Various check after Scale migration
Hi all, as probably many other i just migrate from Core 13.3 to Scale 24.10.
I followed the migration path tips provided on documentation, i backup all data on another system, and after a fresh install → config upload, only minor settings change were needed.
So far so good, and i start to migrate apps (all previously hosted on docker): honestly was a bit confused by installing apps from the catalogue GUI (just mine habit problem), so i start putting my yaml directly as custom app; all good except for photoprism, that fail because i have various volumes pointing as subfolder on the original… But using the same exactly yaml on Portainer works as expected.
Another problem Is on a replication task (inherited from Core) that warn me like this, and i have no idea why.
Is just a pool dayli replication to the “apps” pool to the storage one, running smoothly from months.
Also, can i delete safely iocage dataset?
I also realised i have a monitor dashboard for UPS but It show anything…
There other things to check before can consider this migration done succesfully?
