ok, I tried to clean up and keep only one Target and one Associated Target.
I wasn’t aware it wasn’t good to have multiple extents for a single target. What would LUN ID be for otherwise?
At any rate, the clean up just killed the scst.service, but the GUI wouldn’t show anything abnormal.
/etc/scst.conf
HANDLER vdisk_fileio {
HANDLER vdisk_blockio {
DEVICE dockerhost {
filename /dev/zvol/FAST/iSCSI-dockerhost
blocksize 4096
read_only 0
usn c121b0651602135
naa_id 0x6589cfc000000eff46f0a247a2b7ca55
prod_id "iSCSI Disk"
rotational 0
t10_vend_id TrueNAS
t10_dev_id c121b0651602135
threads_num 32
DEVICE shareexisting {
filename /dev/zvol/backup/FAST-snapshot-backup/FAST/ubuntudockerhost-0vhbns
blocksize 4096
read_only 0
usn 539962f3cfb47c8
naa_id 0x6589cfc000000b16b51fe4a5e1eff8f2
rotational 0
t10_vend_id TrueNAS
t10_dev_id 539962f3cfb47c8
threads_num 32
DEVICE share-dockerhost {
filename /dev/zvol/backup/FAST-snapshot-backup/SSD0/containers-content
blocksize 4096
read_only 0
usn c553945fd86e8c9
naa_id 0x6589cfc0000003e7aa2fef8fa1052373
rotational 0
t10_vend_id TrueNAS
t10_dev_id c553945fd86e8c9
threads_num 32
DEVICE test {
filename /dev/zvol/SSD0/test
blocksize 4096
read_only 0
usn 7407dc34f71c5c6
naa_id 0x6589cfc0000007ad8f1d5be8e054b182
rotational 0
t10_vend_id TrueNAS
t10_dev_id 7407dc34f71c5c6
threads_num 32
TARGET_DRIVER iscsi {
enabled 1
link_local 0
TARGET iqn.2005-10.org.freenas.ctl:dockerhost {
rel_tgt_id 1
enabled 1
per_portal_acl 1
GROUP security_group {
INITIATOR *\#192.168.0.13
LUN 0 dockerhost
journalctl -xeu scst.service
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit scst.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Nov 26 21:04:37 freenas systemd[1]: scst.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit scst.service has entered the 'failed' state with result 'exit-code'.
Nov 26 21:04:37 freenas systemd[1]: Failed to start scst.service - LSB: SCST - A Generic SCSI Target Subsystem.
░░ Subject: A start job for unit scst.service has failed
░░ A start job for unit scst.service has finished with a failure.
░░ The job identifier is 147949 and the job result is failed.
Nov 26 21:17:23 freenas systemd[1]: Starting scst.service - LSB: SCST - A Generic SCSI Target Subsystem...
░░ Subject: A start job for unit scst.service has begun execution
░░ A start job for unit scst.service has begun execution.
░░ The job identifier is 148255.
Nov 26 21:17:23 freenas iscsi-scstd[2201022]: max_data_seg_len 1048576, max_queued_cmds 2048
Nov 26 21:17:24 freenas scst[2200950]: Loading and configuring SCST
Nov 26 21:17:24 freenas scst[2201114]: Collecting current configuration: done.
Nov 26 21:17:24 freenas scst[2201114]: -> Checking configuration file '/etc/scst.conf' for errors.
Nov 26 21:17:24 freenas scst[2201114]: -> Done, 0 warnings found.
Nov 26 21:17:24 freenas scst[2201114]: -> Applying configuration.
Nov 26 21:17:24 freenas scst[2201114]: -> Opening device 'dockerhost' using handler 'vdisk_blockio': done.
Nov 26 21:17:24 freenas scst[2201114]: -> Setting device attribute 'prod_id' to value 'iSCSI Disk' for device 'dockerhost': done.
Nov 26 21:17:24 freenas scst[2201114]: -> Setting device attribute 'threads_num' to value '32' for device 'dockerhost': done.
Nov 26 21:17:24 freenas scst[2201114]: -> Setting device attribute 'usn' to value 'c121b0651602135' for device 'dockerhost': done.
Nov 26 21:17:24 freenas scst[2201114]: -> Setting device attribute 'naa_id' to value '0x6589cfc000000eff46f0a247a2b7ca55' for device 'dockerhost': done.
Nov 26 21:17:24 freenas scst[2201114]: -> Setting device attribute 't10_vend_id' to value 'TrueNAS' for device 'dockerhost': done.
