Hi All,
I just recently acquired a X10SDV-TLN4F (without fan). It’s my first time with TrueNAS and Supermicro.
I tried to boot the system, it more or less works until the speaker just buzzes all the time. I had not time to install anything yet. Once I unplug the board if I try to start again no output is shown and two leds (green and red) are blinking continuously. I waited the night and tried again and booted properly until buzzing. Therefore I suspect it might be related with a temperature problem. Did you have any experience similar to me ?
In the other side, I am looking for a case. I saw most of you use the Node 304. Did any of you try the Jonsbo N1 Mini-ITX ?, I guess I’ll have far more problems with temperature …
I will need a TPM unit. Do you have any recommendation ?
Regards
