25.04.2.4.2 causes system to shutdown at exactly 30 minutes
I just upgraded from 24.04.2 to 25.04.2.4.2. This system has been rock solid with no issues at all running 24/7. After the upgrade my SSH connections started failing due to some AUX parameters that were set. While trying to sort this out the system would shut off. Nothing in logs I can see. At first, I thought it was random, but I put it on a timer and it’s every 30 minutes EXACTLY.
I reset the CMOS, turned off all C6 states and other PM features in the BIOS. I tried two different PSU and disconnecting/reconnecting hardware. I’m down to just a MB, RAM, and my SSD boot pool and it’s still happening.
At this point I’m suspecting TrueNAS, but it could be a fluke of hardware. However, I see some older threads about it.
Just to follow-up on this one. I have no idea what caused the issue, but after seven tests of it shutting off at 30m it now runs fine. I disabled everything in the BIOS and the last setting I recall changing was some thermal CPU protection, but the CPU never went over 30c. In any case, writing this for any future readers who may experience something similar.
