Weird performance using excessive hardware
Ok this one is bugging me to the point I am making a post to see if anyone has ideas as it really makes no sense.
On the top level my performance is ridiculously slow in relation to everything involved. I am only able to achieve just under 600MB/s using any setting or configuration I can think of. I have gone as far as nuking the turenas install and pool but got the same results.
System Overview
  • TrueNAS SCALE Version: 25.04.2.1
  • Storage Pool: 16× NVMe drives (currently in a striped vdev for testing; previously RAIDZ1)
  • Network Interfaces:
    • 25 GbE on Windows 11 test client (AMD 7950X)
    • 100 GbE on Linux test client
  • Test Clients:
  1. Windows 11 machine with 7950X and 25 GbE NIC
  2. Linux box with 100 GbE NIC
Full hardware and software details are in my forum signature.
Problem Description
Despite eliminating any vdev bottlenecks (using a full stripe), SMB throughput tops out just under 600 MB/s. This same ceiling appeared when the pool was configured as RAIDZ1, and persists across fresh OS and pool rebuilds.
Steps Taken to Troubleshoot
  1. Reinstalled TrueNAS SCALE and recreated the pool from scratch
  2. Converted the pool from RAIDZ1 to a single stripe of 16 drives
  3. Verified network performance with iperf3:
  • 25 GbE link saturates at ~24 Gb/s
  • 100 GbE link saturates bidirectionally at ~86 Gb/s
  1. Ran fio on the NAS itself to isolate storage stack: ~2,500 MB/s (appears single thread-bound)
Observed Performance
  • SMB writes (Windows → NAS): ~580 – 600 MB/s
  • SMB reads (Windows ← NAS): ~580 – 600 MB/s
  • iSCSI writes/reads (Windows) : ~580 – 600 MB/s (identical to SMB)
  • iperf3 (network-only): full line rate on both 25 GbE (~24 Gb/s) and 100 GbE (~86 Gb/s)
  • fio (local, random/sequential tests): up to ~2,500 MB/s
I am open to any suggestions and have it torn apart for testing so I have no issues with destructive testing.
I would expect your beefy infrastructure to be more than capable of saturating those links. Between on-NAS confirming high throughput (with random data, right?) and the network showing very high throughputs, I wonder if there is a misconfiguration going on somewhere.
For example, is SMB sync = always required? I would not think it would have a significant impact on an all flash system… but maybe it does? Also, did you confirm that your flash drives aren’t using a fast cache up front followed by a slow drive in the rear, which choke under sustained loads?
Also, is there some way of making two flows happen at once? (Ie add a third machine to the mix, then hammer the server with two SMB sessions of incompressible data at the same time). The reason I ask is that SMB is a single-threaded process.
If your CPU cannot keep up, you might see a doubling of transfer rates (2x 600MB/s) since everything else in the environment seems to be performant. Given your system specs, that seems somewhat of a remote possibility, however.
Thanks for the reply. I don’t think it is SMB related as I have also tested isci and nfs and both are the same. As for single thread overload I tested fio and could get about 2500MB/s before maxing a single thread out. For all the isci, smb, and nfs test the system is idling. No cores over 5% and the disk are at 30MB/s each.
Still no closer to solving but I did encounter an interesting result. I have been trying to remove anything between the array and the test fio (slog, l2arc, arc) and got something interesting. When doing writes (primarycache=none) I am getting the expected speed of 2500~ but when testing read under the same conditions I am getting a much lower number of 610. Per drive utilization falls down into the 30~ acting much like the external testing but now on the local array. As before the CPU is fine with one thread never maxing out. Honestly this just confuses me more as reads should, in theory, be better than writes.
root@truenas[/mnt/Stripe/NFS]# fio --ramp_time=5 --gtod_reduce=1 --numjobs=1 --bs=1M --size=200G --runtime=60s --readwrite=read --name=testfile
testfile: (g=0): rw=read, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=psync, iodepth=1
fio-3.33
Starting 1 process
testfile: Laying out IO file (1 file / 204800MiB)
Jobs: 1 (f=1): [R(1)][100.0%][r=478MiB/s][r=478 IOPS][eta 00m:00s]
testfile: (groupid=0, jobs=1): err= 0: pid=45586: Thu Aug 28 09:41:42 2025
read: IOPS=582, BW=582MiB/s (610MB/s)(34.1GiB/60030msec)
bw ( KiB/s): min=182272, max=860160, per=100.00%, avg=596106.19, stdev=226910.09, samples=120
iops : min= 178, max= 840, avg=582.01, stdev=221.63, samples=120
cpu : usr=0.15%, sys=50.57%, ctx=35086, majf=0, minf=37
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued rwts: total=34942,0,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
READ: bw=582MiB/s (610MB/s), 582MiB/s-582MiB/s (610MB/s-610MB/s), io=34.1GiB (36.6GB), run=60030-60030msec
Also I am just now seeing a typo in the main post but I can’t find a way to edit. The 16-16TB drives in the array are NOT nvme but mechanical. The slog, l2, and all clients are pure nvme. This is critical as an nvme array of that size would definitely be maxing out the cpu but mechanical is just fine.
