Hi, I’ve setup snapshots for my dataset every 5 minutes, between specific hours (9AM to 10PM). I have setup truenas to keep them for 4 hours. The snapshot task is running ok, snapshots are created every 5 mins and deleted after 4 hours.
Problem is with the snapshots that should be deleted after 10AM, i.e all snapshots created after 6PM. These are not deleted.
This is the first day I run this snapshot task, so my guess is that since it got past 10PM, the task is stopped, thus these snapshots will be deleted tomorrow, when the task runs again.
As you see the hourly snapshot task (which actually takes snapshots every 5 mins, between 9:00 to 22:00) everyday, is active and runs right now. Yet, one snapshot from this task is still there.
Doesn’t make sense to me. (My local time is 13:20 2024-06-23 now)
EDIT: I just found a bug in the display of the “Last Run” in the 1st screenshot for my “every 5 mins” snapshot task. When the task is about to run in 1 min, the Last Run says “in 1 min.” instead of “4 mins ago”. This is a bug in that screen only, as the task actually runs fine every 5 mins.
