Hi there, i need some help from the experts.
After a power outage the other day, my VM’s will not start. i get the following error:
CallError
[EFAULT] This system does not support virtualization.
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 184, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1317, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1247, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1379, in nf
File "/usr/lib/python3/dist-packages/middlewared/service.py", line 927, in query
result = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1368, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 165, in query
result = await self._queryset_serialize(
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 213, in _queryset_serialize
extend_context_value = await self.middleware.call(extend_context, rows, extra_options)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1328, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1231, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 100, in extend_context
self._check_setup_connection()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 71, in _check_setup_connection
self._check_connection_alive()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 64, in _check_connection_alive
self._system_supports_virtualization()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 61, in _system_supports_virtualization
raise CallError('This system does not support virtualization.')
middlewared.service_exception.CallError: [EFAULT] This system does not support virtualization.
Any suggestions are greatly appreciated.
Thanks
