I think I’m correct in saying that TNS and ZFS utilises disk IDs, rather than device names, for vdev/pool membership, right? So, in theory, I could shut the server down, shuffle the disks into new slots, boot up and all the vdevs, pools and datasets would be fine.
However, I note that when I run ‘zpool status’ from the command-line, my mirror-0 boot pool is listed using device names (in my case sda and sdb).
Is this because the system has to boot off /dev/sda before it’s started the ZFS service, and it only becomes mirrored (and, I guess, read/write) once it’s booted far enough to run ZFS?
Would I also be correct on thinking that, as this zpool is defined using device names, I cannot physically move those disks? (Well, I could, but it would break things)
I’ve stuck labels on those two disk caddies for now so I know what they are and where they should be located.
