ZFS Labels - What are they and why do I care
This is a community resource that is not officially endorsed by, or supported by iXsystems/TrueNAS. Instead it is a personal passion project, and all of my opinions are my own.
There have been a bunch of failures recently that indicate missing or corrupt ZFS labels. I started answering questions about what they are in-line, but realized that a separate post dedicated to ZFS labels was probably a good reference.
I am going to use the word disk to refer to a zpool component even though they might be disks, partitions, virtual disks, really any block device could be used.
To examine your ZFS labels you first need to identify the disks used by the zpool. Using the TrueNAS user interface click on the Manage Devices button on the Topology brick for the zpool you are looking at. If you have not been able to import the zpool, then you will have to determine the disk device names by looking in /dev for disk devices (sda, sdb, etc.) and their partitions (sda1, sda2, etc.). TrueNAS (as of 25.04) uses partition 1 for non-OS disks, so you will be looking for /dev/sda1, /dev/sdb1, etc.).
To get to a command line, go to System → Shell in the TrueNAS user interface. Use the command sudo /sbin/zdb -l /dev/sda1 where sda1 is the disk you are looking at to examine the ZFS labels on that disk (partition).
NOTE: /sbin/zdb is an overall ZFS debugger. You can do severe damage to a zpool through incorrect usage. Do not just start trying random /sbin/zdb commands and options! /sbin/zdb locks the zpool it is working on, even if just reading data, to ensure consitency, if you are reading lots of data you may block access to the zpool for long enough that I/O may start to timeout. A /sbin/zdb -l should return fast enough to not worry about it (too much), but pulling other data will take longer, potentially much longer.
Here are a sample labels from a 2 x 4xRAIDz2 zpool with both SLOG, L2ARC and hot spares to illustrate the majority of what you will see in a ZFS label, but first a screen shot of the Topology brick from the TrueNAS Dashboard.
The first RAIDz2 vdev
admin@xxx[~]$ sudo /sbin/zdb -l /dev/sdad1
LABEL 0
    version: 5000 <-- base ZFS dataset version
    state: 0
    txg: 21894  <-- most recent committed Transaction Group (TXG)
    pool_guid: 8306720220591971624
    errata: 0
    hostid: 1046909542
    hostname: 'xxx'
    top_guid: 8182871320855948967
    guid: 12752186334501239742
    hole_array[0]: 2
    vdev_children: 4
    vdev_tree: <-- since ZFS stripes accross all top level vdev there is indication as to type of vdev in the global section
        type: 'raidz' <-- when we enter the vdev we see the vdev type
        id: 0 <-- and it's position relative to the other top level vdevs
        nparity: 2 <-- this identifies this as a 2 parity RAIDz
        metaslab_array: 155
        metaslab_shift: 34
        ashift: 12
        asize: 7992986566656
        is_log: 0
        create_txg: 4 <-- the TXG that committed the creation of this vdev
        children[0]: <-- first component of this vdev
            type: 'disk'
            path: '/dev/disk/by-partuuid/a07f7413-3bab-4341-bd46-90b4be6ec160'
            whole_disk: 0 <-- indicates that this is not the entire disk, but in this case a partition
            create_txg: 4
        children[1]:
            type: 'disk'
            guid: 12263111496817576784
            path: '/dev/disk/by-partuuid/968f6293-43e5-41e5-a667-037f3a913cd1'
            whole_disk: 0
            create_txg: 4
        children[2]:
            type: 'disk'
            guid: 7688501057607157299
            path: '/dev/disk/by-partuuid/a1c2f1d9-c9db-4f14-a522-9a67ea89431b'
            whole_disk: 0
            create_txg: 4
        children[3]:
            type: 'disk'
            guid: 6828939413129632038
            path: '/dev/disk/by-partuuid/893bb901-f633-4199-977a-cd30f72d27e7'
            whole_disk: 0
            create_txg: 4
    features_for_read: <-- feature flags that effect read operations
        com.delphix:hole_birth
        com.delphix:embedded_data
        com.klarasystems:vdev_zaps_v2
    labels = 0 1 2 3 <-- at which positions did I find this label
admin@xxx[~]$
The second RAIDz2 vdev
Much the same as the first, differences indicated below.
