When creating DataSet I get 'CallError'
ElectricEel-24.10.1
In browser I go to the ‘Datasets’ and ‘Add Dataset’.
I enter the name of new dateset and click ‘Save’.
Then I get an error.
CallError
[EFAULT]
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 211, in call_method
    result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1529, in call_with_audit
    result = await self._call(method, serviceobj, methodobj, params, app=app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1460, in _call
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 230, in create
    return await self.middleware._call(
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 261, in nf
    rv = await func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 49, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 179, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset.py", line 797, in do_create
    await acl_job.wait(raise_error=True)
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 457, in wait
    raise self.exc_info[1]
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 509, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 556, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1367, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/acl.py", line 890, in setacl
    return self.setacl_nfs4(job, data)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/acl.py", line 602, in setacl_nfs4
    self.setacl_nfs4_internal(path, data['dacl'], do_canon, verrors)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/acl.py", line 554, in setacl_nfs4_internal
    raise CallError(setacl.stderr.decode())
middlewared.service_exception.CallError: [EFAULT]
Can you post output of midclt call core.get_jobs | jq? It looks like we’re trying to inherit an invalid ACL.