I simply can not figure this one out. Since my last post I got on a rabbit trail of thinking it was the HBA so I swapped in a much older raid card to test. I still get the same results though. Without any cache enabled the array is a minimum 2.5GB’s RW. This makes me think the array is good and the HBA was fine. I have tested a few endpoints and no matter if it is SMB, NFS, or iscsi my results are always at 400-600MB’s with cache enabled or disabled. Each of the endpoints have native disk speeds in the 6-7GB’s range so I don’t think that is the bottle neck. Additionally I did a point to point connection with an endpoint and the server (at a lower speed of 10g) and still got the same 400MB’s speed.
I feel like each part in isolation is working but I am missing some critical bit of information somewhere.
I’m not a specialist, but it looks like a synchronous operation.
Also, I would suggest:
  1. Directly connect your windows or/and linux box to the truenas. Thus eliminating the possibility of switch misconfiguration.
  2. Running SMB read or write simultaneously on both windows and linux and measure the total throughput. Perhaps you would need a switch for this again.
Some questions:
  1. How do you exactly measure SMB performance on linux and windows?
  2. Are client storages fast enough to saturate more than 600MB/s? 600MB/s looks suspiciously close to the max bandwidth of SATA SSD…
Unfortunately the thread is a bit of a mess. To answer some of the questions already posted.
  • Direct connection has the same speed.
  • All client devices storage exceeds 7GB/s RW
  • Have tested SMB, NFS, and isci all have the same speed
  • Tested alternate HBA but performance was identical
  • When testing the file transfers the per disk usage is around 20MB/s
  • When testing local the per disk usage is around 250MB/s
  • CPU is not taxed in any way even single thread
  • Multiple clients receive the same individual speed
I remain perplexed on this one. Even pulling directly from L1 the speed is unchanged.
And what about combined speed?
Silly question, but do you happen to have a sata or sas L2ARC drive in there?
This is interesting as I have similar caps on my system also with a 4 drive NVMe set up I use as an NFS share for VMs, my original thread on the old forums:
Negative the l2 is comprised of pure nvme. All four of the stripe nvme drives are identical pcie 4.0 disk.
If I am reading your post correctly your speed vastly exceeds what I am getting on my setup. For local only storage everything seems to be working, ie the mechanical array is in line and if allowed to test arc it delivers arc speeds. But the moment it moves over the network something breaks, badly. I just can’t figure it out as the two test iperf and fio show no issues. This indicates that the network is good and the storage is good. My current idea is to swap the 100g network card for a lower speed card on the off chance there is a bug in truenas with this card past that I have nothing left.
Ya, it is something to chase. I later did see that it appeared that the ZFS process for me was doing spikes to 100% on a single core, almost like it was buffering something and causing things to spike. From my workstation end I would see fast speeds, then drop to 0MB/s then spike backup.
I do need to dig into it again myself one of these days, I hate not getting full performance 100% of the time on systems.
I may have figured this out. If I did I deserve the largest dunce hat in existence. Its 5am (insomnia hitting hard) so I want to validate my data again later but it seems a bios update swapped my pcie lane mappings on the server. This resulted in the 100G nic be starved for cpu communication using a 4x connection rather than 16x. I can only assume that iperf is so light that it is able to give a nic saturation without really hitting the pcie lanes.
Action items:
  • Bring render or AI servers online and test end to end 100G
  • Revalidate workstation 25G results
Things that bother me right now.
  • Iperf is very confusing with full speed results even with the error
  • iscsi results still glacial when compared to SMB
What’s the VDEV layout of the hard drives? Those speeds look about right for a single RAIDZ2 volume. Did you try a 2x RAIDZ2 vdev pool, that should get you some better write speeds.
This is a good starting place for understanding vdevs
https://www.truenas.com/solution-guides/#TrueNAS-PDF-zfs-storage-pool-layout/3/
I am going to call this one resolved. While there are still some remaining questions about total performance of the array the very specific issue I was having with the exact data throughput cap was caused by a hardware issue on the pcie interface for the NIC that cut the lanes from x16 down to x4.
I can now read and write at ~ the speed of the mechanical array 2500MBs
There remain a number of questions about why despite having a large amount of ram and L2 ssd’s the performance does not reflect this. If I find any data that can help clarify this I will open a new thread to discuss that as I find it a separate topic from this original issue.
It should help only with reads. By default RAM/ARC can hold up to 5GB of dirty (async writes) data. So your burst writes should be very fast.
At just a 1G burst test I still max out at 2400MBs. This is why I can’t shake the feeling that something is bugged. I will have to do more digging as all the parts are on hand to make this work but it is struggling.
You can try to tweak these parameters (I was wrong; it is 4GB by default). Also, there are time restrictions (parameters) for dirty data – you probably would need to tweak them as well. But perhaps you need a good reason for doing that.
I mean, if 4G is not enough for burst, what would be enough? Do you need all your RAM as a write cache? If you really need sustained big and fast writes, you should probably just use NVMe’s pool (although I’m a bit confused about what you are using right now and what your pool layout is).
