Hi, I have a Linux host:
root@automator-1:/# uname -a
Linux automator-1 5.15.0-102-generic #112-Ubuntu SMP Tue Mar 5 16:50:32 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
root@automator-1:/# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
And it mounts shares on two different TrueNAS Scale hosts:
root@automator-1:/# cat /etc/fstab|grep cifs
//192.168.1.252/archief /mnt/archief cifs credentials=/etc/wachtrij.cred,uid=1001,gid=1001,vers=3.0 0 0
//192.168.1.250/processing /mnt/automator-2 cifs credentials=/etc/wachtrij.cred,uid=1001,gid=1001,vers=3.0 0 0
<snip> a bunch more like these..</snip>
Since this morning we have been having unreliable SMB connections. Reading/writing files often fail, like for example this one:
BlockingIOError: [Errno 11] Resource temporarily unavailable: '/mnt/automator-2/P-Overige/<customer-information>.jpg'
Since this has started it can’t do more than a hundred or so operations before it will encounter such an error.
I am pretty sure this is a hardware error, probably in the Linux host, since it’s both the oldest and it has the problem with both the TrueNAS hosts, and I haven’t configured any automatic upgrades, and no software changes were introduced in the past week or so.
There is a non-zero amount of errored packets in netstat -i
, but it’s less than a tenth of a %, and SMB is on top of TCP, so this shouldn’t have had any effect.
When I look in the dmesg -T
I see a constant stream of:
[Mon Apr 15 17:30:29 2024] CIFS: VFS: \\192.168.1.252\archief validate protocol negotiate failed: -11
[Mon Apr 15 17:30:38 2024] CIFS: VFS: \\192.168.1.250\IPC$ validate protocol negotiate failed: -11
[Mon Apr 15 17:30:39 2024] CIFS: VFS: \\192.168.1.250\IPC$ validate protocol negotiate failed: -11
[Mon Apr 15 17:30:39 2024] CIFS: VFS: \\192.168.1.252\IPC$ validate protocol negotiate failed: -11
[Mon Apr 15 17:30:39 2024] CIFS: VFS: \\192.168.1.252\archief validate protocol negotiate failed: -11
I googled that error message, but no one on the internet has had it since a kernel bug was fixed in 2017. All my systems are either the latest version of TrueNAS Cobia, or an up to date Ubuntu 22.04 LTS.
I have rebooted all involved systems, as well as all the networking hardware involved.
Anyone know what could be causing these weird SMB protocol failures? Even if it’s a hardware problem, I don’t get how it would persist in the exact same way across reboots. But I also don’t understand how it would suddenly happen despite there being no updates installed in the past week.