admin@xxxx[~]$ sudo /sbin/zdb -l /dev/sdb1
LABEL 0
    version: 5000
    state: 0
    txg: 21894
    errata: 0
    hostid: 1046909542
    hostname: 'xxx'
    top_guid: 6761566294553582256
    guid: 9294818102476701863
    hole_array[0]: 2
    vdev_children: 4
    vdev_tree:
        type: 'raidz' <-- you can see how the type of each vdev can be different
        id: 1 <-- this vdev is in the second position (0 is first position)
        nparity: 2
        metaslab_array: 145
        metaslab_shift: 34
        ashift: 12
        is_log: 0
        create_txg: 4
        children[0]:
            type: 'disk'
            guid: 15631385997839139037
            path: '/dev/disk/by-partuuid/ef214a32-6ae4-492e-b0e2-e27c3d52129b'
            whole_disk: 0
            create_txg: 4
        children[1]:
            type: 'disk'
            guid: 500392086168322762
            path: '/dev/disk/by-partuuid/05398324-c01e-4a7b-8db0-54f9df580e97'
            whole_disk: 0
            create_txg: 4
        children[2]:
            type: 'disk'
            path: '/dev/disk/by-partuuid/fd1c11d4-8c5f-4051-ae95-240a9506a898'
            whole_disk: 0
            create_txg: 4
        children[3]:
            type: 'disk'
            guid: 10873913273110761404
            path: '/dev/disk/by-partuuid/4ac7491b-550d-47d7-89d3-a65e0b06d0cb'
            whole_disk: 0
            create_txg: 4
    features_for_read:
    labels = 0 1 2 3
admin@xxx[~]$
The L2ARC (read cache) vdev
admin@xxx[~]$ sudo /sbin/zdb -l /dev/sdl1
LABEL 0
    version: 5000
    state: 4 <-- I assume this identifies this device as an L2ARC
    guid: 2228300738575578825
    ashift: 12
    path: '/dev/disk/by-partuuid/31dfc96d-1d6f-41d2-96b7-e3f20f0a8c38'
    labels = 0 1 2 3
L2ARC device header
    magic: 6504978260106102853
    version: 1
    flags: 1
    start_lbps[0]: 0
    start_lbps[1]: 0
    log_blk_ent: 1022
    start: 4198400
    end: 477955096576
    evict: 4198400
    lb_asize_refcount: 0
    lb_count_refcount: 0
    trim_action_time: 1748551131
    trim_state: 2
L2ARC device log blocks
No log blocks to read
admin@xxx[~]$
The SLOG (write accelerator) vdev
admin@xxx[~]$ sudo /sbin/zdb -l /dev/sdu1
LABEL 0
    version: 5000
    state: 0
    txg: 21895
    errata: 0
    hostid: 1046909542
    hostname: 'xxx'
    top_guid: 15363572077989720144
    is_log: 1 <-- identifies this as a SLOG device
    hole_array[0]: 2
    vdev_children: 4
    vdev_tree: <-- since you can have mirroed SLOG the vdev type needs to be identified
        type: 'disk'
        path: '/dev/disk/by-partuuid/1e016cb4-515d-4d46-83fc-4cdf42f893e6'
        whole_disk: 0
        metaslab_array: 1162
        metaslab_shift: 30
        ashift: 12
        asize: 198044024832
        is_log: 1
        create_txg: 21893
    features_for_read:
    labels = 0 1 2 3
admin@xxx[~]$
The hot spare vdevs
admin@xxx[~]$ sudo /sbin/zdb -l /dev/sdd1
LABEL 0
    version: 5000
    state: 3 <-- I assume this identifies this as a hot spare
    guid: 13909808474772480724
    path: '/dev/disk/by-partuuid/188d232b-93aa-4a07-9986-dcc4d5bc0a97'
    labels = 0 1 2 3
admin@xxx[~]$ sudo /sbin/zdb -l /dev/sde1
LABEL 0
    version: 5000
    state: 3
    guid: 4206175843085097119
    path: '/dev/disk/by-partuuid/a6e88d24-f4d0-4561-99ba-63e9e971ee1e'
    labels = 0 1 2 3
admin@xxx[~]$
ZFS labels are written to the start and end of each disk used by ZFS. There are 4 copies for redundancy, 2 at the start (labels 0 and 1) and 2 at the end (labels 2 and 3). Each label has enough information to assemble this disk into the vdev it is a member of, including identifying where it fits in the vdev as well as all the other disks in the vdev. Each label knows nothing about other vdevs in the zpool, although there is positional information, so some information about other vdevs may be inferred.
The zpool and all it’s disks are identified via unique identifiers so that duplicate names do not confuse it and so that when disks change OS device names ZFS can still figure out which is which. If you want to import a zpool and there are duplicate zpool names, then you import by unique identifier and if a zpool of the same name is already imported, assign the zpool a new name.
When Things go Wrong
There are a variety of things that can go wrong with a zpool. If you cannot import a zpool then looking at all of the ZFS labels can provide a clue with what is wrong and possibly provide a path to recovery. While I ask questions here, I am not providing solutions as every case is different and doing the wrong thing can lead to data loss! Gather the information the questions below ask and then ask for help on the TrueNAS Forums.
  • Do you have all 4 ZFS labels?
    • If not, then which are missing?
      • 0 and 1 from the start of the disk?
        • What might have overwritten the beginning of the disk (partition)?
      • 2 and 3 from the end of the disk?
        • What might have overwritten the end of the disk (partition)?
  • Are any of them flagged as corrupt?
    • Are they all corrupt or only some of them?
  • Do the txg values match on all labels?
    • If not, then a disk with a lower txg was not updated when later txg were committed, this can give you a timeline of when which disk was unreachable.
I recall it is not quite that. The label has enough information to assemble the vdev this disk (the disk containing the label) belongs to, but not the entire pool. There is an error code telling you essentially “some disks are missing, but I don’t know what exactly is missing”. This happens when the entire vdev is lost (that is, not one disk is available from the vdev), normally happens if something like a disk shelf disconnects, taking multiple drives with it at the same time.
That is correct, I’ll phase it better.
The data is broken down by vdev. Each vdev component has enough information reassemble that vdev, but knows nothing about other vdevs in the zpool.
