn: uid=system,cn=sysaccounts,cn=etc,dc=myrealm,dc=example,dc=com
changetype: add
objectclass: account
objectclass: simplesecurityobject
uid: system
userPassword: <new_password_here>
passwordExpirationTime: 20380119031407Z
nsIdleTimeout: 0
adding new entry "uid=system,cn=sysaccounts,cn=etc,dc=myrealm,dc=example,dc=com"
^D
To my understanding, the advanced LDAP Settings in TrueNAS are there to use Kerberos to authenticate with the FreeIPA LDAP Server. Is that correct? If so, there appears to be an issue with this. The following is my configuration and the error I get when saving the configuration. For simplicity, I am using LDAP unencrypted, but in production it should be LDAPS.
imgur (dot) com/gzfCADe
Either there is an issue with TrueNAS when retrieving the keytab file or something similar. Or TrueNAS doesn’t correctly use the Keytab file to authenticate with FreeIPA.
The following is the error output when saving the LDAP config in TrueNAS:
  File "/usr/lib/python3/dist-packages/middlewared/plugins/kerberos.py", line 417, in do_kinit
    gss_acquire_cred_principal(
  File "/usr/lib/python3/dist-packages/middlewared/utils/directoryservices/krb5.py", line 251, in gss_acquire_cred_principal
    cr = gssapi.Credentials(
  File "/usr/lib/python3/dist-packages/gssapi/creds.py", line 77, in __new__
    res = cls.acquire(name, lifetime, mechs, usage,
  File "/usr/lib/python3/dist-packages/gssapi/creds.py", line 173, in acquire
    res = rcred_cred_store.acquire_cred_from(b_store, name,
  File "gssapi/raw/ext_cred_store.pyx", line 161, in gssapi.raw.ext_cred_store.acquire_cred_from
gssapi.raw.exceptions.MissingCredentialsError: Major (458752): No credentials were supplied, or the credentials were unavailable or inaccessible, Minor (2529639068): Cannot contact any KDC for realm 'MYREALM.EXAMPLE.COM'
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 488, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 533, in __run_body
    rv = await self.method(*args)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 49, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 179, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 671, in do_update
    await self.ldap_validate(old, new, verrors)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 499, in ldap_validate
    await self.validate_credentials(data)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 756, in validate_credentials
    await self.kinit(ldap_config)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 745, in kinit
    await self.middleware.call('kerberos.do_kinit', {'krb5_cred': cred})
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1626, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1468, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1361, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/kerberos.py", line 430, in do_kinit
    raise KRB5Error(
middlewared.utils.directoryservices.krb5_error.KRB5Error: [KRB5_KDC_UNREACH] Major (458752): No credentials were supplied, or the credentials were unavailable or inaccessible, Minor (2529639068): Cannot contact any KDC for realm 'MYREALM.EXAMPLE.COM'
The first Traceback is in my eye the most relevant one since that is the first error that occurred. It states gssapi.raw.exceptions.MissingCredentialsError: Major (458752): No credentials were supplied, or the credentials were unavailable or inaccessible, Minor (2529639068): Cannot contact any KDC for realm 'MYREALM.EXAMPLE.COM'. I don’t understand why, because the correct LDAP user and password are provided, as well as the required keytab.
Here is the generated kerberos config /etc/krb5.conf from TrueNAS.
[libdefaults]
        forwardable = true
        default_ccache_name = KEYRING:persistent:%{uid}
        dns_lookup_kdc = false
        dns_canonicalize_hostname = false
        udp_preference_limit = 0
[appdefaults]
[realms]
        MYREALM.EXAMPLE.COM = {
                default_domain = MYREALM.EXAMPLE.COM
                kdc = ipa.srv.example.com:389
[domain_realms]
        myrealm.example.com = MYREALM.EXAMPLE.COM
        .myrealm.example.com = MYREALM.EXAMPLE.COM
        MYREALM.EXAMPLE.COM = MYREALM.EXAMPLE.COM
        .MYREALM.EXAMPLE.COM = MYREALM.EXAMPLE.COM
What I am confused about is, why does the kbc value under [realms] has the port 389? That is the LDAP port. Why is this set in the kerberos config? Shouldn’t it be port 88? The only setting where a port was configured is in the LDAP screen and if I remove the port and only specify the FreeIPA hostname, the same error as shown above occurs, but the /etc/krb5.conf file stays the same.
When I manually edit the /etc/krb5.conf file to port 88 or remove the port, I get the following error:
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 911, in __start
    await self.ipa_kinit(ipa_config, ldap['bindpw'])
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 876, in ipa_kinit
  File "/usr/lib/python3/dist-packages/middlewared/plugins/kerberos.py", line 447, in do_kinit
    raise CallError('Password is required')
middlewared.service_exception.CallError: [EFAULT] Password is required
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 681, in do_update
    await self.__start(job, ds_type)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 932, in __start
    if not err.err_msg.startswith('[KRB5_REALM_UNKNOWN]'):
AttributeError: 'CallError' object has no attribute 'err_msg'
The error is middlewared.service_exception.CallError: [EFAULT] Password is required which is also confusing for the same reason as the other error above. Why is a password required when I have the keyfile? Either way, this is no permanent fix, since the file is regularly re-written.