Nov 26 21:17:24 freenas scst[2201114]: -> Opening device 'share-dockerhost' using handler 'vdisk_blockio': done.
Nov 26 21:17:24 freenas scst[2201114]: FATAL: Received the following error:
Nov 26 21:17:24 freenas scst[2201114]: A fatal error occurred. See "dmesg" for more information.
Nov 26 21:17:28 freenas scst[2200950]: failed!
Nov 26 21:17:28 freenas systemd[1]: scst.service: Control process exited, code=exited, status=1/FAILURE
Nov 26 21:17:28 freenas systemd[1]: scst.service: Failed with result 'exit-code'.
Nov 26 21:17:28 freenas systemd[1]: Failed to start scst.service - LSB: SCST - A Generic SCSI Target Subsystem.
░░ The job identifier is 148255 and the job result is failed.
dmesg
[1212177.685706] [2200968]: dev_vdisk: Registering virtual vdisk_blockio device dockerhost (BLOCKIO)
[1212177.686797] [2200968]: dev_vdisk: Auto enable thin provisioning for device /dev/zvol/FAST/iSCSI-dockerhost
[1212177.686806] [2200968]: dev_vdisk: Attached SCSI target virtual disk dockerhost (file="/dev/zvol/FAST/iSCSI-dockerhost", fs=61440MB, bs=4096, nblocks=15728640, cyln=7680)
[1212177.687025] [2200968]: scst: Added device dockerhost to group copy_manager_tgt (LUN 0, flags 0x4) to target copy_manager_tgt
[1212177.687047] [2200968]: scst: Attached to virtual device dockerhost (id 1)
[1212177.758419] [2200968]: scst: Changed cmd threads num to 32
[1212177.758661] [2201069]: dev_vdisk: USN for device dockerhost changed to c121b0651602135
[1212177.759227] [2200968]: dev_vdisk: Registering virtual vdisk_blockio device share-dockerhost (BLOCKIO)
[1212177.761257] [2200968]: dev_vdisk: ***WARNING***: Device /dev/zvol/backup/FAST-snapshot-backup/SSD0/containers-content doesn't support barriers, switching to NV_CACHE mode. Read README for more details.
[1212177.774932] [2200968]: dev_vdisk: Auto enable thin provisioning for device /dev/zvol/backup/FAST-snapshot-backup/SSD0/containers-content
[1212177.774953] [2200968]: dev_vdisk: Attached SCSI target virtual disk share-dockerhost (file="/dev/zvol/backup/FAST-snapshot-backup/SSD0/containers-content", fs=61440MB, bs=4096, nblocks=15728640, cyln=7680)
[1212177.775274] [2200968]: scst: ***ERROR***: Device handler's vdisk_blockio attach_tgt() failed: -30
[1212177.775734] [2200968]: dev_vdisk: Detached virtual device share-dockerhost ("/dev/zvol/backup/FAST-snapshot-backup/SSD0/containers-content")
Removing Extent share-dockerhost on the GUI and systemctl start scst.service didn’t make any diffrence, error was the same.
CLI removing share-dockerhost from /etc/scst.conf, restarting service the isseu was the same with next Extent in line shareexisting
Removing from GUI, didn’t made any change to scst.conf
CLI removing from scst.conf and restart scst.service did manage to get the service started without error.
And this time, from a VM:
$ iscsi-ls -s iscsi://192.168.0.13
Target:iqn.2005-10.org.freenas.ctl:dockerhost Portal:192.168.0.13:3260,1
Lun:0 Type:DIRECT_ACCESS (Size:59G)
These Extent where made from Devices that showed up on the GUI a selectable device. I intentionally selected device that were from Replicated Tasks, Zvol snapshots replicated.
Wanted to test a way to boot a Proxmox VM from a Truenas VM zvol snapshot replica,
Is there any reason this failed? Why would these be selectable from the Device dropbox when cretaing an Extent?
Further testing iSCSI share, everything worled as expected.
Adding a test Target and Associated Target with Extent test worked:
LUN ID being 0 or 1:
Target:iqn.2005-10.org.freenas.ctl:test Portal:192.168.0.13:3260,1
Lun:1 Type:DIRECT_ACCESS (Size:19G)
or
Lun:0 Type:DIRECT_ACCESS (Size:19G)
and even two Associated Target on the same target:
and then I can see them on Proxmox accordingly.
Why is multiple LUN on a Target is discouraged?
