I just moved appartments and after trying to start my media server based on TrueNAS Scale, my main VM and its storage is missing.
What I’ve done:
- Server shutdown
- Changed network settings (new gateway, new bridge device IPs, new DNS server address)
When I tried to bring my VM back online, I noticed this error:
[EFAULT] VM will not start as DISK Device: /dev/zvol/VMs/debian-lzbp5 device(s) are not available.
Taking a look at the dashboard, I can see that the “VMs” Pool is offline. If I click on “Manage Devices”, I get an empty list.
I’ve set this server up quite a while ago and don’t even remember which disk this was on, but I’m sure the pool only contained one disk. Here’s my disk layout:
root@truenas[~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 3.6T 0 disk
└─sda1 8:1 0 3.6T 0 part
sdb 8:16 0 3.6T 0 disk
└─sdb1 8:17 0 3.6T 0 part
sdc 8:32 0 3.6T 0 disk
└─sdc1 8:33 0 3.6T 0 part
nvme0n1 259:0 0 232.9G 0 disk
├─nvme0n1p1 259:1 0 1M 0 part
├─nvme0n1p2 259:2 0 512M 0 part
├─nvme0n1p3 259:3 0 216.4G 0 part
└─nvme0n1p4 259:4 0 16G 0 part
└─nvme0n1p4 253:0 0 16G 0 crypt
Output of some commands that might be useful:
root@truenas[~]# zpool status
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:07 with 0 errors on Fri Sep 6 03:45:08 2024
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
nvme0n1p3 ONLINE 0 0 0
errors: No known data errors
pool: media-storage
state: ONLINE
scan: scrub repaired 0B in 03:23:01 with 0 errors on Sun Aug 18 03:23:02 2024
media-storage ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
08a9c883-6b8f-4995-a85e-6122b57f15a2 ONLINE 0 0 0
e54a5bd7-a43b-4cf6-bb4a-9e1a7ce01462 ONLINE 0 0 0
aeb6fe6a-427b-48dd-828b-9151de69298c ONLINE 0 0 0
root@truenas[~]# zpool import
no pools available to import
root@truenas[~]# zfs list
NAME USED AVAIL REFER MOUNTPOINT
boot-pool 12.3G 197G 96K none
boot-pool/ROOT 12.2G 197G 96K none
boot-pool/ROOT/23.10.2 4.93G 197G 4.92G legacy
boot-pool/ROOT/24.04.1.1 2.39G 197G 164M legacy
boot-pool/ROOT/24.04.1.1/audit 308K 197G 308K /audit
boot-pool/ROOT/24.04.1.1/conf 140K 197G 140K /conf
boot-pool/ROOT/24.04.1.1/data 100K 197G 284K /data
boot-pool/ROOT/24.04.1.1/etc 6.71M 197G 5.66M /etc
boot-pool/ROOT/24.04.1.1/home 0B 197G 132K /home
boot-pool/ROOT/24.04.1.1/mnt 104K 197G 104K /mnt
boot-pool/ROOT/24.04.1.1/opt 74.1M 197G 74.1M /opt
boot-pool/ROOT/24.04.1.1/root 8K 197G 164K /root
boot-pool/ROOT/24.04.1.1/usr 2.12G 197G 2.12G /usr
boot-pool/ROOT/24.04.1.1/var 33.5M 197G 32.0M /var
boot-pool/ROOT/24.04.1.1/var/ca-certificates 96K 197G 96K /var/local/ca-certificates
boot-pool/ROOT/24.04.1.1/var/log 576K 197G 56.8M /var/log
boot-pool/ROOT/24.04.2 2.39G 197G 164M legacy
boot-pool/ROOT/24.04.2.2 2.49G 197G 164M legacy
boot-pool/ROOT/24.04.2.2/audit 424K 197G 424K /audit
boot-pool/ROOT/24.04.2.2/conf 140K 197G 140K /conf
boot-pool/ROOT/24.04.2.2/data 776K 197G 284K /data
boot-pool/ROOT/24.04.2.2/etc 6.63M 197G 5.66M /etc
boot-pool/ROOT/24.04.2.2/home 300K 197G 132K /home
boot-pool/ROOT/24.04.2.2/mnt 96K 197G 96K /mnt
boot-pool/ROOT/24.04.2.2/opt 74.1M 197G 74.1M /opt
boot-pool/ROOT/24.04.2.2/root 388K 197G 164K /root
boot-pool/ROOT/24.04.2.2/usr 2.12G 197G 2.12G /usr
boot-pool/ROOT/24.04.2.2/var 128M 197G 31.0M /var
boot-pool/ROOT/24.04.2.2/var/ca-certificates 96K 197G 96K /var/local/ca-certificates
boot-pool/ROOT/24.04.2.2/var/log 96.5M 197G 39.5M /var/log
boot-pool/ROOT/24.04.2/audit 700K 197G 700K /audit
boot-pool/ROOT/24.04.2/conf 140K 197G 140K /conf
boot-pool/ROOT/24.04.2/data 132K 197G 280K /data
boot-pool/ROOT/24.04.2/etc 6.65M 197G 5.65M /etc
boot-pool/ROOT/24.04.2/home 84K 197G 132K /home
boot-pool/ROOT/24.04.2/mnt 104K 197G 104K /mnt
boot-pool/ROOT/24.04.2/opt 74.1M 197G 74.1M /opt
boot-pool/ROOT/24.04.2/root 96K 197G 164K /root
boot-pool/ROOT/24.04.2/usr 2.12G 197G 2.12G /usr
boot-pool/ROOT/24.04.2/var 32.7M 197G 31.2M /var
boot-pool/ROOT/24.04.2/var/ca-certificates 96K 197G 96K /var/local/ca-certificates
boot-pool/ROOT/24.04.2/var/log 432K 197G 37.3M /var/log
boot-pool/ROOT/Initial-Install 8K 197G 2.33G /
boot-pool/grub 8.20M 197G 8.20M legacy
media-storage 2.41T 4.73T 40.7G /mnt/media-storage
media-storage/.system 1.49G 4.73T 1.23G legacy
media-storage/.system/configs-ae32c386e13840b2bf9c0083275e7941 16.7M 4.73T 16.7M legacy
media-storage/.system/cores 128K 1024M 128K legacy
media-storage/.system/ctdb_shared_vol 128K 4.73T 128K legacy
media-storage/.system/glusterd 139K 4.73T 139K legacy
media-storage/.system/netdata-ae32c386e13840b2bf9c0083275e7941 248M 4.73T 248M legacy
media-storage/.system/rrd-ae32c386e13840b2bf9c0083275e7941 128K 4.73T 128K legacy
media-storage/.system/samba4 943K 4.73T 352K legacy
media-storage/.system/services 128K 4.73T 128K legacy
media-storage/.system/webui 128K 4.73T 128K legacy
media-storage/media-nfs 2.26T 4.73T 2.26T /mnt/media-storage/media-nfs
media-storage/windows-smb 104G 4.73T 104G /mnt/media-storage/windows-smb
Does anyone have an idea how to get my VM data back?
EDIT: Just noticed I was smart enough to implement a periodic snapshot task for the dataset. I’ve never worked with these snapshots, but I should be able to recover the data from them, right?