I would very much appreciate some help with this!
We are also struggling with this. Any progress?
I have this working with MIT Kerberos running in a TrueNAS container, exporting Kerberised NFSv4 to a Mac client. It does not need LDAP. If that is helpful I can post how I did it.
Yes, please. Any help on how to configure this and how it works is appreciated. However, as I understand it, LDAP is needed to let NFS v4 know about additional users. Otherwise one would need to add every user that wants to access the share to exist as a TrueNAS user.
Kerberos (whether from FreeIPA or standalone) is only performing user authentication. In your setup FreeIPA’s LDAP is providing the user directory with user/group, uid/gid, home directory, etc. mappings, and I suspect also hashes for NTLMv2 authentication.
I setup Kerberos for my home environment, so having to add every user to TrueNAS was not an issue. In an office environment with more users and computers you will be much better off with an integrated solution. An alternative to FreeIPA and Active Directory may be Samba Active Directory.
The krb5.conf that you pasted above is definitely wrong. Kerberos KDC ports are 88/udp and 88/tcp. Based on what I entered in the TrueNAS GUI Kerberos section by hand, TrueNAS 25.04.1 created this correct krb5.conf realms block for me:
[realms]
MYHOME.LAN = {
default_domain = MYHOME.LAN
admin_server = fileserver.myhome.lan
kdc = fileserver.myhome.lan
kpasswd_server = fileserver.myhome.lan
The keytab has keys for the principals that the server will use. It does not have the Kerberos service ports. My reading of the TrueNAS documentation is is that it works something like:
  • TrueNAS uses the LDAP bind password you provide to authenticate to the LDAP server.
  • When it connects to the LDAP server it finds that there is an integrated Kerberos service.
  • It takes the opportunity to use the LDAP bind account (which requires admin credentials) to create a Kerberos principal for TrueNAS, and then downloads the key.
  • It’s not clear whether it uses Kerberos to authenticate to LDAP, or just keeps using the LDAP bind account, but what is strange is that you can only choose 1 of 3 Kerberos principals:
  • host/truenas.server@REALM – would be the one I would expect would be used for machine-account authentication
  • nfs/truenas.server@REALM – principal for the NFS service
  • cifs/truenas.server@REALM – principal for the SMB service
In practice you would want the keytab to have all 3, and not just 1…
This is perhaps not helpful but I suspect aligns with your experience: I started trying to get FreeIPA to work in a container. The container install instructions (GitHub - freeipa/freeipa-container: FreeIPA server in containers — images at https://quay.io/repository/freeipa/freeipa-server?tab=tags) are… unusual… and I couldn’t get the container to even start on TrueNAS. The TrueNAS documentation on FreeIPA integration is scant and you were not able to find other FreeIPA users here. I decided the universe was telling me not to use FreeIPA; maybe it is telling you the same. If you don’t have Active Directory, you can likely use a Samba Active Directory, and then join TrueNAS to the Samba Active Directory using the standard TrueNAS AD integration.
With whatever you choose, at the end you will need to install a keytab for TrueNAS that contains the nfs/truenas.server@REALM principal for NFSv4 to work. A Linux client also requires a keytab with host/linux.client@REALM principal, and then your user principal. A Mac client doesn’t require the keytab; just your user principal is sufficient, but kinit --keychain is helpful for storing your Kerberos password and keys in Keychain. If you have Macs in an office environment, you can deploy an integrated Kerberos SSO via MDM so users get keys automatically when they login and the keys are automatically refreshed.
Thank you for your detailed post. I will look into configuring TrueNAS with FreeIPA again, now I have more background info on how it should work.
I haven’t experienced any issues with setting up FreeIPA, since I chose to install it in its own Rocky Linux VM. I am even thinking about getting a RedHat Subscription to get support for IdM and asking them about Kerberos and NFSv4, since I currently don’t have the time to read the full documentation of both. Though, this wouldn’t help me directly with TrueNAS since I am pretty sure they won’t help me with that.
I am pretty set on using FreeIPA/RedHat IdM, because I need it for central user management for Linux server users and web portal logins. Currently, I am the only admin and user of my infrastructure, but I would like to set it up like a large corp would do. It would be nice to also use it for a synchronized home folder on the servers and better authentication, other than the IP based whitelist. Managing users and groups in TrueNAS and matching them to the application users on the Linux Server that need access to the data is becoming quite tedious.
Have you seen this re: LDAP not being a valid authentication service for SMB? I’m not sure if it also affects the integration with FreeIPA.
If so, a Samba Active Directory might be a better idea, and if you have Windows clients, it would have an administration experience like enterprises that use AD.
